no room for tape. I did the best I could.
oil on the good foot
Hey Phil, yours is still good? How many miles?
Hey Eric, If it starts leaking again, I would verify that the breather element inside the air box isn't plugged up. They can get pretty nasty with this Florida humidity.
Had the airbox out changing the intake boots and it looked good to me.
The original seal is unavailable- even splitting the cases would not fix it.
The speedy sleave looked ok to me but it might get a groove like the crankshaft did from the seal over many miles.
I'm not a mechanic like you guys but am keepin this bike running great with y'all helping here.80 G
I break cleaned the oil and old silicone
I sanded the edge of the speedy sleeve with 800 grit-wasn't sure which way to go- in out or back forth. Painters blue tape might work if done right.
Then put oil on the lip and silicone on the out part of the seal.
I hammered a piece of wood against the seal and then a big socket, left it overnight.80 G
Originally posted by speedlimit85 View PostThat seal and got 2 more coming. I sanded wrong but just the edge, electric tape seems strong to protect it if I can cover the edge cone and remove after seal is in.
How to remove the sleeve if needed?1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors )
