oil on the good foot
  • speedlimit85
    • Jan 2017
    • 434
    • Gainesville, Fl.
    #211
    no room for tape. I did the best I could. Click image for larger version
    80 G
      • 1818
      Looks good. Hope it works. Hey Phil, yours is still good? How many miles?
        • 8797
        Still good, I did the repair about a year and a half ago, probably around 15K miles. I didn't use a repair sleeve.
        Hey Eric, If it starts leaking again, I would verify that the breather element inside the air box isn't plugged up. They can get pretty nasty with this Florida humidity.
          • 1818
          That looks delicious.
          • speedlimit85
            • Jan 2017
            • 434
            • Gainesville, Fl.
            #215
            Had the airbox out changing the intake boots and it looked good to me.
            The original seal is unavailable- even splitting the cases would not fix it.
            The speedy sleave looked ok to me but it might get a groove like the crankshaft did from the seal over many miles.
            I'm not a mechanic like you guys but am keepin this bike running great with y'all helping here.
            80 G
            • speedlimit85
              • Jan 2017
              • 434
              • Gainesville, Fl.
              #216
              I got a good feeling about this one 65,000 mi
              Phil, those scrambled eggs could be wax from the Pennsylvania oil.
              80 G
                • 8797
                Yep, I think all conventional oils have paraffin wax but Pennzoil and QuakerSnot probably have the most. ​​​​
                • speedlimit85
                  • Jan 2017
                  • 434
                  • Gainesville, Fl.
                  #218
                  I break cleaned the oil and old silicone
                  I sanded the edge of the speedy sleeve with 800 grit-wasn't sure which way to go- in out or back forth. Painters blue tape might work if done right.
                  Then put oil on the lip and silicone on the out part of the seal.
                  I hammered a piece of wood against the seal and then a big socket, left it overnight.
                  80 G
                  • speedlimit85
                    • Jan 2017
                    • 434
                    • Gainesville, Fl.
                    #219
                    And got oil in the cover right away. I am really disturbed.
                    I am buying 2 more to try and install better.
                    80 G
                      • 8797
                      Wow, that sucks. What kind of seal did you use? The same kind as last time?
                        • 1818
                        800 grit might be too rough and if you crossed the direction of rotation that would be bad. Micro grooves may be present. You need 1500 + as mentioned and you would need to polish in the direction of rotation wetted with oil. Not across. Maybe a new sleeve is in order.
                        Click image for larger version  Name:	image_5280.jpg Views:	0 Size:	238.4 KB ID:	877705
                        Click image for larger version  Name:	s-l1600 (28).jpg Views:	0 Size:	149.9 KB ID:	877704
                          • 1818
                          It looks like the single lip Viton high temp unit.
                          • speedlimit85
                            • Jan 2017
                            • 434
                            • Gainesville, Fl.
                            #223
                            That seal and got 2 more coming. I sanded wrong but just the edge, electric tape seems strong to protect it if I can cover the edge cone and remove after seal is in.
                            How to remove the sleeve if needed?
                            80 G
                              • 1818
                              Not sure. Never used one.
                                • 2083
                                Use a dremel tool with a cutoff wheel and a steady hand, only cut half way through the thickness, then using a small straight pick or sharp scratch awl inline with the crankshaft right at the score line, carefully tap the point of the pick/awl in between the sleeve and the crank to split the sleeve off of the crank.
