oil on the good foot
  • speedlimit85
    • Jan 2017
    • 437
    • Gainesville, Fl.
    #166
    justme1100
    Oil Seal and Speedy sleeve for shaft
    Ok, did not read every post but on my XJ that seal can be ordered for $10 or less. Got my latest one from Advance Auto, Rock Auto. com also has them. National 223240 Have bought 3 so far. 1st one didn't work, thought it was bad. Found a speedy sleeve(I could look for the box for the part number if you need it cuz I got it somewhere), repairs the groove from the shaft from years of wear by the spring in the seal. Works great but you have to put it on backwards so you don't have to split the cases. Use a dremel tool to remove rough edge, found this out when I replaced the 2nd seal after flooding my crankcase with oil over the winter and that edge tore up seal #3. I am waiting for seal #4 to arrive, 2 day wait, I hope this helps.
    80 G
      • 8850
      I would be 100% sure its leaking from the seal and not somewhere else like the base gasket, and running down the case, dripping off the weep hole, I have that problem with mine except its on the alternator side. I sprayed foot powder on the case under the cover, below the seal. No leak at the seal but its a real fooler.
      I wonder if it's possible for the oil to leak thru under the speedy sleeve.
      • speedlimit85
        • Jan 2017
        • 437
        • Gainesville, Fl.
        #168
        I took the left cover off and some oil is inside. I don't want to take it apart again right away- it's running too good.
        Soon I will take take it apart and should be able to see where it is leaking from. If it is under the sleeve, I don't know what to do. If it is the seal to the sleeve on the crank, I could sand the edge better so the seal can go on unharmed.
        I was thinking of getting a tougher seal: https://www.oringsandmore.com/fkm-oi...rice-for-1-pc/ what do you think?
        80 G
          • 8850
          Yep, I guess you could try a different brand of seal, may work out better, who knows. If you are worried about the seals lip being damaged upon installation, maybe wrap a piece of electrical tape around the crank overlapping the edge of the sleeve. Then install the seal and after it passes over the sharp edge, pull out the tape.
            • 2089
            "If it is under the sleeve, I don't know what to do."
            The leak may very well be coming from in between the crank and the Speedi-sleeve which is why they must be installed with red loc-tite
            • speedlimit85
              • Jan 2017
              • 437
              • Gainesville, Fl.
              #171
              Tape is a good idea.
              80 G
                • 789
                #172
                The corner of a plastic sandwich baggie has always been my go to when installing a seal on a splined shaft.
                  • 8850
                  Hey Eric, which are you running, conventional or synthetic oil in your engine. And what weight? Synthetic can work its way past seals sometimes when conventional wont.
                  Also using thinner than 20W50, the crank can rattle around causing a seal to leak. A higher mileage engine can do this due to worn crank bearings. Your engine mileage is somewhat low IIRC.
                  • speedlimit85
                    • Jan 2017
                    • 437
                    • Gainesville, Fl.
                    #174
                    I heard the crank could wobble. I've been using 10w40 conventional with 58,000 mi. 20w50 is a bit thicker right? Ive been regularly changing oil every 3,000 mi w/filter every other.
                    80 G
                      • 8850
                      Yep, I would try the 20W50 conventional non-synthetic next time around. Yes it is a bit thicker and with 58K on the clock, that's what I would be using. The crankshaft bearing clearances on these old air cooled engines is a bit on the large side, so the thicker oil should help.
                      The 20W50 is getting more difficult to find these days, your Walmart should carry it for $18...
                      The Supertech brand in the blue jug has been changed to a semi synthetic, so this seems to be a suitable replacement.
                      Click image for larger version  Name:	IMG_20230121_085628.jpg Views:	0 Size:	159.2 KB ID:	871750
                      Click image for larger version  Name:	IMG_20230121_085706~2.jpg Views:	0 Size:	130.5 KB ID:	871751
                      • speedlimit85
                        • Jan 2017
                        • 437
                        • Gainesville, Fl.
                        #176
                        I may have amazing news, replaced leaking o-ring under left cover. It looked like I crushed it when replacing last time. It can fool ya...I have not looked at the seal, it may be working. I'm gonna put more miles on and see it I get any more oil on the good foot.
                        80 G
                          • 8034
                          If you end up having to revisit the seal, try this stuff. I fixed three hydraulic actuators with it. It works and my save you the hassle of repair.
                            • 8850
                            I hope that's all it is, good luck.
                            • speedlimit85
                              • Jan 2017
                              • 437
                              • Gainesville, Fl.
                              #179
                              Update: seal and sleeve are working.
                              after 3000mi no oil leak
                              80 G
                                • 8850
                                Am I close to a real bike mechanic yet?
                                Yes you are, congrats. That's awesome.
