Hey Eric just a thought, does your engine run smoothly or is there any excessive vibration? The latter may be the crankshaft bouncing around causing the oil to get past the seal. If a bearing is worn and/or the oil is too thin, I would think this could be possible.
oil on the good foot
JAT Are the stock crank seals directional ?1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
The bike runs great and the seal and sleave worked for 10.000 mi. It was dry in there and I felt and looked- I remember a smear under the timing plate felt and smelled like burnt rubber. Maybe the seal was degrading against the sleave at the outer edge to the second lip?
I have to try another seal before attempting to remove a metal sleave from the crank in a small space.
I had a leak repair at the oil return and ran low on oil during these 10.000 mi I don't know but a seal should stop oil at most temp, pressure, grade quality, quantity...and for more miles.
No one else is gonna fix it. so I gotta do it with your help.80 GComment
The seal is 32x 48 meaning there are less than 16 mm to fit a dremel without cutting into the case. Is that available or possible?
Use a dremel tool with a cutoff wheel and a steady hand, only cut half way through the thickness, then using a small straight pick or sharp scratch awl inline with the crankshaft right at the score line, carefully tap the point of the pick/awl in between the sleeve and the crank to split the sleeve off of the crank.
80 GComment
You can also use a micro file and file a groove. You DO NOT want to file all the way to the crank, just a score lineit can split along.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
That may be possible. How do I know if it needs to be removed? I would then need to install another, right?
https://www.oreillyauto.com/detail/c...0/99128?pos=10
yamaha seals:
https://www.partzilla.com/product/ya...eeb19b62f81350
https://www.cmsnl.com/products/oil-s...h7_9310132144/
Other side replacement seal looks directional.
Phil's is working and mine was, the seals we are using are good steel with high temp rubber (bi-directional I think).
https://www.oringsandmore.com/oil-sh...-ref-cr563065/
https://www.oringsandmore.com/fkm-oi...rice-for-1-pc/
80 GComment
There is possibly more to this seal issue than an off the shelf 32x48x8 size. Material & design of the original part must be taken into account. It's very possible that there was nothing really wrong with your installation that lasted 10,000 miles or mine that lasted 7,000 miles. I think a badly installed seal will leak right away. The issue could be seal design and material. There are directional seal designs and specific materials that come into play. Our replacement seals were possibly good but could have simply wore out quick from friction and heat and possibly directional rotation.
https://rlhudson.com/wp-content/uplo...seal-guide.pdf
. Must be directional to pull oil in towards the motor. You can actually see the directional ribs in this picture (stock "split_the_case" type seal).
