oil on the good foot
  • speedlimit85
    • Jan 2017
    • 434
    • Gainesville, Fl.
    #151
    It fits! Glad I didn't tear it up in anger. What's the torque for the valve cover?
    80 G
      • 8802
      I think it's 7 ft/lb.
      • speedlimit85
        • Jan 2017
        • 434
        • Gainesville, Fl.
        #153
        Before closing it up, would it be a good idea to verify the timing with TDC by the piston movement in # 1 cylinder?
        80 G
          • 8802
          If you want. The #1 piston should be at TDC with the cam dots lined up with the arrows and the timing plate at the T mark.
          • speedlimit85
            • Jan 2017
            • 434
            • Gainesville, Fl.
            #155
            Someone suggested that- I may check. #1 is left side facing forward right?
            80 G
              • 8802
              1 thru 4, left to right, sitting the bike.
              • speedlimit85
                • Jan 2017
                • 434
                • Gainesville, Fl.
                #157
                It runs right. Bike is fixed!
                I put it all back together. This time the bolt and reluctor plate moved into right position the torque wrench clicked right. This bike runs like this never happened.
                80 G
                  • 8802
                  So it was all just a bad dream?
                  Glad it's running right and you learned a few things along the way.
                  Back to poppin' wheelies again. : )
                  • speedlimit85
                    • Jan 2017
                    • 434
                    • Gainesville, Fl.
                    #159
                    I think what happened was the centrifigal advance was out of place like you said can happen.
                    And I advanced the timing like ya said- a bit CCW. It might be a 1200 now...running scary good!
                    80 G
                      • 8802
                      Yep, a little advance on the timing will sure pep it up. The idle speed may need to be turned down a tick, the advancement will bring it up.
                      • speedlimit85
                        • Jan 2017
                        • 434
                        • Gainesville, Fl.
                        #161
                        I want to sum up for anyone installing a speedy sleeve on the crankshaft left side. I got no oil on my left foot so far...only a few hundred mi.
                        Put the sleeve in the oven 200deg and install backward with the flange facing away from the bike. Hit the tool into the sleeve with a hammer onto the crankshaft all the way to cover the groove. Then remove the flange with cutter and needle nose pliers twisting like a sardine can. I sanded any sharp feeling area. Then install seal.
                        80 G
                          • 2083
                          It took "ELEVEN" pages for success sumpin's goin' on here
                            • 2066
                            Nice job - congratulations on you success finally.
                            Maybe you could include the source and P/N for the sleeve in your summary - for others that come by later. I looked through the entire thread and didn't find them easily.
                            Also did you use red Loctite or something else to bond and seal the sleeve on the crankshaft?
                            • speedlimit85
                              • Jan 2017
                              • 434
                              • Gainesville, Fl.
                              #164
                              part # 99128 for the sleeve at any auto part store is 32 mm for the crankshaft should be good for both sides
                              I put the sleeve on with no bond advised by a mechanic. I used permatex blue for the outside of the seal and oil for the inside.
                              80 G
                              • speedlimit85
                                • Jan 2017
                                • 434
                                • Gainesville, Fl.
                                #165
                                I hate to say it. It is slowly leaking again after 3000 mi.
                                The only thing I can think of is the seal could have caught a sharp edge on the speedy sleeve on the way in. I sanded the edge but maybe not good enough.
                                80 G
