  • Bellerophon
    • Jul 2011
    • 103
    • Meridian, Idaho
    #1906
    Left side wheel bearings are available on eBay. I remember a thread where this guy said he had several custom made in Japan. Here's the link. http://www.ebay.com/itm/Yamaha-XS110...0fe514&vxp=mtr
    Thread here. http://www.xs11.com/forum/showthread...+wheel+bearing
    2016 Yamaha FJR1300A
    2007 Kawasaki KLR650A
    1979 Yamaha XS1100SF
    1971 Kawasaki F6 125
      #1907
      Just about back to where I started.
      Today
      Replaced thermistor fuel level sender with one that works (Thanks Andreas)
      Tried to balance carbs with a home-made ATF filled manometer.
      Had to remove the carb rack to eyeball-align the butterflies back into position after I'd screwed up the manometer balance.
      This was a good thing.
      The removal showed the rear support strut that the carbs need after you've swapped the stock airbox for pods was fatigue-cracked so it got re-welded.
      The removal also showed the throttle cable was partially frayed where it enters the lower nipple. Lucky I had a spare.
      Ran the bike to check the eyeball alignment worked.
      Fogged the neighborhood until the ATF that got sucked into the motor burned away.
      When the smoke cleared I took off my 2 pint pony tank, put the Standard tank back on and ran the rig around the block.
      Ran like a bastard until the 2nd corner then started to falter.
      Remembered to turn the Standard tank's manual fuel taps back on.
      Ran good all the way back home.
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        #1908
        Today
        Fred, what is it with you and running out of gas?!
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
        • mikubuilder
          • Jul 2011
          • 548
          • Westland, Mich.
          #1909
          Looks like James put his stash on Bay
          Nick
          1982 Virago 750 (it's alive!)
            #1910
            Yes, James was selling them on eBay the whole time for a little bit more than he was selling them directly to us here.
              • 6762
              #1911
              my turn...ordered a set of progressive front fork springs......the emulators from Race tech will be a future order...also procured a pair of XJ rear shocks...once the fork springs come in then we'll upgrade the fronts and swap out the rears... hopefully we'll firm things upo 'cause right now it aint so good...
                #1912
                Solved a long time obnoxious oil drip. I sort of had the feeling it was the cylinder base gasket leaking, turned out to be the oil pressure sender being loose. Now she doesn'tmark her territory!
                  • 7940
                  Progressive springs are not a good choice if you plan to install emulators. Granted, I'm extremely prejudiced against progressive springs, but the experts at either Race-Tech or Traxxion Dynamics will agree with me. If progressive wound springs are what you want, you're done.
                    • 6762
                    #1914
                    well I dont profess to know anything abt suspensions but this is what i can afford at this time..my buddy Mark says i'll be fine with this...sorry if that offends the popular vein of thought... I need an improvement and i need to get this bike ready to ride the roads we'll be on during the SE XSive Riders Rally...its going to take me until Oct to reestablish the money flow and catch up with bills...being a 10 month employee sucks...money stops for 8 freaking weeks...plus I only get paid once a month...you cant imagine what a pain in the ass that is...In fact I wont be getting my check cleared for Sept until the 30th...1 effing day after the rally...so I honestly cant even tell you if i will with 100% certainty that I will be there...same thing happend last year and i barely made it ...
                      • 7940
                      Ben,
                      Straight rate springs don't cost more than progressive springs. You said you wanted to add emulators. I'm trying to save you money. If you go to emulators later, you'll be buying springs again. Progressive springs and emulators are different technologies. Yes they will function together, but not like they should.
                      The money thing is a drag, but you have a job. Many people don't and I'm one of them. It's not a good place to be.
                        • 6762
                        #1916
                        just one more example where I got my facts skewed... sorry to hear you're outta work...hadnt heard of that before......I spent 5+ yrs out of work before my present job...it may be crappy how we get paid but like you said at least I have a job...I'm planning to die on this job...I and then collect unemployment afterwards...LOL BTW I wont be combining these springs with the emulators..i just didnt know better...
                          • 9980
                          Pin striping on The hornet's fairing .........for however long it stays on.
                          • CRXSi90
                            • Jun 2004
                            • 400
                            • Madison, Wisconsin
                            #1918
                            Picked up a replacement jet and cleaned the airbox.
                            '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
                            '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
                              • 9980
                              Been working on The Green Hornet today. After my stupid mishap with the tank.........
                              I got it repainted and finish sanded yesterday........
                              I still have to get the throttle lock sorted out but I'm basically ready for the Lost Rally in Wisconsin.
                              Installed the fairing and the 3 point engine guards and the old soft bags for now.....
                              • jjz28
                                • Apr 2012
                                • 1023
                                • Beckley, W. Va.
                                #1920
                                looks really good greg, that fairing fits in nicely. I really think I will wind up getting a fairing for mine and put the slipstreamer ss-28 on my xs750. What fairing is that exactly?
                                77 XS750 2D completely stock
