  • Elevener
    • 608
    • small town in TEXAS
    #76
    Well I got everything on except for fork seals. Still need to bleed front brakes (stainless lines). Gonna pick up some hose for that tomorrow. Put mikes coils on, wires and ends, new plugs. Geezers rectifier, new cables and handgrips. Im just a week behind schedule . I learned last weekend to not try to work on your bike if your on call.
    Trapped in time. Surrounded by evil. Low on gas.
    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
    • psycoreefer
      • Feb 2008
      • 1557
      • Minden, NV
      #77
      79 - nothing
      81 - put the carbs back together, put the carb on it, balanced and adjusted idle mix. Got the tank full of electrolyte and started the electrolysis.
      1979 xs1100 Special -
      My Bike:
      [link is broken]
      • ross
        • Dec 2006
        • 542
        • see signature...
        #78
        XSive exprements....
        Originally posted by psycoreefer
        79 - nothing
        hey there psychoreefer....let me know how that tank thangy works....i got one sitting in the man-cave for a test subject.....ride hard, ride safe...ross
        rebel devil
        1979 xs 1100f standard
        authenic historical vehicle
        42°36'23.52"N, 82°52'44.78"W
        "I'M IN MY HAPPY PLACE"
        "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
        "if you don't wrench on it, get behind me satan!"
        '96 venture cct.....installed!
        stainless, braided, pvc coated brake lines
        i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
        • randy
          • Dec 2003
          • 4521
          #79
          Today I went through the carbs, did the XV920 float valve mod. Tomorrow night new skins. It's been a busy winter here,
          -new starter clutch
          -new main and rod bearings
          -venturer tensioner mod
          -xv920 float valve mod
          -tapped and plugged the oil gallery 'cork' under the stator cover
          -changed oil pump, it prolly ate the mains.
          -polished everything that doesn't move. polishing really blows.
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            #80
            Hey Randy what's so special about the XV920 float valves? Where did you get them ?
            -new starter clutch
            BDF Special
            • randy
              • Dec 2003
              • 4521
              #81
              well, you have an '80 so I'm not sure it's an upgrade for you, but the '78-'79 carbs have all metal float needles. The XV920 has a viton tipped needle and it has the threaded seat that the earlier carbs use. I got them from Zanotti's. Don't be tempted to order them from Parts n more, theirs don't have a filter screen on 'em. IIRC, 81xsproject posted the mod a while back.
              • ManitoulinLad
                • 358
                • Manitoulin Island,Ont.,Canada this is in Lake Huron
                #82
                After supper last night I did my 1st oil change since the rebuild. I finally got my petcock rebuild kit & did that - orginally I just took them apart ( quite a few days ago) & cleaned them & put them back on. Please Use Diver Rays trick of die-electic grease when you put it back together - I didn't know that at the time - dry "O" ring tore & it leaked on the one side - did it again last night with new stuff & used the grease - perfect. Man alive what a difference with the new rubber in there - smoooth. - dan
                '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                1179 big bore kit, 80SG motor
                Rebuilt head, valves
                TC Bros Forward Controls (Brass Pegs)
                Tkat Fork Brace
                T.C. Spade Fuse Box
                Dyna Coils & wires
                Mikesxs shocks,controls,& bars (special)
                ISO grips with stelleto ends
                4 into 1 black Bassani exhaust
                Bridgestone Spitfires
                Tuned by Tinman905
                & a will to keep it.
                • Wildkat
                  XS Special Gurette
                  • Apr 2004
                  • 3416
                  • Location, Location
                  #83
                  Originally posted by Wildkat
                  Looked at the XS and thought about polishing her... because that's usually all she ever needs...
                  Jinxed myself by saying this and had to repair an oil leak and now I have a hole in my exhaust... So today will be spent polishing up the stock system John got for me...
                  81 SH Something Special
                  79 SF MEAUQABEAUXS
                  81SH Nor'eas tah (Old Red)
                  80 LG Black Magic
                  78 E Standard Practice
                  James 3:17
                  “Alis Volat Propriis”
                  Yamaha XS 1100 Classic
                  For those on FB
                    #84
                    Originally posted by ManitoulinLad
                    - - - Man alive what a difference with the new rubber in there - smoooth. - dan
                    Hi Dan,
                    oh yes, it's always best to use a new rubber.
                    • mro
                      • Oct 2005
                      • 4276
                      • Hayward, California
                      #85
                      Took the carbs off one SF. Needed to see how much adjustment was left between the carbs for synking. Reset those and should have em back on tonight.
                      Little further along taking apart an G for paint and a few possible mods. Sure seems to take longer to do stuff now a days.
                      mro
                      • psycoreefer
                        • Feb 2008
                        • 1557
                        • Minden, NV
                        #86
                        81 - got the carbs all set, replaced the too short throttle cable with a spare I had around. Changed the oil, put a crush washer under the drain bolt so it would stop leaking. Put on 2 new spark plug boots (2 were bad) and clipped a bit off all the wires to ensure good contact, replace all the spark plugs with new. Checked the ignition timing.
                        79 - changed the oil and filter, tried to get motivated to do the front brakes, but realized I didn't have any brake fluid.
                        My Bike:
                        [link is broken]
                        • DenyP
                          • 599
                          • Staples, Minnesota 56479
                          #87
                          I replaced my rear wheel and tire, did some lube and took her out for a good spin. Dang it has been a long winter. She walked up to 110 with out too much flogging. I did notice I have a little stumbling as it is coming off the idle circuits at around 4000 and also at 7000 rpm. In both cases it happens across a few hundred rpms at most. I know the 4000 mark is due to carberation, but I haven't pinned down what is going on at 7000.
                          Deny
                          • ManitoulinLad
                            • 358
                            #88
                            Hey Fred Funny as usual - nothing gets buy. But y'know my Dad's only words of advise when I left home was that "he never believed in washing his feet with his socks on". Maybe thats why I got married real young hehe - Dan
                            Tkat Fork Brace
                            T.C. Spade Fuse Box
                            Dyna Coils & wires
                            Tuned by Tinman905
                            • slow mo
                              • 858
                              • ontario canada
                              #89
                              Hi Dan,
                              i,m in agreement with my friend from the flatlands! its always best ,,thanks Fred ,,hi ya Dan see ya soon in the ride around the bend!! ride safe ,,slow mo!
                              moemcnally@hotmail.com
                              i AM THE KING OF NOTHING
                                #90
                                Hey Fred Funny as usual - nothing gets by. - - -
                                Hi Dan,
                                back on theme, today I managed to salvage the inside out exhaust nut that had the stud busted off in it, re-tapped the other 7 and died down the 2 studs that came out with the nuts to clean the threads up; made a new stud from a long bolt.
                                I also managed to get the exhaust all taken apart at the joints. Got mad and cut the clamps off. Can get new stainless ones that have accessible fasteners.
