oil on the good foot
    • 1987
    1. Yes that oil drain hole is supposed to be there, I just checked my spare engine case and it has it too.
    2. After you finish the job and everything is all good, then yes, you will then be a real bike mechanic.
    Take that wrong size seal to a local bearing shop and tell them you need one with a 48MM outer diameter with all the other dimensions being the same (32X48X8). That one you have there is probably 45MM and for the other side of the bike.
    If you can't find one anywhere, I have a few extra new ones, I could send you one.
    Click image for larger version Name:	IMG_20220731_193911.jpg Views:	0 Size:	111.4 KB ID:	869751
    Phil, do you have any idea what the exact part number was for those seals you have? Looks like a good source for them.
      • 8891
      I bought them on eBay, here is the link....
      https://www.ebay.com/itm/20255519657...wAAOSwofxUmG0p
        • 8891
        Here is the link for the seal directly from O-rings and More...
        Stocking distributor of metric o-rings and seals in various materials and sizes. Metric Orings in Buna 70 & 90, Silicone, Viton and EPDM material.
          • 1987
          Awesome. I had just finished looking them up as well and you beat me to this post. I think that this should be something that should be posted permanently for future use.
          • speedlimit85
            • Jan 2017
            • 446
            • Gainesville, Fl.
            #35
ID:	869811 well, that's not right. I need a new one. I need to put it in right.
            80 G
            • speedlimit85
              • Jan 2017
              • 446
              • Gainesville, Fl.
              #36
              Is this the wrong seal? the seal is 30x48x8 but the label is 32x48x8
              80 G
                • 8891
                The numbers should be stamped on the seal 32 48 8. If the inner diameter is 30 on the one you installed, that would explain why the seal collapsed.
                • speedlimit85
                  • Jan 2017
                  • 446
                  • Gainesville, Fl.
                  #38
                  Yes. They are sending me the right one.
                  80 G
                    • 8891
                    That's good, put a little oil on the inner part of the seal before installing the new one. So if I understand correctly, the wrong seal was in the box marked 32x48x8?
                    • speedlimit85
                      • Jan 2017
                      • 446
                      • Gainesville, Fl.
                      #40
                      Yes. I didn't look at the seal only the label. I thought I was doing it wrong-was hard to install. After getting the seal out saw the numbers on seal were wrong.
                      I was told gasket maker-silicone on the outer part too.
                      80 G
                        • 8891
                        Yes, thin layer of gasket maker on the outside edge of the seal only, a little oil or grease on the inner part of the seal where the crankshaft spins.
                        • speedlimit85
                          • Jan 2017
                          • 446
                          • Gainesville, Fl.
                          #42
                          It runs. Oil seal not leaking. My new ebay pick up coils need repair right away. I think I did it, but I need those pick up coils to work just right. Is there a better source for replacement?
                          80 G
                            • 8891
                            As far as I know, there isn't anything available as far as new replacement units. Once repaired correctly, the old units should last a pretty good while.
                            BTW, the correct gap of the P/U coils is .027" (.7 mm).
                            • speedlimit85
                              • Jan 2017
                              • 446
                              • Gainesville, Fl.
                              #44
                              There is still paint on the screws. If they weren't removed don't need to gap right?
                              80 G
                                • 813
                                #45
                                How do you delete a bad reply? Sorry!
