2017 Colorado/Western Rally
  • Bigfoot
    XS-XJ GURU
    • Sep 2005
    • 1422
    • Kansas City, Missouri
    #211
    I'm in for a shirt. 2xl short sleeve.
    Are you gonna make it out to Colorado?
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
    • dpotter58
      • Aug 2004
      • 1848
      • Southern Maryland
      #212
      I'm going to be there!! Pretty excited about it too.
      1980 LG
      1981 LH
        • 9980
        There goes the neighborhood..
          • 3241
          dpotter, glad you are in! You gonna do the campground or hotel/cabin?
          ZRX1200
          Seca 750
            • 3241
            Originally posted by BA80
            You gonna do them in just short sleeves or long sleeves also?
            If you are doing both I'll probably take one of each. Large
            I was thinking short sleeve, however long sleeve is a good thought too. Let me look into it in the next week or so for cost and I'll post up about that.
            ZRX1200
            Seca 750
            • Bigfoot
              XS-XJ GURU
              • Sep 2005
              • 1422
              #216
              Awesome. Look forward to seeing you again.
              Harry
              '79 Standard
              '82 XJ1100
              '84 FJ1100
              Acta Non Verba
              • dpotter58
                • Aug 2004
                • 1848
                • Southern Maryland
                #217
                Hotel. already reserved.
                1980 LG
                1981 LH
                  • 3241
                  Awesome.
                  I syn'd the carbs on the ZRX today. How does this look? Thanks CaptonZap for the loan on the sticks!
                  ZRX1200
                  Seca 750
                  • CaptonZap
                    • Jun 2010
                    • 1748
                    • Denver
                    #219
                    That sucks!
                    CZ
                    p.s. What RPM?
                      • 3241
                      1152.2 rpm.
                      Was at 1200 rpm... can't see it by the angle of the dangle of the picture.
                      ZRX has a really low oil pressure when warmed up at idle based on guys putting a gauge to it. Spec calls for 1000+/-50 rpm.
                      Hey, with the air that gets in those columns do I need to account for that or still go with just straight across the top regardless of air below?
                      ZRX1200
                      Seca 750
                        Straight across top of preferably mercury fluid. No zoom-in, but looks to be approx. 17in.vac. across the four.
                          • 5064
                          #222
                          Awesome.
                          That looks great, but only if it was done near idle rpms.
                            • 5064
                            #223
                            I subsequently saw that it was done near idle. Good. Concerning air in the column(s), I couldn't really see how much was in there. It is the weight of the column of fluid that really counts, so if there was a lot of air, I would have brought it back to the reservoir and started over. As an alternative if one of the columns had like 1/2 inch of air below the the top of the mercury, you could subtract the height of that one by 1/2 inch because air is essentially weightless in comparison.
                              • 3241
                              Yeah, I agree. I'm going to hook it up again and account for the air in the columns. The mercury level in the reservoir is not "full" and being that it's hard to come by, I don't see adding any. The bike idles like a smooth purring cat now though.
                              With your ST 1300, the FJR 1300, Kawasaki C14 and C10, we're going to have all the super sport tourers represented. If Roo comes he will have a Kawasaki Nomad.
                              That said, does anyone know of a kit or mod that moves the pegs forward on the Special models? That would relieve my knee bend and make the bike much more enjoyable to ride for more than an hour here or an hour there.
                              ZRX1200
                              Seca 750
                                Guess you could use the mercury out of old themometers, or if your home has the slider type thermostats which do use mercury contained tiny resovior, for electrical contact trigger to come on........switch 'em out for digital thermostats and pour the mercury in the mamometer resivior.
