Giving high mileage bike some love. Now ran when parked?
    • 2011
    I recently picked this up. BAM.
Name:	Stock XS11 Clutch.jpg
      • 8062
ID:	887572 Click image for larger version
      I replaced both pickups. One had a broken wire right at the housing. Once again, it runs on four cylinders. At least, on the lift. This ignition advance is really wonky. I’m sure my bike has a lot more years and miles than were ever intended.
        • 8893
        What is the mileage? Yamaha really over engineered these you know. I believe a well-cared for engine can make it at least 200K.
        I'm sure it also depends on riding style too.
          • 8062
          I’m on my third speedometer. I think I went over 100,000 a few years ago. It fired right up on the lift. No smoke. I believe I fixed two leaks or I hope I did.
            • 7819
            I do have an advance unit if you find you need it.
              • 8062
              Thanks Ray! I believe I have at least one of those if I need it.
              I let it sit a few days with 20 ml of MMO on top of each piston. I also found spark plug gaps way too fat. It fired right up after this last fix. I hope I can give it a good run this coming weekend.
                • 8893
                Taiwan/Japan source?
                Parts Unlimited cables say they are from Taiwan...
                https://www.ebay.com/itm/16789329778...90.c101224.m-1
                  • 2011
                  I have had better luck with Parts Unlimited cables. They are pretty good quality.
                    • 813
                    #69
                    Having owned a Suzuki GS, which are known to eat clutch cables, I'll take NOS or even a good working used cable over anything on the aftermarket.
                      • 2097
                      I'm with ya on that LAB3, also I run two cables for my throttle and clutch on my full dressed '80G, that way they never break on a dark rainy night.
                      • speedlimit85
                        • Jan 2017
                        • 449
                        • Gainesville, Fl.
                        #71
                        The oem cable has a swivel on the lever end. The others don't so fray and snap.
                        80 G
                          • 813
                          #72
                          Even then you need to pop it out and give it some lube every now and again.
                            • 8062
                            I poured half a can of Seafoam into the tank, took it off the lift and rode it. I did almost 50 miles of local backroads. Thunder is getting close as I garaged it.
                              • 8062
                              It seems to run just fine. Pulls hard. I can’t detect smoke. It started right up from cold. Seat of the pants, it feels great!
                              ​​​​​I tried to post an image. I keep getting an error.
                                • 8062
                                Just to recap:
                                I let it sit for days with MMO in the cylinders. I did close spark plug gaps into spec. Fresh oil. Seafoam in the tank 50 miles. Today, I filled the tank from empty with Top Tier 93 octane. I drove 14 miles.
                                I just did another compression test warm.
                                180-172-165-170
                                The spark plugs went from sooty black to what looks very good.
                                I’m happy to say it pulls very hard now. I still have to address the clutch.
