Giving high mileage bike some love. Now ran when parked?
    • 8077
    Marty, get a new set of clutch springs, Barnett if you can, and just replace them. I noticed years ago the factory springs would no longer work well. Too many years being compressed and they lose the ability to work properly. I've had clutch plates from the factory still work well IF I replaced the springs.
    They’re certainly inexpensive enough to give it a go. I put a set of Vesrah in an XS650 and the pull wasn’t noticeably more.
      • 7831
      Barnett is ALL I use for a reason. I have a complete clutch set for my winter project, and may put in a set on the '79 to keep the clutch working correctly.
        • 8930
        Make sure your clutch cable is in primo condition when using those Barnett HD springs. Just a heads up, motion pro cables are not what they used to be, they are cheap Chinese crap now.
          • 8077
          I found them and for only a little over $30.
          Barnett Clutch Springs - Parts Giant
            • 8077
            Back to OE for a superior product? Or, is all of it crap like everything else.
              • 8930
              Cables made in Taiwan or Japan seem to be better, I had 2 motion pro cables fail at the engine side, the ferrule broke off. No problem with the Taiwan, don't know about OEM.
                • 8077
                Taiwan/Japan source?
                  • 2007
                  I put Barnett kits in all 3 of mine year before last. Quite an improvement I must say. Now I have to keep my fingers crossed concerning my clutch cables. I put new cables on all three when I did the restorations on them. Sadly I believe they were motion pro. Like Marty I would love to know the source. Did a bit of research and AI says that the Motion Pro 05-0058 clutch cable is made in China. I am assuming that because Taiwan is literally a part of China that may be why Google AI assumes just China. I also found this listing on Ebay Yamaha XS1100 1978-1982 Black Vinyl MOTION PRO - 05-0058 - Clutch Cable | eBay the label clearly says Taiwan. Of course Motion Pro itself is a California based company which prides itself on USA made products. I am at this point hoping my cables are fine.
                    • 8930
                    The ebay vendor I purchased from 4 years ago no longer has them, I will try to find another source when I get a chance. I remember the way I found them was to look at many listings and look for the country of origin.
                      I got three miles. Two cylinders dropped out. I believe I have a damaged connection at one of the pick-up coils. Inside where I can’t easily fix it. I believe I can replace the entire assembly. I think I have a spare.
                      Also, it’s time for me to address my worn clutch. I may just pull the assembly out of a parts bike.
                      So sorrry yur repair verification run din't play out like you/we all wanted it to. (•﹏• )
                      Imma 'bout to head out onna "Soft-Serve" run myself and here's a "warm-up" video so's I got's the right feelz fOaR riding my XS. (^-^)
                      (I'm STILL Head-over-Heals in love wit' my XS....)
                      Ummm... 'bout your cable concerns. (O_o)
                      'Bout 12 years ago the end sort'a just slipped offa my own clutch cable. (●´⌓`●)
                      I did my own repair similar to wut's shown here-
                      O'course I got a spare eventully and even carried it wit' me on my gad-a-bouts cross the continental USA. (☉_☉)
                      But I ain't had to use it cuz the repaired one ain't failed yet. (ʘ‿ʘ)
                      Still waitin' tho.... (*′☉.̫☉)
                        • 8077
                        In the last few years, I replaced a few clutch cables with Motion Pro. I don't know if they changed recently, but what have looks pretty stout. This is all I could find with an internet search:
                        Motion Pro Workmanship
                        Motion Pro tools, cables, controls and accessories are designed with high quality materials. Our products are built to withstand years of use. We stand behind our products 100% for quality and workmanship.
                        Google's AI gave me info on the wrong company. They aren't what they used to be either.
                        There are many high quality products coming from Taiwan, Japan, and China. As per usual, you get what you pay for.
                          • 8077
                          Another question:
                          I'm looking for a spec on the distance between each pickup coil and the reluctor. I failed to find it in the OE and Clymer books.
                            • 8930
                            It is .7mm
                            The 2 motion pro cables that failed on me I purchased together, so maybe it was just a bad batch? It was the pot metal that failed.
                              • 7831
                              The cable ends used to be solid solder. It may be with the "new" tin only solder they are not holding onto the cable like the old lead/tin solder.
                                • 2057
                                I have had motion pro clutch cables break on 3 of my bikes. Speedometer/tachometer cables as well. Especially in icy conditions. They are junk. I always grab extra OEM cables when I see them. As far as clutches go, Barnett is great equipment for the 25 year old drag racer. That clutch will never slip and that's the problem. It's a mother on your first gear in the morning. The "crunch" sound from shifting into first gear on a freshly started bike has to be experienced in order to fully understand the cringe moment it induces. I learned this in the 80's and never went back. I use only OEM plates and pads with Vesrah springs. Almost stock pull on the cable and the bike shifts like stock. No clunk. Even pulling a steel sidecar won't make it slip if it's properly adjusted.
Name:	clutch springs.jpg
ID:	887503 Click image for larger version
ID:	887504 Click image for larger version
