New to Japanese, need help with vin info.
    • 1980
    Manifolds from Japan.
    https://www.ebay.com/itm/361850795811
      • 1980
      Kicker. Perhaps the 850 style kicker fits a little better. Try that first.
      https://www.ebay.com/itm/22156088042...Bk9SR7istO_GYw
      Click image for larger version  Name:	s-l1600 (3).jpg Views:	0 Size:	144.4 KB ID:	878345
        • 1980
        Your 80+ motor would need the clutch removed to install the kick shaft assembly and seal. I did this to my motor using info from the forum.
Name:	s-l1600 (oiu).jpg
          • 800
          #49
          That part should look awfully familiar to an HD guy.
          • Mathh
            • Nov 2006
            • 693
            • Beek, Netherlands
            #50
            I think he needs more than that
            MV Agusta Brutale 910R '06.
            Yamaha MT-09 Tracer '15 grey.
              • 1980
              Correct Mathh, this is what you will see inside. There is a small gear and circlip that must also be installed.
ID:	878352 Click image for larger version
ID:	878353 Click image for larger version
                • 732
                If the XS850 is the same, I may have what you need here:
                1980 Yamaha XS850 Triple Kick Start Shaft and Gears. | eBay
                Click image for larger version  Name:	s-l960.jpg Views:	0 Size:	183.9 KB ID:	878365
                  • 2121
                  Ranger: I don't see a starter clutch in those pictures. I just rebuilt my XS750 SC a few weeks ago (again). Maybe the kick starter parts have something that is also a clutch?
                    • 732
                    Thanks Mike,
                    You're right. I'll need to fix that ebay ad.
                    Thanks again,
                    Bob
                      • 1980
                      I know I just posted this picture but it also shows the kicker after I added the gears & seal. It originally had the typical 1980+ kick shaft block-off.
                      • jgonz
                        • Feb 2021
                        • 24
                        • Las Cruces, NM
                        #56
                        Hi fellas, I haven't updated this in a few days and I'm sorry for that. I was supposed to head out this weekend for my two week work trip but, wouldn't you know it... my well went and broke. I use a well for water and last Thursday (or maybe Wednesday, I forget) I was going for my shower and, goose eggs.. no water. I requested to be rescheduled and I've spend that last few days troubleshooting, arranging for well service, ad working on it. I was showering at the gym and basically, not really getting much done because I was otherwise engaged. Honestly, getting on line and posting was the furthest from my mind. This thing also set me back quite a bit of money so I'm a little peeved.
                        I did not order anything as of yet, because I thought I was going to be leaving (I usually don't order parts if I know I won't be here to receive them). I'm definitely going to go ahead with my plans for the kicker, all gaskets will be replaced and the 2nd gear fix will be done. All rubber components will be replaced as well. I will be removed the drive shaft and cleaning the heck outta that. If anyone has any tips on that, please let me know. I imagine that nothing in there will need replacing as the joint looked ok... only cleaning as far as I can tell.
                        I will rebuild the forks. I'll need to replace seals and also the air valve on the left side is broken, so that will have to be fixed. The speedo cable looks a bit worn so I will need to look into that. I don't like the look of that big huge speedo and tach it has for stock, so maybe someone has a suggestion for aftermarket?
                        I think I'm going to be here for the next few days so, unless something changes, I'm going to begin tearing into her and looking around. I also moved the empty frame off the lift and replaced it with one of my shovels, as I have to multi-task when I am able.
                        Love the feedback, fellas, so keep it coming.
                        • jgonz
                          • Feb 2021
                          • 24
                          • Las Cruces, NM
                          #57
                            • 1967
                            Love the way you have the xs11 carbs sitting next to the Harley. I had to look twice. Here is a manual you can reference for the shaft drive. It is for the xs750 but still has a lot of information that still applies. https://www.ringler.us/xs1100/ShaftDriveManual.pdf
                              • 1980
                              Is that a Harmonic balancer and single fire ignition on that Shovel?
                                • 1980
                                When repairing your second gear issue, use a machine shop such as this guy (picture is KZ1000 but he will do any gear). You can send the entire cluster or just the two facing gears and then switch the thrust washer. Cutting the dogs with a Dremel a' la YouTube makes my skin crawl. Hack artists deluxe. Those faces will never meet perfectly and you run a high risk of ruining the hard face by cutting too deep in some areas. There is no way to control damage when you grind it by hand.
                                https://www.ebay.com/itm/380730235282
