Valve Adjustment Pictorial
  • JasonRedbeard
    • 109
    • Tuscaloosa, AL
    Beautiful write-up, Steve. The only thing I'd change is to add a note on the CCT adjustment to the end of it. I haven't done the shims on my bike yet, but it seems like that will be a critical step of the reassembly.
    And Phil....my 5-year-old saw that pic and laughed his butt off.
    My Special is as old as I am.
    • xssiveone
      • 766
      • Windsor,Ontario,Canada
      So.... who's going to post the picture tutorial with the MP tool?
      Actually, I did one about 12 years ago. Haven't been active here for a long time but have been dropping in lately to have a peek around. Glad to see this forum is still going strong.
      The web page I did needs updating, but I'm not sure I remember the password. Everything is there, but it's a bit of a mess.
      XSsiveone valve adjust
      Brian
      remembering the same thing!
        I have used the tool, it works. And it is a good choice if your changing one or two shims. IMO, if your changing out more than that, then for time purposes, I would use one method or another of the cam methods.
        Not against the tool, just my experiences.
          • 8753
          The kid's got a good sense of humor...
            #35
            Originally posted by xssiveone
            Yep, there's another one of those ground-on-to-make-fit MP tools....
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              • Fort Myers, Florida
              #36
              Special
              WOW, not only is my bike "Special" but I must be "Special" too. Am I the only one who can use this tool right out of the box on all 8 valves with no mods or problems
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                • 2076
                Almost the same...
                ...as our Elevens, but IMHO some good info and pics for those that have never done the job yet. Actually I did both my XS11 and XJ750 at the same time and swapped shims around on both engines as they are the same diameter
                http://xjbikes.com/Forums/viewtopic/t=14827.html
                http://xjbikes.com/Forums/viewtopic/t=29209.html
                HTH
                  • 9980
                  +1 I must be Special too.
                    • 7817
                    Well, it looks like at the end of the season I'll be replacing all of the shims AND the cam chain. So, I probably won't find out if I'm "special".
                      • 9980
                      I was just reading your cam chain post Marty. Before you go ordering a new chain, check and make sure all the sliders are OK. As in not XSively worn or broken. JAT
                      Those roller chains aren't really prone to wear. I replaced a timing chain in a Mazda V6 just the other day and the chain was the same as what's in our engines, just longer. The chain was actually fine, the tensioner had gone south.
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        #41
                        Tool
                        Not that special my tools worked out of box also. I think that it can be tuff to get the tool into position on some valves but if you take care its better than pulling the cams for most people. I agree that if you are in a situation where you have multiple valves to get set the cam pull works but in a one or two adjustment I would not use the cam pull method.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        Barnett Clutch Springs
                        R1 Clutch Fiber Plates
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                          • 7817
                          How do I check the sliders? If they are bad, the cam chain damper is NLA. has anyone here come up with a trick to repair it? Does the engine have to be disassembled to remove and replace it? Will my engine be making a lot of noise if the plastic material is gone?
                          I'm going to move this over to the cam chain wear post as well.
                          • Rasputin
                            • 3189
                            • Lacombe, Alberta, Canada
                            #43
                            Just gor giggles
                            I went out to the man cave and got my Yamaha shim tool and my MP shim tool out. I tried both on a head I have lying about. Both will work but the MP is quite a bit harder to use. I got to comparing the two and thought you all may like to see what I found. Here is a pic of the two side by side in a vice. Sorry the pic is not clearer but I am not much of a photographer. This may explain why so many have to grind the MP tool. The Mp tool is the top and blackest one. I had never tried the MP one before today and it was a suprise that it sucked so badly.
                            2-79 XS1100 SF
                            2-78 XS1100 E Best bike Ever
                              • 9980
                              My MP tool doesn't look like either one of those.
                              Originally posted by Rasputin
                              Kinda like the one on top but the angle of the tip is different.
                              • Rasputin
                                • 3189
                                #45
                                My Mp one says ... MP above the numbers 08-0020. Is yours different?
                                2-79 XS1100 SF
