Valve Adjustment Pictorial
  • JasonRedbeard
    • 109
    • Tuscaloosa, AL
    Beautiful write-up, Steve. The only thing I'd change is to add a note on the CCT adjustment to the end of it. I haven't done the shims on my bike yet, but it seems like that will be a critical step of the reassembly.
    And Phil....my 5-year-old saw that pic and laughed his butt off.
    My Special is as old as I am.
    • xssiveone
      • 766
      • Windsor,Ontario,Canada
      So.... who's going to post the picture tutorial with the MP tool?
      Actually, I did one about 12 years ago. Haven't been active here for a long time but have been dropping in lately to have a peek around. Glad to see this forum is still going strong.
      The web page I did needs updating, but I'm not sure I remember the password. Everything is there, but it's a bit of a mess.
      XSsiveone valve adjust
      Brian
      remembering the same thing!
        I have used the tool, it works. And it is a good choice if your changing one or two shims. IMO, if your changing out more than that, then for time purposes, I would use one method or another of the cam methods.
        Not against the tool, just my experiences.
          • 8962
          The kid's got a good sense of humor...
            #35
            Originally posted by xssiveone
            Yep, there's another one of those ground-on-to-make-fit MP tools....
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              • Fort Myers, Florida
              #36
              Special
              WOW, not only is my bike "Special" but I must be "Special" too. Am I the only one who can use this tool right out of the box on all 8 valves with no mods or problems
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                • 2104
                Almost the same...
                ...as our Elevens, but IMHO some good info and pics for those that have never done the job yet. Actually I did both my XS11 and XJ750 at the same time and swapped shims around on both engines as they are the same diameter
                http://xjbikes.com/Forums/viewtopic/t=14827.html
                http://xjbikes.com/Forums/viewtopic/t=29209.html
                HTH
                  +1 I must be Special too.
                    Well, it looks like at the end of the season I'll be replacing all of the shims AND the cam chain. So, I probably won't find out if I'm "special".
                      I was just reading your cam chain post Marty. Before you go ordering a new chain, check and make sure all the sliders are OK. As in not XSively worn or broken. JAT
                      Those roller chains aren't really prone to wear. I replaced a timing chain in a Mazda V6 just the other day and the chain was the same as what's in our engines, just longer. The chain was actually fine, the tensioner had gone south.
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        #41
                        Tool
                        Not that special my tools worked out of box also. I think that it can be tuff to get the tool into position on some valves but if you take care its better than pulling the cams for most people. I agree that if you are in a situation where you have multiple valves to get set the cam pull works but in a one or two adjustment I would not use the cam pull method.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        Barnett Clutch Springs
                        R1 Clutch Fiber Plates
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                          How do I check the sliders? If they are bad, the cam chain damper is NLA. has anyone here come up with a trick to repair it? Does the engine have to be disassembled to remove and replace it? Will my engine be making a lot of noise if the plastic material is gone?
                          I'm going to move this over to the cam chain wear post as well.
                            • 3193
                            #43
                            Just gor giggles
                            I went out to the man cave and got my Yamaha shim tool and my MP shim tool out. I tried both on a head I have lying about. Both will work but the MP is quite a bit harder to use. I got to comparing the two and thought you all may like to see what I found. Here is a pic of the two side by side in a vice. Sorry the pic is not clearer but I am not much of a photographer. This may explain why so many have to grind the MP tool. The Mp tool is the top and blackest one. I had never tried the MP one before today and it was a suprise that it sucked so badly.
                              My MP tool doesn't look like either one of those.
                              Originally posted by Rasputin
                              Kinda like the one on top but the angle of the tip is different.
                                • 3193
                                #45
                                My Mp one says ... MP above the numbers 08-0020. Is yours different?
