Valve Adjustment Pictorial
    With all this talk about valve adjusting and being in the middle of doing just that on my current project bike, I decided to post a 'how-to' on the 'cam removal' method. I'll note that it's very important that the bike/motor be level side-to-side. So, without further ado, here it is...
    [IMG][/IMG]
    First things first; check and record your clearances for all valves. Remove the cam and timing covers and rotate the motor clockwise while checking each valve. I use a go/no go set of feeler gauges, really handy...
    [IMG][/IMG]
    Once you've got all the measurements, turn the crankshaft (always clockwise) until the pointer is on the 'T'.
    [IMG][/IMG]
    Do you see these 'dots' on the cams? If you do, they both should line up with the marks on the cam caps, and then turn the crankshaft around one more time (so you can't see them)...
    [IMG][/IMG]
    ...then remove these two cam sprocket bolts. Turn the crank once more (so you can see the dots again and they line up with the marks on the caps) and remove the other two bolts. Note the little 'points' by the second pair of bolt holes...
    [IMG][/IMG]
    ...as shown in close-up here. These holes must be on the same 'side' of the cam as the dots or your cam timing will be off. DO NOT turn the crankshaft again until you get to the end of the reassembly process!
    [IMG][/IMG]
    Remove the cam chain tensioner...
    [IMG][/IMG]
    ... which will give you slack so you can lift out the top chain guide. Lift/move the chain to one side and lift it out.
    [IMG][/IMG]
    Loosen/remove the cam caps, taking care not to just take them off, but to loosen them gradually so as to not 'cock' the cam as at least one lobe will be holding a valve open. Loosen the cap nuts on either side of those lobes about 1/4 turn at a time. Once you have the caps off, lift up and rotate the cam/sprocket until you can pull the cam out through the sprocket. TIP: use a magnet on/near the nuts/bolts so as not to lose any inside the motor; it really sucks trying to fish those out...
    [IMG][/IMG]
    You now have access to all the shims, simply pop them out. I use a knife edge, some use magnets (but I haven't had any luck with those, the oil 'stiction' is more than the magnet can overcome) to get them out.
    End of part 1.....
  • EricHa
    • Mar 2009
    • 201
    • IL
    Thanks Steve. I'm in the middle of shimming too, and I struggled with that Motion Pro piece of junk tool last night. I'm going to pull my carbs this weekend, and appreciate the tutorial!
    1979 Yamaha XS1100SF (gone)
    Airbox w/K&N element
    Jardine 4 into 1
    145 mains, 45 pilots
    1996 Ducati 900SS CR
    1977 Kawasaki KZ900-A5
    1975 Honda CB550K
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Thanks Steve !
      I didn't know about those mark near the cam bolts.
      When I put all mine back together, the dots did line up, but now I think I'll take the valve cover off again and check to make sure those marks on the cam sprockets indeed line up with the timing marks/dots.
      (Maybe I just got lucky and they are lined up correctly)
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        Part 2
        Check the shim size, which should be etched on the 'bottom' side. To determine your new shim size, check your recorded clearance. I use 'inch' feeler gauges as I've found it's much simpler to calculate shim changes.
        Now in this case, all the valves were good except for the two inner intake valves (so I'm not pulling the exhaust cam), both of which are .004". Each shim size difference is .002", and as I want the upper end of the early spec (.008"), I need to go two sizes thinner. Both valves have 270 shims installed, so I'm going to use 260 shims for replacement.
        As a side note, I suspect that whoever adjusted these last had a hard time getting to these (the two hardest to work in the bike with the motion-pro tool) so they just skipped them. I'll also note that I'm doing this with the motor on a stand so it's a bit easier, but it's not that much tougher in the bike.
        Once you have all the shims replaced/moved to get your calculated clearance, assembly is pretty much the reverse with a few exceptions and things to check. First, lay the cams in so the dots will line up with the caps, although if the dots are a bit to the 'rear' of the cam marks that will help with getting the sprockets on. Once you get the cam caps reinstalled and torqued (again, tighten gradually) and are installing the sprockets back on the cams, make sure the cam chain is properly on the crankshaft sprocket and that the holes in the cam sprockets line up right. If you need to turn the cams slightly to line up the sprocket bolts, do so; don't turn the crank. Install the first two cam sprocket bolts (don't tighten them yet), then install the cam chain tensioner; this is so you can rotate the motor to get to the other two cam sprocket bolts without worrying about the chain jumping. Double-check your cam timing at this time; after rotating it once, make sure the cam dots line up with the caps when the timing pointer is at 'T'. If everything's good, final torque all the bolts, doublecheck to make sure your clearances ended up where you want them, and reassemble the rest...
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          Nice work, steve. I would suggest to anyone new at this, only because it gives me more piece of mind...to tape a magnet to your socket when removing the cam cap nuts / washers and stuff a rag in the tunnel. I know there are magnetic sockets and insert magnets for sockets, but I've never quite gotten around to gettin a set of those
            I should have mentioned that.... good catch. I actually do use a magnet so as not to lose anything, particularly those washers under the cam cap nuts.
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              • Fort Myers, Florida
              MP tool
              Not to do anouther step by step on the MP tool (did one a while back for someone here) The thing most people have a problem with is they turn the cam lob all the way down on the tapet, then try to install the tool, it won't fit that way. If you turn the cam till the valve just starts to open, then slide in the tool, then turn the cam alittle more if needed til it just goes in place, put in the bolt and turn the cam back, the tool works fine
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                The MotionPro tool seems to be a love it/hate it deal.. And one issue with them is the quality control on them seems to be pretty uneven, as more than a few have reported having to do some grinding on them to get them to fit. I've got one, and that's what it needs before it'll fit...
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Here is the one I use
                  No grinding needed. Anouther way to discribe how to uss it without mods to the tool. Turn the came lobe all the way down. Slip the tool in to place as far as you can, turn the cam lobe away from the tool slowly while pushing the tool into place, it WILL drop into place when the lobe is far enough away from the tool. Tighten the bolt, turn the cam more, R/I shim, turn back till the tapet just starts to move down, remove tool The 1st time I used it it took me 2 hours till I figured out it wont go in if the valve is even half way open The 2nd time, knowing how to use it, it took me about 1/2 hour
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    Both methods have their pros/cons; if you know what size shims are in there before starting the adjustment and/or have a full set of them available (like a dealer would, or at least used to when the bikes were newer), then the MP tool is probably a bit faster method. Also faster if you only have one or two valves that need adjustment.
                    But if you're doing an adjustment on a motor where the shim sizes are all unknown and the majority of the valves need adjustment, the cam removal method lets you see them all at once. A lot of times you can simply shift them around and only need to buy a few. Pulling the cams also lets you take a look at the cam bearing journals and check the cams for wear.
                    With the MP tool, you'll need to remove/replace each shim just to find out what you have before you can figure out what you need if you need to buy some, so you'll end up doing them twice. You also have the possiblity of breaking the head if you boo-boo and turn a cam the wrong way and contact the tool.
                    Like I said, both have their points...
                    • DAVINCI
                      • Jan 2011
                      • 1048
                      I hate that f-in tool more than I hate my ex-wife.
                      • dpotter58
                        • Aug 2004
                        • 1865
                        • Southern Maryland
                        So are you going to make it a sticky in the maintenance section?
                        1980 LG
                        1981 LH
                          Not me, a plain ol' 'mod' ain't got the HP for that... That's for a Admin...
                          I'll add that if there's anything anybody thinks I missed, post it and I'll 'edit' it in...
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            6 of 8
                            I adjusted 6 of 8 in about 1/2 hour with not knowing what the current shims were and a starter set of shims
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • petejw
                              • 2269
                              • sydney australia
                              depending on the number of shims that need replacing
                              theres no real need to remove the cams or the tensioner,
                              u can loosen the cam with the tensioner in place, that way
                              theres no possibility of the chain slipping off the crank,
                              if the chain is tight then the lock bolt can be loosened and the
                              chain will still have the spring tension from the cct on it to prevent slippage.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              1981 xs1100 RH (aus) (5N5)
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
