Valve Adjustment Pictorial
    Interesting......I would like to know what the difference is.
      #62
      Greg, these things look to be sand-cast, and all I can figure is their quality control on the molds isn't too good...
      • Titans
        • Mar 2010
        • 24
        #63
        Quick questiong guys if I may
        I still cant figure out why, as the engine wears, the valve clearance decreases?
        • tcoop
          • Nov 2009
          • 793
          • South Weber, UT
          #64
          As you run the engine the valve slams against the seat, each time it wears on the seat going in a little more each time. In turn it raises the bucket a little more which closes the gap between the lobe and the shim.
          Ty
          78 XS1100E - Now in Minnesota
          80 XS1100LG - The Punisher
          82 XJ1100 - Daughter's Bike
          • andylawcc
            • Dec 2012
            • 49
            • Los Angeles, CA.
            #65
            i have a question about measuring the gap.
            In the beginning, I measured the gap whenever the pointy part of the lobe isn't touching the shim. So, for some valves, the pointy part is facing exactly opposite away from the valve (so, 180 degrees), while some are just facing "90 degrees away." Then I did my calculation and replaced with new shims. Now, after the replacement, i re-measured and found out quite a few valves didn't come out as expected / within spec, i double checked the math and it still didn't make sense.
            So, after fiddling a while, I find out the lobe has tighter clearance when it is just pass touching the valve shim, and the clearance/gap increases as i turn the crankcraft and the pointy part is "180 degree away." The gap then reduces as it is pass the 180 degree spot, and getting closer back to touching the valve shim.
            So I suppose the fatter side of the lobe is not a perfect circle then?
            and I should use the LARGEST clearance number as base right?
            79 XS11
              #66
              Correct, the cam lobe is not circular until it gets elongated. And yes, you want to measure the clearance when the gap is the largest, or with the lobe at 180 deg from the valve. You do not need to be overly fussy about being EXACTLY 180. But you do want it to be close.
              • andylawcc
                • Dec 2012
                • 49
                • Los Angeles, CA.
                #67
                thanks again DGXSER...
                79 XS11
                • Petersg_99
                  • Apr 2012
                  • 184
                  • Phoenix, AZ.
                  #68
                  If I get a new valve cover gasket, can you remove and reinstall the valve cover multiple times, or is the valve cover gasket only good for 1 or 2 times?
                  What about the camshaft plugs? Do they need to be replaced when you pull the valve cover?
                  Guy
                  1980 XS1100G - Frankenstein - resurrected from the impound lot
                  1991 Suzuki GS500E (not running yet)
                  2003 Burgman AN400 - Blue Belle
                  2005 Burgman AN400 - Silver Belle
                    #69
                    Could use rtv and not waste time with the gasket. Cam plugs can just stay there. Don't remove them, if you do put a good layer of rtv on them before reinstal.
                      • 8962
                      If you spray the new gasket with Pam cooking spray, you can remove it and use it over again. The cam plugs can be re-used, just put a bead of RTV around all edges when installing. I myself just use RTV and no gasket.
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        • Virginia Beach, VA.
                        #71
                        The camshaft plugs should be good for years. (as long as they don't get damaged/nicked, etc.)
                        Some/most don't use a valve cover gasket, they use yamabond or some other RTV that they like.
                        I've reused my gasket quite a few times, but the hard spot with that is the gasket gets brittle and may break, thus creating a leak at that location.
                        80G (Green paint(PO idea))
                        The Green Monster
                        Got him in '04.
                        bald tire & borrowing parts
                        Scarlet
                        Got her in '11
                        Ready for the twisties!
                        81H (previously CPMaynard's)
                        Hugo
                        Cold weather ride
                        • mack
                          • 2411
                          • Ontario, Canada
                          #72
                          Pam
                          Pam's the way to go if your not using RTV. You'll probaly never have to buy another gasket as long as your careful about hooking them on something while removing them.
                          mack
                          79 XS 1100 SF Special
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          https://youtu.be/wB5Jfbp6SUc
                          https://youtu.be/RaI3WYHSuWA
                          Frankford, Ont, Canada
                          613-398-6186
                            • 8962
                            Yep, and the engine smells like a pizza parlor for a few hundred miles, lol.
                            • LoHo
                              • Sep 2002
                              • 1342
                              • Fresno, CA
                              #74
                              Are the little tabs on the sprocket bolt holes mentioned in Clymer's? I noticed them, but didn't know their importance...now I have to go check, dammit!
                              • old_chopper
                                • Sep 2010
                                • 120
                                • Oklahoma
                                #75
                                Since we've officially hijacked the thread...I use a doubled over zip tie to slightly hold the valve open then pull the shim. I feed the zip tie thru the spark plug hole between the open valve and seat and rotate the engine to close the valve. Costs about 25 cents and is super easy. I've used this method on Suzuki GS (8 valve) and my XS.
                                US Army 1986-1991
                                1979 1100 Special (on the road after 16 years!)
                                1983 GS300L (wifes ride)
                                1985 Super Glide
                                2012 Super Glide
