Cleaning pistons and Valves
  • petejw
    • 2269
    • sydney australia
    #76
    Tod, I didnt think you were being arguementive,
    i think its been a interesting topic to discuss/debate. :-)
    Austin. Dont. :-)
    if ur using an angle grinder with a wire wheel to remove the gasket, dont go pressing to heavily, if it grabs it could muck up the mating surface on the alloy, otherwise it should be fine.
    with the stator i think you might b able to connect an ohm meter to the wires to tell if they havent corroded thru, i cant find my manual so not sure what readings would be.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      You expect a one word answer from me?? lol. Silly new guy.
      The cross hatch is still there. DON'T.
      • renegade_xs11g
        • 462
        • Mid-Michigan
        #78
        Gasket Sraping....use a razor blade or gasket scraper, putty knife, then a wire wheel or brush....anything but a grinding wheel
        Can't tell you on the debated issue of the carbon ring
        I've never put a motor back together, without having a machine shop do the valves or jugs....so I've always gotten them back clean, and used new rings bearings etc.....
        completly new to the concept of just putting an engine back together
        My Photo Bucket
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          #79
          3m makes little buffer pads about an inch big. Kinda look like a brillo pad but it goes on a die grinder. you know the little air tool. im not going to use a big huge grinder but i always use this little finisher wheel on all the cars i work on to clean the surface. Ya know what im talking bout?
          Austin Ingalls
          MIDNIGHT FURY
          XJ maxim rear air shocks
          KERKER 4-into-1 exhaust
          Pod Filters
          Money pit.......
          BLACKED OUT
          • renegade_xs11g
            • 462
            • Mid-Michigan
            #80
            Yep, I sure do....those will do the job well
            My Photo Bucket
            • Rasputin
              • 3189
              • Lacombe, Alberta, Canada
              #81
              Yup. I use them little 3M pads lots. Just dont go to wild with the coarseness on them pads. I have used them loads on aluminum parts and they work fine.
              2-79 XS1100 SF
              2-78 XS1100 E Best bike Ever
              • kirmit77
                • Mar 2009
                • 464
                • Kingwood, TX
                #82
                sounds good.
                Going to go and glass bead blast some of the stuff today out at the hangar. Gotta clean alot of stuff.
                Austin Ingalls
                MIDNIGHT FURY
                Pod Filters
                Money pit.......
                BLACKED OUT
                • kirmit77
                  • Mar 2009
                  • 464
                  • Kingwood, TX
                  #83
                  Today
                  I cleaned alot of stuff.... but the corrosion on the covers is pretty bad. What is the best way to clean the covers?? also the cylinders???
                  Austin Ingalls
                  MIDNIGHT FURY
                  Pod Filters
                  Money pit.......
                  BLACKED OUT
                    • 8800
                    A few ways... Soft brass wire wheel, fine grit sandpaper with Mothers polish, an old timers trick, don't laugh, coca-cola and tin foil. Happy birthday bro.
                    • kirmit77
                      • Mar 2009
                      • 464
                      • Kingwood, TX
                      #85
                      being 20
                      doesnt feel different. Well i have to go out of town tomorrow but ill try those ways on thrusday. I think i want to paint the engine black and do a blacked out bike! Frame is stripped and will be painted on thursday so i might accidentally paint everything else
                      inquires welcome
                      Austin Ingalls
                      MIDNIGHT FURY
                      Pod Filters
                      Money pit.......
                      BLACKED OUT
                        #86
                        inquires welcome
                        I gotta say, the best bike look is the one you like. They all can look good, and real pity is when someone does a BAD chop job to a rare or classic bike, but a good quality chop while not something I would personally do, is something I can certainly drool over.
                        • kirmit77
                          • Mar 2009
                          • 464
                          • Kingwood, TX
                          #87
                          no chop
                          no choppin for me... just gunna get a drag bar and black it out most likely.. I dunno. Ill paint the frame tomorrow and go from there.
                          Austin Ingalls
                          MIDNIGHT FURY
                          Pod Filters
                          Money pit.......
                          BLACKED OUT
                          • kirmit77
                            • Mar 2009
                            • 464
                            • Kingwood, TX
                            #88
                            AHHHHH this is no good.....
                            found some scratches in the cylinder wall!!! CRAP!!!! so it looks like ill have to bore it or something... I NEED HELP!! did not expect this.... how much are big bore kits???
                            Austin Ingalls
                            MIDNIGHT FURY
                            Pod Filters
                            Money pit.......
                            BLACKED OUT
                              #89
                              Check with Andreas, he likely has some good jugs (the kind on the bike not the others ) for sale. It might be cheaper to do that than the big bore kit, then again, then you would have an XS12.
                              • kirmit77
                                • Mar 2009
                                • 464
                                • Kingwood, TX
                                #90
                                ill check....
                                but where could i find a good big bore??????
                                Austin Ingalls
                                MIDNIGHT FURY
                                Pod Filters
                                Money pit.......
                                BLACKED OUT
