I agree that you can be proud on the job you will have done when you get this bike running. At any age being able to recover an old machine to good running order is a worthwhile endeavor. For me i enjoy the turning of wrenches almost as much as I like riding the finished product. If cash is not a big issue i would take the time to do it right the first time round. If all the parts are with in spec give the cylinders a light hone and go with the new rings. Get the hear sorted out and you will be able to conceder that part of the engine a "done deal" You will not want to do it twice unless your like me and don't mind twisting wrenches. For me there is no time factor because I have 2 other bikes here that I can use.
Rob
Rob
in fact, on a standard car engine, I always pull the pistons out the top so you have to remove the ring to get them out. So it must not be the end of the oil seal in a car engine. I fail to see how the bike engine is different in this regard.
My Rotor has a nice little layer of rust on it as well. The ALT and charging system on the XS11 is a brushless one, that means that nothing touches against other moving parts. That big rusty ROTOR just spins in between the field coil and the stator coil. So....as long as there's no signs of rubbing on the stator coils or field coils, then you can remove the rust from the ROTOR anyway you want, but a simple wire wheel or brush will be enough.
