Wiseco makes 'em.
Cleaning pistons and Valves
Search for a post from Dan Hodges, he unveiled his master secret specialist that makes pistons. Wiseco stuff just went through the roof on pricing, and Dan suggested that the specialty shop may be cheaper.Ich habe dich nicht gefragt.Comment
rebore
looks like terminology/country barrier going on,but you guys seem to have nutted it out.have been on the road all week so am just reading all this now.
a couple of things,TopCat siad about valve paste,there is a COURSE and a FINE, use in this order for a proper job, down here they,re in the same tube,[either end]
if your going to get oversize pistons,take all 4 to your machinist numbered 1-4 and have him individually machine each JUG. having spent 3 1/2-4 yrs & $5300 rebuilding mine if your going to do it, do it right, do it with care/pride after all it will be YOUR bike
to maybe throw in another tailspin with all that rust on your stator, check to see if your rotor still has magnet pull, use a screwdriver, being magnetic between two fields is where you get charge fromnever ride faster than your gaurdian angel
can fly
1981 rh 5N5
MIDNIGHTSPECIAL
1188cc
4 into 1 pipes with a transac muffler,
as the motorcycling gods intended everything else stock std
http://s856.photobucket.com/home/steptoexs11
http://steptoexs11.webs.com/
http://www.youtube.com/my_videos?feature=mhum
1982 vf750 sabreComment
what to do....
I really dont have the money for that big bore kit, what to do, what to do.....
WHAT YALL THINK!?!?!?Austin Ingalls
MIDNIGHT FURY
1979 XS1100 Special [Full Restore Project]
XJ maxim rear air shocks
KERKER 4-into-1 exhaust
Pod Filters
Money pit.......
BLACKED OUTComment
i did
$100 For pistons jugs and retainers and i think pins
I sent my frame to a sandblaster and a powdercoater so hopefully it will all be back pretty soon!
$215 for blasting and gloss black coatingAustin Ingalls
MIDNIGHT FURY
Pod Filters
Money pit.......
BLACKED OUTComment
so much cleaning.....
i got all of the valves out with a Rigged C-clamp. using the dremel to clean up everything and got some valves soaking in chem dip. i bought the complete gasket set from partsnmore and thats that. everything is coming along good except i need a new tank and fuel level unit
no bueno. anyways its coming along just taking time...
Austin Ingalls
MIDNIGHT FURY
Pod Filters
Money pit.......
BLACKED OUTComment
I used a deep socket and a hammer to get valves out. Just tap the socket on the end of the spring cap and the keepers will come out. Wish it was that easy to put them back in.
Also with the recessed valve springs, a normal spring compressor doesn't cut it. Your rigged C clamp is probably far better than my craftsman valve spring compressor. I'm jealous...
Sorry, is your scoot a standard or a special? I have an extra tank off a special that has a sender unit. If its that important to you, we can work a deal. My special the light don't work until after I hit reserve anyway. I just use the trip meter and lots of luck.....Ich habe dich nicht gefragt.Comment
79 special
i just bought a sending unit for 20 dollars on ebay and i might have a tank from ebay for around 30ish? PM me if you can make me a better deal but i thought thats pretty good?Austin Ingalls
MIDNIGHT FURY
Pod Filters
Money pit.......
BLACKED OUTComment
Cleaning the pipes
What would be the best way to clean the pipes so i could paint them black?? they WERE chrome but now its all nastyfied and rusted. How do you get the chrome off?
ThanksAustin Ingalls
MIDNIGHT FURY
Pod Filters
Money pit.......
BLACKED OUTComment
recomendation
What kind of paint?? rattle can engine paint? Also what kind of paint should i use on the actual engine and covers?? also what would I primer?!?!?!?
THANKS!Austin Ingalls
MIDNIGHT FURY
Pod Filters
Money pit.......
BLACKED OUTComment
For the engine, start with cleaning down to bare aluminum. Use the "self etching"primer, and then a good engine paint. ( 350 to 500 degree).Also what kind of paint should i use on the actual engine and covers?? also what would I primer?!?!?!?
The headers will take a HIGH HEAT paint. a 1500 degree is best, but 1200 degree should work. READ THE INSTRUCTIONS BEFORE PAINTING!!! If it says you need to "bake" the paint, DO NOT PAINT IT UNTIL THE ENGINE IS READY TO RUN! Then paint, install, and runt for about 10 minutes to start the bake. Cool for about 1/2 hour, and repeat the run. Cool for 1/2 hour and then run for 20 minutes. If you do NOT do this, the paint may not hold up.
All this paint is available in rattle can.Ray Matteis
XS1100 SF Bob Jones worked on it!Comment
cleaning....
cleaning this bike SUCKS!!! there is SO MUCH dirt EVERYWHERE!!! i have been getting after it with my dremel and a vacuum. very time consuming but i gotta do it!
I think Im just going to paint the covers. Seems like Painting the engine would be a big hassle right now. When painting the covers do i still need a primer?
thanks AGAIN... like always
AustinAustin Ingalls
MIDNIGHT FURY
Pod Filters
Money pit.......
BLACKED OUTComment
