Cleaning pistons and Valves
    • 8893
    Wiseco makes 'em.
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      #92
      Search for a post from Dan Hodges, he unveiled his master secret specialist that makes pistons. Wiseco stuff just went through the roof on pricing, and Dan suggested that the specialty shop may be cheaper.
      Ich habe dich nicht gefragt.
      • Steptoe
        • 175
        • Thabeban,Bundaberg QLD , Australia
        #93
        rebore
        looks like terminology/country barrier going on,but you guys seem to have nutted it out.have been on the road all week so am just reading all this now.
        a couple of things,TopCat siad about valve paste,there is a COURSE and a FINE, use in this order for a proper job, down here they,re in the same tube,[either end]
        if your going to get oversize pistons,take all 4 to your machinist numbered 1-4 and have him individually machine each JUG. having spent 3 1/2-4 yrs & $5300 rebuilding mine if your going to do it, do it right, do it with care/pride after all it will be YOUR bike
        to maybe throw in another tailspin with all that rust on your stator, check to see if your rotor still has magnet pull, use a screwdriver, being magnetic between two fields is where you get charge from
        never ride faster than your gaurdian angel
        can fly
        1981 rh 5N5
        MIDNIGHTSPECIAL
        1188cc
        4 into 1 pipes with a transac muffler,
        as the motorcycling gods intended everything else stock std
        http://s856.photobucket.com/home/steptoexs11
        http://steptoexs11.webs.com/
        http://www.youtube.com/my_videos?feature=mhum
        1982 vf750 sabre
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          #94
          what to do....
          I really dont have the money for that big bore kit, what to do, what to do.....
          WHAT YALL THINK!?!?!?
          Austin Ingalls
          MIDNIGHT FURY
          XJ maxim rear air shocks
          KERKER 4-into-1 exhaust
          Pod Filters
          Money pit.......
          BLACKED OUT
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            #95
            andreasweiss is a forum user that salvages these bikes. see what he has for a set of pistons rings and a cylinder block. If you,re lucky, you could get a matched set that would be more or less a bolt on.
            • kirmit77
              • Mar 2009
              • 464
              • Kingwood, TX
              #96
              i did
              $100 For pistons jugs and retainers and i think pins
              I sent my frame to a sandblaster and a powdercoater so hopefully it will all be back pretty soon!
              $215 for blasting and gloss black coating
              Austin Ingalls
              MIDNIGHT FURY
              Pod Filters
              Money pit.......
              BLACKED OUT
              • kirmit77
                • Mar 2009
                • 464
                • Kingwood, TX
                #97
                so much cleaning.....
                i got all of the valves out with a Rigged C-clamp. using the dremel to clean up everything and got some valves soaking in chem dip. i bought the complete gasket set from partsnmore and thats that. everything is coming along good except i need a new tank and fuel level unit no bueno. anyways its coming along just taking time...
                Austin Ingalls
                MIDNIGHT FURY
                Pod Filters
                Money pit.......
                BLACKED OUT
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  #98
                  I used a deep socket and a hammer to get valves out. Just tap the socket on the end of the spring cap and the keepers will come out. Wish it was that easy to put them back in. Also with the recessed valve springs, a normal spring compressor doesn't cut it. Your rigged C clamp is probably far better than my craftsman valve spring compressor. I'm jealous...
                  Sorry, is your scoot a standard or a special? I have an extra tank off a special that has a sender unit. If its that important to you, we can work a deal. My special the light don't work until after I hit reserve anyway. I just use the trip meter and lots of luck.....
                  • kirmit77
                    • Mar 2009
                    • 464
                    • Kingwood, TX
                    #99
                    79 special
                    i just bought a sending unit for 20 dollars on ebay and i might have a tank from ebay for around 30ish? PM me if you can make me a better deal but i thought thats pretty good?
                    Austin Ingalls
                    MIDNIGHT FURY
                    Pod Filters
                    Money pit.......
                    BLACKED OUT
                    • kirmit77
                      • Mar 2009
                      • 464
                      • Kingwood, TX
                      #100
                      Cleaning the pipes
                      What would be the best way to clean the pipes so i could paint them black?? they WERE chrome but now its all nastyfied and rusted. How do you get the chrome off?
                      Thanks
                      Austin Ingalls
                      MIDNIGHT FURY
                      Pod Filters
                      Money pit.......
                      BLACKED OUT
                      • tarzan
                        • 1700
                        • Chandler,Az.
                        #101
                        you should be able to sandblast the pipes.Then paint them
                        80 SG XS1100
                        14 Victory Cross Country
                        • kirmit77
                          • Mar 2009
                          • 464
                          • Kingwood, TX
                          #102
                          recomendation
                          What kind of paint?? rattle can engine paint? Also what kind of paint should i use on the actual engine and covers?? also what would I primer?!?!?!?
                          THANKS!
                          Austin Ingalls
                          MIDNIGHT FURY
                          Pod Filters
                          Money pit.......
                          BLACKED OUT
                          • tarzan
                            • 1700
                            • Chandler,Az.
                            #103
                            You need to use high heat paint.Your exhaust gets up to 1000 degrees from what Ive read.
                            I also saw in another post that you can get high heat powder coating
                            80 SG XS1100
                              • 7819
                              For the engine, start with cleaning down to bare aluminum. Use the "self etching"primer, and then a good engine paint. ( 350 to 500 degree).
                              The headers will take a HIGH HEAT paint. a 1500 degree is best, but 1200 degree should work. READ THE INSTRUCTIONS BEFORE PAINTING!!! If it says you need to "bake" the paint, DO NOT PAINT IT UNTIL THE ENGINE IS READY TO RUN! Then paint, install, and runt for about 10 minutes to start the bake. Cool for about 1/2 hour, and repeat the run. Cool for 1/2 hour and then run for 20 minutes. If you do NOT do this, the paint may not hold up.
                              All this paint is available in rattle can.
                              • kirmit77
                                • Mar 2009
                                • 464
                                • Kingwood, TX
                                #105
                                cleaning....
                                cleaning this bike SUCKS!!! there is SO MUCH dirt EVERYWHERE!!! i have been getting after it with my dremel and a vacuum. very time consuming but i gotta do it!
                                I think Im just going to paint the covers. Seems like Painting the engine would be a big hassle right now. When painting the covers do i still need a primer?
                                thanks AGAIN... like always
                                Austin
                                Austin Ingalls
                                MIDNIGHT FURY
                                Pod Filters
                                Money pit.......
                                BLACKED OUT
