Cleaning pistons and Valves
  • tarzan
    • 1700
    • Chandler,Az.
    If everything looks ok You should be fine.Its hard to tell from the pics but it looks like the cylinders dont have much wear,is that the case?I would lightly hone the cylinders and put it back together.
    80 SG XS1100
    14 Victory Cross Country
    • kirmit77
      • Mar 2009
      • 464
      • Kingwood, TX
      everything looks pretty good and i did plan on honing it just enough. ill take some more detail pics of the cylinders but to me they look good. no scarring or scratches just the top is really dirty
      Austin Ingalls
      MIDNIGHT FURY
      1979 XS1100 Special [Full Restore Project]
      XJ maxim rear air shocks
      KERKER 4-into-1 exhaust
      Pod Filters
      Money pit.......
      BLACKED OUT
        Wow...
        Sorry I missed that.
        Throw a very light hone onto the cylinders and throw it back together if you think that's the true mileage. You won't need rings.. unless that's 109,800. If the valves are as nasty as you say though.. that may be more correct. I can't see them getting too jacked up in 10k miles, no matter how rich it was running.
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          well....
          its been sitting since 1985 and i know the full story and the owner and that is the exact miles. ill try doing a light hone on sunday and slapping it all back together! hope to get it running soon but cant find anyone around here that has a friggin C-clamp style valve spring compressor..... o well ill keep lookin.
          Austin Ingalls
          MIDNIGHT FURY
          Pod Filters
          Money pit.......
          BLACKED OUT
          • kirmit77
            • Mar 2009
            • 464
            • Kingwood, TX
            what is everyones take on this ???
            What does everyone think about these Viton valve seals??
            i just need the seals and then i can get to gettin on the rebuild
            Austin Ingalls
            MIDNIGHT FURY
            Pod Filters
            Money pit.......
            BLACKED OUT
              You can ease the top ring off of the pistons and slip them down into the cylinders so they are sitting just like if they were on the piston (Horizontally). You then take some feeler gauges to check the gap between the ends of the ring. Standard gap is .2-.4mm (.008-.016") with a limit of 1.0mm (0.039")
              More than likely, if the top ones are ok, the rest will be also. Be careful getting the rings off though since they will be pretty brittle.
                Hey Kirmit,
                You can make your own with a regular C clamp, get some PVC pipe, cut a nice slot in it about 120 degrees worth, leaving enough space to have access to the keepers, but not so much of a gap that the pipe section would slip/tilt. Use the solid part of the "C" clamp on the valve heads, and use the screw end on the spring end with the pipe. Check out the tech tips for photos on this. Like it's been said, most have done just about everything before, just need to look or ask!
                PS, you haven't said, but hopefully you're going to LAP your valves once you've cleaned the hard carbon off of them!?
                • kirmit77
                  • Mar 2009
                  • 464
                  • Kingwood, TX
                  next questoin
                  What is the procedure on lapping?
                  Austin Ingalls
                  MIDNIGHT FURY
                  Pod Filters
                  Money pit.......
                  BLACKED OUT
                    You get a fancy little double suction cup wooden device (Lapping Tool), and a tube of lapping compound, put a nice thin layer of compound around/onto the sealing surface of the valve, slide it into the head, and then use the suction cup to grap the valve head, and spin and press slightly against the valve/seat to GRIND the mating surface of the valve and seat. When done correctly, you then see a nice little gray line on the valve and seat, about 1/16" wide or so. When it's complete, no spots, gaps in the line, then you're done, clean the valve and seat thoroughly...you don't want that gritty compound getting into the rest of the engine.
                    This is the poor mans way of reconditioning the valve sealing surface instead of having the head and valves reground by a machine shop!
                    • kirmit77
                      • Mar 2009
                      • 464
                      • Kingwood, TX
                      sounds good
                      ill will be definitely do it. BUT... i need to know about the valve seals i have posted up a couple of post. any recommendations???
                      Austin Ingalls
                      MIDNIGHT FURY
                      Pod Filters
                      Money pit.......
                      BLACKED OUT
                        That's a good price, and they seem to be quality stuff. I paid $8.00 EA in 2000 for a set from YAMAHA since I didn't know better back then. You can get a complete gasket set for $80.00 from Partsnmore.com, and it comes with a set of valve seals also! What were you going to do about the head gasket?? OEM from Yamaha is also $80.00, you get that one in the kit also!
                        PS, just checked PNM, they have the individual valve seals for $2.00 ea!!!! I think MikesXS carries the lapping tool, but you can get that from your local auto store, even Walmart I think?
                        • petejw
                          • 2269
                          • sydney australia
                          hey Austin,
                          You can see if the valves are leaking by placing the head on its side and pouring petrol into each port, if theres no seeping/leaking your head's good to go, do this 4 both exhaust and intake valves.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          1981 xs1100 RH (aus) (5N5)
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • Ivan
                            • Jul 2008
                            • 2524
                            • Hutchinson KS
                            Valve seals are almost an afterthought. The old Chevy engines used to just use a small plastic "umbrella" that didn't even seal. It was merely a deflector. The tolerance on the valve guides is small enough that oil has a hard time getting passed there, and if it does, there is so little that you won't even notice it burning. The sign of leaking valve seals is a puff of blueish oil smoke on start up that goes away in a few seconds. Usually, on an automotive engine, something else will break before the leaking valve seals will cause a fouled plug.
                            All that is leading up to:
                            Valve seals are valve seals. Cheap ones work just as well as expensive ones. Viton isn't really necessary. They all work about the same.
                            Ich habe dich nicht gefragt.
                            • 79XS11F
                              • 3563
                              • Ottawa, Ont. Canada
                              I don't have my lens in so I have not read the whole threat but here's my input. On all three of the engines I have rebuilt I have cleaned the valves on course brass wire wheel on a beach mounted grinder. I use a hand held drill and wire wheel on the combustion chambers as well. Do it with the valves in place and avoid hitting the gasket surfaces.Tops of pistons were cleaned with a thick feeler gage followed by wire wheel. don't hit the sides of them so be careful. Combustion chambers were then buffed to a mirror like finish with a polish suitable for alloy. Once the valves and guides are cleaned with contact cleaner put the valves in place and check for any side play. There should be none with everything clean and dry. After the head is reassembled using assembly oil as necessary, in the turn it upside down on the bench and fill each combustion chamber with alcohol right to the gasket surface.Let it sit for several hours like that and see if any of the alcohol got past the valve seats. if so lap the valves of that cylinder and test again. If there is no leakage your good to go if all the springs were of correct length.
                              If theres no piston slap and the ring gaps were good you could reuse them but given that the engine is apart I would give the bores at least a quick light hone with a fine stone followed by using ether new stock size rings that have been gaped to spec or 1st. over size that have been gaped to spec. On the 1st. over size rings you would have a lot more filing to do to reduce them to the correct size but it can be done.
                              Rob
                              KEEP THE RUBBER SIDE DOWN
                              1978 XS1100E Modified
                              1978 XS500E
                              1979 XS1100F Restored
                              1981 Suzuki GS1100
                              1983 Suzuki GS750S Katana
                              1983 Honda CB900 Custom
                              • Steptoe
                                • 175
                                • Thabeban,Bundaberg QLD , Australia
                                white metal
                                g,day kermit, if your that far down in the motor check how much [they call it ] white metal is left in your gudgeon pin hole top of conrod,[little end] check for slop with your old pin as well,you,ll have some wear[diagonal in the hole] as long as its not square to the rod,[up and down] .worst comes to worst they can be re-metaled. as for the carbon go to your local auto store and buy a decarbonizing brush that fits in the end of your drill
                                never ride faster than your gaurdian angel
                                can fly
                                1981 rh 5N5
                                MIDNIGHTSPECIAL
                                1188cc
                                4 into 1 pipes with a transac muffler,
                                as the motorcycling gods intended everything else stock std
                                http://s856.photobucket.com/home/steptoexs11
                                http://steptoexs11.webs.com/
                                http://www.youtube.com/my_videos?feature=mhum
                                1982 vf750 sabre
