And so it begins ... Another bike building project
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    #196
    OK, The Kerker has been replaced with an RC Engineering pipe that looks far more suitable on the bike. I had to make and grind to size some collars for the keepers to catch and as can be seen, this pipe makes the bike a no passengers ride. The pipe interferes with the right side foot peg.
    Pics as usual.
    Rob
    DIY Keepers
    Much better looking set up.
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • MeatTooth
      • Apr 2009
      • 175
      • Tulsa, Oklahoma
      #197
      WOW I like that exhasut a lot!
      Tulsa, OK
      • 79XS11F
        • Jul 2006
        • 3563
        #198
        Yeah, It really fits nice and looks great eh. It also give easy access to the oil filter and oil drain bolt. I could even run with the main stand if I want to but it will not be necessary on this around town daily use red light racer :-)
        It came off an vintage racing XS11 so with some baffle packing and tuning the engine should sound sweet and run well.
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • 79XS11F
          • Jul 2006
          • 3563
          #199
          Micky mouse time
          So, in order to get this bike safetied, plated and insured for use next week I had to throw a few "Mickey Mouse" items at her. I have made a engine output sprocket cover and a chain guard as can be seen in the photos. They will have to do until the snow flies. If nothing else they can be used as templates for heavier better looking replacements. The chain guard will be mounted on alloy supports tomorrow morning before the lad drops by to do the safty.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • 79XS11F
            • Jul 2006
            • 3563
            #200
            If all goes well today and the weather does not change I will be applying 2 coats of gloss black nason fullthane 2K urethane to my bikes body parts. I have spent the last few days applying 3 coats of hand sanded primer to these parts and they are ready to go. The last reducer / dust removal will be done just a few minutes before th paint is applied. I will have to apply the paint outdoors due to the high volatility of the paint that is being applied. This paint will not require any clear coat to make it resistant to fuel and the finish, if I can get it applied properly, will have the look of several coats of Lacquer. If all goes well I should end up with a factory quality finish. I'll post some more photos when the paint is on it.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
              #201
              Good luck with the pain. Definitely would not be painting here today, way to humid here!
              Is that a oil pressure gauge down by the timing cover?
              ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
              • 79XS11F
                • Jul 2006
                • 3563
                #202
                Yes I am watching humidity levels here as well. I may however, have no other option other then to apply the paint and account for the humidity in the dry time between the first and second coat. This paint as I understand it will dry in higher then "perfect" humidity levels but added care will be required. In any case 20 minutes is the max time frame involved between coats because it is a 2 part mixed and reduced paint. In this city I would be waiting for a long long time if I wanted "perfect" conditions outdoors. Humidity is currently 73% with pressure rising so humidity may fall off somewhat as the day progresses.
                Yes that is an oil pressure gauge.
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                • 79XS11F
                  • Jul 2006
                  • 3563
                  #203
                  Well, thanks to being a resident of Ottawa, The swamp at the end of the Ottawa river, No painting could be done. The RH fell to 56% just before the Grey clouds rolled in. It feels too much like rain now to risk the painting job.
                  On another note i have found a nice little faring to stick on the front of this bike and you may want to check them out at this e-bay link. Price is pretty good and I have used this faring in the past. It worked well.
                  The black trimmed edge is the top edge of the windshield.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • Macamon
                    • Aug 2009
                    • 71
                    • Los Angeles
                    #204
                    But... It's square So much for us specials
                    "There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
                    Active: 1932 Ford Model A; XS1100SF (Just got 'er); XS1100SG; 2000 F250 Turbo Diesel; 2003 Ford Mustang
                    Broken: 1999 Kawi Vulcan 750; 1998 Triumph Trophy 1200
                    Gonners: XS1100SF (my first ride); '82 Honda CB900F (bored to 1123cc); '86 Kawasaki ZG1000
                    • 79XS11F
                      • Jul 2006
                      • 3563
                      #205
                      But they take an insert in the front that is much nicer then that opening that is seen in the photo. It's an adapter for round or square lights. He said he has only 2 round adapters left last time I checked them.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • 79XS11F
                        • Jul 2006
                        • 3563
                        #206
                        Here's what the adapter looks like. It fits right into the opening in the front and makes the faring look much nicer then is seen in the photo without the adapter in place. There's a round one shown in the instructions in the background of the photo. As per the listing the adapters are included along with mounting hardware.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • 79XS11F
                          • Jul 2006
                          • 3563
                          #207
                          I painted the body parts after work today and got a reasonable job. I will have some rubbing to do but all in all I am happy with the outcome at this point. Pin striping will be high shine silver to match the engine and other raw brushed alloy parts. I should be able to handle these parts tomorrow afternoon for a closer look at what sort of paint job it "really" is. Hopefully the amount of post painting work that is required will be minimal. Some pics as usual.
                          Full wet coat on the tail cowl
                          Full wet coat on the tank
                          Full wet coat on the side covers
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                            Those look really good! You're not actually going to, you know, like, put them on a motorcycle and actually ride it, like, outside and everything, are you?!
                            โ™ฌ
                            โ™ฌ
                            • slow mo
                              • 858
                              • ontario canada
                              #209
                              nice job 79xs
                              the tins came out great i,m surprised at the results members get with some thought and motivation,,super job ..ride safe ,,slow mo!
                              moemcnally@hotmail.com
                              i AM THE KING OF NOTHING
                                #210
                                Awesome paint work Rob! Looks slicker than greased owl...uhh...well..looks really smooth!!!
