And so it begins ... Another bike building project
Hey Rob,
You sure you're Canadian, I didn't hear any "eh's"?!
That machine sounds awesome, didn't know you were making a
MIDNIGHT SPECIAL!!!!
T.C.T. C. Gresham
Well, I wouldn't call it "sweet" just yet eh. I got a color tune it eh and re-sync it after that eh. OH, and the camera is like about 4 feet from the bike eh, not right at the exhaust pipe eh.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
Wow complete lack of accent for a bloke from up nort'!
That is a NICE sounded machine there Rob!!! Very sweet indeed!Life is what happens while your planning everything else!
78 XS750Comment
1978 XS500E
1981 Suzuki GS1100
I've been taking care of loose ends and other stuff including the dial-a-jet setup. Got the fuel petcocks changed out for know working units. So far so good on the all SS socket head hardware. She's really starting to look like a bike now.
Looking like a bike
pods and dial-a-jets
Closer look see
1978 XS500E
1981 Suzuki GS1100
Hey Rob,
Good to see your finally getting there,
looking very sweet,
whats the go with the dial a jet set up, remember reading a little bout it a while ago, have you used it b4?, whats involved in setting it up?pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
The last piece of the puzzle has been found and won on e-bay. I now have a small bikini café type fairing for this bike. And it's even made for the SQUARE headlight. Sored it for 29 bucks
1978 XS500E
1981 Suzuki GS1100
That's was just up the road from me Rob. It's going to look sharp on your bike. I'm looking for the same but for a round headlight.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
OK, So now that I have all my camping stuff packed into my new travel trailer :-)
I can see the garage floor and get back to work on this bike. Crap, all I need now is a chain, a chain guard and rear brake caliper support, a few hours work and she's Done. I will however not insure her until Oct when my insurance comes up for renewal. I will not insure both bikes at the same time. I hope to get a few runs in with her before the snow flies
1978 XS500E
1981 Suzuki GS1100
After a lot of fiddle farting around and measuring I have arranged the drive sprocket, spacers and rear wheel up to within about 1/8 of an inch. Of center. This will be the starting point. Because I centered the swing arm which is symmetrical I measured from the rim on both sides over to the swing arm and split the difference between the two measurements to determine the starting point. I have to shim the sprocket away from the wheel 11/32 of an inch for the sprockets to remain lined up while centering the wheel.
I will still need a few spacers to use on the brake side of the axle before I can tighten things up.
Question. Given that there is no internal spacer between the wheel bearing on the rear wheel, what would you think would be a good torque setting for the rear axle nut?
1978 XS500E
1981 Suzuki GS1100
