And so it begins ... Another bike building project
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    #121
    No, it's rarer that that. It's a 83 GS750SD Katana (Canadian version). Less then 200 were ever produced. It's my next project bike to restoration. It is however, exactly the same rolling chassis as the GS1100 with the smaller engine.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • Thee_oddball
      • Apr 2009
      • 87
      #122
      Rob
      ahhhh thats why i could not figure out the color (83,1100 were blue and white) , very nice find!!
      1982 XJ1100J MAX ,25.000 miles
      • petejw
        • 2269
        • sydney australia
        #123
        Hey Rob,
        Looking really good,
        hang the parts in the oven, once they heat up the
        paints becomes soft prior to drying hard.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • 79XS11F
          • 3563
          #124
          Well, the wheels will not fit into the oven with the door closed so I baked the rear wheel for 2 hours with the door closed as much as it would go. The front wheel is in there now with the door open even wider. If nothing else, at least the paint will be dry and hand-able without doing damage to the coating. All the other parts will fit in OK They will go in the oven in about an hour and a half.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • Big Daddy Funk
            • 639
            • Brantford, Ontario, Canada.
            #125
            Very Rare Bird
            That Katana is a rare bike and from what I could see, seems to be in excellent shape. Hope you post here as a project as well.
            You have excellent restoration skills my friend and I know how much time and money it takes. It definitely shows in that XS, squeaky clean and a real head turner. Are you planning to dyno it for final tuning? Looking forward to a full set of completed pics. Congrats. Rick
            I May Be Crazy, But I Have A Good Time.
            Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily rider
            • 79XS11F
              • 3563
              #126
              Yes the bike is a complete unit except for the exhaust system which I will likely never find. A lot of other Parts are however still available for it so I have already changed out all plastics and grommets. Even the fairing is NOS. Have a replacement set of forks with the anti dive not messed up. I know of only 2 others like it in North America from the North American Katana owners association. It will be a different project as compared to the 11s. My hop up bike that this thread is about is meant to be a daily rider so the restored 11 can see minimum use. Club runs show and shines maybe bike shows. It would be interesting to Dino it but that type of service is not common place in Ottawa and therefore rather costly. We'll see.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • Big Daddy Funk
                • 639
                #127
                100 horses?
                If you can get down to this area, just let me know. I have a friend with a state of the art Dyno (he's a drag bike builder) I'll twist his arm and get you two pulls for under $100.00cdn. You get HP & torque curves and A/F mixture ratios from 0 to redline. They can also read a bunch of other performance enhancements with it. It's a great tool for getting the most out of the money you already have in the bike.
                I wouldn't be surprised if you have a big bore kit, aftermarket cams, adjustable cam sprockets, flowed head, headers and the chain drive conversion that you could break into the 100 HP area. Thx Rick
                • 79XS11F
                  • 3563
                  #128
                  Because it will be a daily ride I have not gone that radical with it. Enhancements include ... 1179 kit, DIY exhaust side porting, polished combustion chambers, Kerker 4 - 1 headers, K&N POD filters With jetting kit, Thunder products Dial-A-Jet system, Performance clutch, Both inside and outside kick starter system removed, NOS Crank & rod bearings, Oil cooler, Accel coils & wires, Steering Damper, Fork Bridge, Reinforced frame, Chain drive kit, Solid engine mounts, EBC Pro-lite rotors and new pucks, SS brake lines all round, BT45 tires, Progressive shocks and fork springs plus air up front, HID lighting, driving lights, Air horn, All SS hardware, All balls wheel bearings, Low rise handle bars, and likely a list of other cosmetic things I am forgetting. And of course every thing has been cleaned / refurbed as necessary.
                  This project has been 2 -3 years in the making. The history of both bikes in photos and text blogs is on "my space". There should be a link in my signature. I'm rather surprised to see that simple site getting 15 to 25 hits a day and questions from all over the globe. It's really amazing how much attention these 11s can still draw after all these years.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • 79XS11F
                    • 3563
                    #129
                    Does anyone know off hand what the torque setting of the rear wheel mounted final drive is. I'm referring to the female part that has it's 6 studs pass through the rubber crush drive grommets of the back wheel. there's no spec in the manual?
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                      #130
                      The item you refer to is the clutch hub, and it usually isn't removed. I would just get them gudentite, and don't worry about it after that. Just be sure to pack the splines in the final drive, where the clutch hub mates to it, with grease.
                      • 79XS11F
                        • 3563
                        #131
                        Thanks John, I guess I will check th manual for torque settings for that size nuts and go with that. They were in deed tight to remove. Suppose it won't hurt to lock tight them. The chain drive sprocket slides into it in the same fashion that the original drive did so those parts will be greased. I just discovered another bearing in the end of that unit that will need to be changed. That's 3 wheel bearing in total for the rear wheel.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • 79XS11F
                          • 3563
                          #132
                          The Rear wheel is Complete and ready for rubber ... Interesting set up.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • 79XS11F
                            • 3563
                            #133
                            Puttered around in the garage on and off today and got the callipers and front MC rebuilt but I’m still waiting for shoes and of course front wheel installation before I can really set them up and finish them. I temporarily Hung the fronts just to get them off the bench. Rebuilt the switch boxes and started installing the handlebar gear. It’s coming together bit by bit. Can’t really see it in the photos but the high heat paint has “ambered” a little on the parts that would fit in the oven with the door closed. If I do this sort of thing again I will not bake it. Time for a few Ryes ...
                            Rob
                            Throttle side
                            Clutch side
                            Front callipers
                            1978 XS500E
                            1981 Suzuki GS1100
                            • 79XS11F
                              • 3563
                              #134
                              At last it's starting to look like a motorcycle
                              I got my tires installed and wheels balanced yesterday, received additional hardware so now things are coming along nicely. i can see the light at the end of the tunnel :-)
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                              • Big Daddy Funk
                                • 639
                                #135
                                Head Turner
                                Truly sweet. Great craftmanship and a ton of patience. Love to see that bike up close. Rick
