And so it begins ... Another bike building project
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    #76
    Originally posted by DGXSER
    Wow, now I am really considering a project for next winter. I like the "brushed nickle" look. You have more patience than I ever hope to!!
    The same amount of cleaning and prep would be required for repainting so it's not really a lot of extra work.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 79XS11F
      • 3563
      #77
      I was going to rebuild the brakes today but got side tracked and ended up just continuing to put parts on the bike and nearly completed the electrical. So far I have managed to stick to the all SS socket head hardware theme with only the occasion bolt not being in my assortment but a list is being made as I go. it also looks like I will have to do some custom work to the left hand side rear foot peg support because the frame reinforcement bracket on the outside of the frame will interfere with the fitting of that part. Tomorrow I will be at the paint stripper again to try to remember everything that’s left to be stripped so all painting can be completed in one shot when painting starts again. As usual ... more pics.
      Rob
      Under body panel electrical
      Rear Fender on and wired
      Still all SS socket head hardware
      I’m going to have to grind out the back side of this peg support for proper fit
      Even the small screws like on the back side of the pilot box are SS socket head. The small fine thread ones are actually easier to find then the big ones because all the small ones are fine thread .
      1978 XS500E
      1981 Suzuki GS1100
      • 79XS11F
        • 3563
        #78
        Got about an hour and a half in on the front wheel. I think I will glass bead it .. Be much faster but non the less it's looking pretty good...
        Rob
        1978 XS500E
        1981 Suzuki GS1100
          #79
          Hey Rob,
          Lookin' mighty fine, but you need to take a day of REST and ENJOY your
          BIRTHDAY you old man!!! Have a Happy One!!!
          • petejw
            • 2269
            • sydney australia
            #80
            Hey Rob,
            Thats all looking so sweet,
            looking forward to seeing the end result.
            and have a good one on your birthday!
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              #81
              B-Day
              Yes, Definitely happy Birthday Rob. I have been watching your build. That is going to be one beautiful bike. I would think you could counterbore that front peg hole up to @ 0.5" and add a spacer the same thickness between the bracket and the frame at the rear...JAT
              Anyways, I hope you are still doing the ZRX rear swinger. Painted Black to match the bike would set it off nicely...Anyways Happy Birthday. Have a good Canadian Beer for me....Chop
              MDRNF
              79F.....Not Stock
              • 79XS11F
                • 3563
                #82
                I was looking at options but to move that peg support out far enough will lead to running out of engine through bolt length for the added distance. I think when it's all said and done it will be faster to just hollow out the back side of the entire peg support.
                Yes I am thinking I will likely go forward with the ZRX swing arm set up. The other kit appears to use 2 bearings but one of them is toast and it or they are pressed into the casing and onto the shaft so replacement is going to be an issue that might be best left to a machine shop.
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #83
                  When I first installed my Chain-drive, I had the Jardine 2-1's on each side and I had to grind on mine some too. You will get a much sportier ride out of the ZRX swingarm. It is one of the lightest swingarms I have ever held and super strong too.....
                  MDRNF
                  79F.....Not Stock
                  • 79XS11F
                    • 3563
                    #84
                    The ZRX swing arm is in deed a lot lighter then the swing arm that came with the other kit. However I am somewhat concerned about shock length and rear brake set up. More so about rear brake set up then shock length. I'm going to have to go through that thread again and find the info I need on both those issues. If the bearing on the other one was not toast it would have been "plug and play"
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                    • 79XS11F
                      • 3563
                      #85
                      Hey Rob,
                      REST is for OLD people LOL LOL OH... was that my back going out again ... LOL LOL
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #86
                        Shocks
                        I found that the 14.25" shocks from a KZ1000 are a very good alternative to the ZRX shocks.... I also Sent Scappod a Spare front brake line from a Hayabusa, It was plug "n" play on the rear. Are you going to use the stock XS11 caliper and hanger?
                        Are you using an XS650 Rear wheel?
                        If so you could probably just make a spacer on the axle that goes between the caliper hanger and the right axle pinch......
                        MDRNF
                        79F.....Not Stock
                        • 79XS11F
                          • 3563
                          #87
                          Well this is the stuff I still have to sort out because I have already bought the tires and was intending to use the standard size rear wheel. I also already have normal length Progressive rear shocks and SS brake lines for the rear end. That being said I do if nothing else have the chain drive conversion parts that fit the standard rear wheel so I may be able to mix and match and still use the 17 inch rear wheel so long as shimming can plant that wheel where it needs to be. I can also likely figure out something for the standard brake set up but would likely need a longer SS brake line. I think your middle gear conversion puts the chain out further then this other unit but I have to look at all the parts carefully.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #88
                            You can cut down and add spacers to the ZRX axle all day. You can also add spacers to go between the XS650 rear sprocket and wheel (or any other wheel for that matter)..... The Hardware store sells washers just the right I.D. for the ZRX and XS11 axle in different thicknesses also.....
                            MDRNF
                            79F.....Not Stock
                            • 79XS11F
                              • 3563
                              #89
                              That's the other issue. I have an axle for the ZRX swing arm but will I be able to find the right bearings that fit both the wheel and axle white taking into account that "special" bearing it the rear of the 17 inch standard wheel. There's a few things to sort out before I put it together. finding time during the normal week week to hit all these specialty shops is an issue as well. They are for the most part not open on weekends.
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                #90
                                Yes, You can make it work for sure. You can source different size bearings and shim accordingly.....Anything is possible.....I've already jerked out a 2.5L 4 cylinder Porsche motor and replaced it with a 5.3l CHEVY V8..........I 've done some bearing swaps/conversions to the drivetrain already.
                                MDRNF
                                79F.....Not Stock
