And so it begins ... Another bike building project
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    It Continues
    I farted around in the garage this evening and managed to get almost all the wiring completed and all the rubber is in place. If I can get the coils mounted tomorrow without too much fuss I may even see the engine go into place. As you may notice I am sticking to the SS hardware everywhere I can...
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 79XS11F
      • 3563
      Can This B Fixed
      I was hanging my coils a few minute's ago and noticed one of the wires was loose but it was not loose. The post is broken off down very close to the coil. The posts are hollow with a rather tiny wire running through the center that is soldered at the top of the post. I am doubting that it can be fixed but if anyone has any ideas my ears are open.
      Other option is .. Does anyone have a single accel coil to sell.
      BLAST ... if this had not happened the engine would likely be in the bike tomorrow.
      Rob
      1978 XS500E
      1981 Suzuki GS1100
        Something like that I try to think how is that piece put in to begin with?? They installed it at the factory, so is it screwed in? or soldered in?
        Just food for thought, not a clue how to fix it myself.
        • 79XS11F
          • 3563
          #34
          If it's threaded in it would likely come out but even if i can get it out there's the issue with the tiny wire that was running through it. I never even knew the posts were hollow. I do in deed think it's TOAST. Buying a matching single unit is just over 100 bucks with TAX. If I buy a new set I will save about 45 and that's likely what I will do. I have a feeling the wrench contacted the "L" bracket and pushed the post over cause I did not make them very tight. The "L" brackets are needed to make the coils mountable in the factory position. I guess I should have connected the wires first and then put the brackets on.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            #35
            The only thing like it I have done is the stud for my turn signal that is hollow. One of mine got bent and broke when I staightened it out. I took a piece of Allthread of the same size and drilled the hole in it but it was not metric thread, so I ran a die over one end part way it to make the metric thread which also served as the stop or shoulder. let me thread it into the turn signal side, then used a std thread nut on it inside the headlight box.
            As to the wire inside on yours, I wonder how they got it soldered in to start with? Was that end put in first? Just thinking out loud. Probably end up cheaper just to replace it, and probably bugger it up good some other way fixing this. But then what do you have to lose, and might work!
              • 8962
              Can you solder a wire lead to the broken post and then connect it to the wiring harness?
                #37
                I'm with BikerPhil on this. You could use one of those EYE round end wire connectors to fit around the post and solder it to the post. Do you need to secure the small wire inside the post to the post? Soldering it would do it, but putting a small screw into it might also do it, and if you used one with a larger head, it would help hole the EYELET in place along with the solder??
                As for buying NEW ACCEL's , you've seen several folks post on here about their experience with the MIkesXS high output coils, they are much cheaper and work quite well, and provide a pretty good oomph of power, possibly not quite as much as the ACCEL, but I don't remember reading the actual power/volt rating for them? 30K, 40K, 50K???? The Mikes are ~35K!
                JAT!
                • Korr
                  • Jul 2008
                  • 293
                  • Torrance, CA
                  #38
                  I wish i had a garage to work in I would get so much done. look at all that stuff drool!
                  1978 XS1100E Standard
                  Tkat Fork Brace
                  On Hold
                  TopCat S.O.F.A. + Fuse Block
                  Mike's XS Pod FIlters
                  • 79XS11F
                    • 3563
                    #39
                    If I can dig out the epoxy that fills the post without cutting or doing more damage to that wire I could likely repair it like that. I will have to fill the base of the post with solder and attach the wire ring in a single operation. It's worth a shot.
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                    • 79XS11F
                      • 3563
                      #40
                      Welcome to Sanfred & Sons XS11 collection ... I think I have close to enough parts to build a third bike.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • blue giant
                        • Aug 2007
                        • 880
                        • Ontario, Canada
                        #41
                        Rob
                        That sounds like a winter 2010 project!!
                        Paul
                        1983 XJ1100 Maxim
                        1979 XS1100 Standard
                        1980 XS1100 Special
                        • 79XS11F
                          • 3563
                          #42
                          I think 2 - 11s is enough for this lad. When the insurance runs out on the kat I will undertake to restore that bike. Anything beyond that will be something different. However, My fully restored 78 is my fav bike to ride :-)
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • thewiz
                            • Oct 2006
                            • 1115
                            • Wilksboro, NC
                            #43
                            Yeah, but ...
                            think about all the 11s out there that need your help The ones that would be lost without you .... can you just turn your back on 'em without hardly a second thought?
                            80G Mini-bagger
                            Past XS11s
                            • 79XS11F
                              • 3563
                              #44
                              Ohhhh ... I am sure that they or the parts they produce will find a good home with the members here and abroad. If we save "EVERY ONE OF THEM" ... we'll be screwed for parts eh ... :-)
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
                              • 79XS11F
                                • 3563
                                #45
                                I Popped the engine in this evening
                                being that I don't have my coils yet I decided to get the engine mounted. If you look close you will see how you can do this alone and not even break a sweet.
                                PICs as usual
                                In position
                                Sliding boards in place and strapped to the frame which is straped to the stand
                                On her way over
                                Close to in place, a bottle jack was used to help make it light in the frame for final adjustment
                                There she be in the frame :-)
                                1978 XS500E
                                1981 Suzuki GS1100
