begging new mod, need input
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #181
    gracias
    I removed alot of connections from the Blue-Streak and hot soldered them. I still have a gremlin in the headlight at times. I just hit the high beams and roll on. I want the absolute best wiring/charging for this bike possible.....chop
    MDRNF
    79F.....Not Stock
      • 7608
      The only problem with the solder is it will crack after a while. If you look at airplane connections, they are ALL crimped. a GOOD crimp tool, and the proper connectors will last longer than a solder joint. The Anchor connectors can be had with the heat shrink tubing as part of it.
      Ray
      • 50gary
        • Apr 2006
        • 225
        • Saginaw, Michigan. USA Third stone from the sun
        #183
        Ray, that's exactly what I did on my complete re-wire of my XS650 project. Marine tinned wire marine connectors, and even a very nice new marine fuse box. Strange but about 2003 I also used the SV650 taillight moulded into the rear of a TT500 seat with carbon fibre.
        Cheers, 50gary
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #184
          gotta pic
          I am actually going to have mine mounted upside down and flow right into the rear fender to come to a rounded point....
          MDRNF
          79F.....Not Stock
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            #185
            for pggg
            hey, what's the diameter in mm on the 14T sprocket you have? and thickness also....Also if anyone wants a v-star tank....pm I have changed my mind on tanks.....chop
            MDRNF
            79F.....Not Stock
            • pggg
              • 1609
              • NZ
              #186
              Chop, 530 pitch sprockets are exactly 9mm thick, 13 tooth are 72mm diameter and 14 tooth are an extra 2 or 3mm wider than that - from memory (can't get at my 14T on the bike to re-measure the diameter exactly)
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #187
                Busa forks
                I looked at the old thread about steering head bearings. I saw 50Gary's reply about xs11 steering bearings. Looks like I will need a 30x47x15 tapered bearing for my Busa tree. Also would it be feasable to turn the tree around like this guy?
                MDRNF
                79F.....Not Stock
                • 50gary
                  • Apr 2006
                  • 225
                  #188
                  That would be quite unstable. The bike would have virtually no trail. The offset of the triple clamps would be negitive. The Hayabusa triples will have much less offset than the XS11 to start with. This Hayabusa triple will shorten the wheelbase by about 1/2" (estimate, probably close to my R1 triples) and quicken the steering a bit. The new forks will be more vertical (and quicken the steering a bit) because they are shorter in length making the front steering angle more steep. This will make the Hayabusa spring rate act stiffer than if the XS11 rake were dialed in by lowering the rear in relation to the "new front".
                  Cheers, 50gary
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    #189
                    busa tree/forks
                    Yeah, maybe he took a quick pic without realising he had the fork trees backwards. Any how I will put mine forwards and My triumph S/A is 2" longer than stock xs11. I think this will be the ticket and move the weight forward a bit....wat ya think?
                    MDRNF
                    79F.....Not Stock
                    • 50gary
                      • Apr 2006
                      • 225
                      #190
                      The things that I said about the offset and steering angle will still apply, so it's a step in the right direction for improved handling IMhO. The standard (1978e) weight distribution of the XS is biased towards the rear. 54.8% rear and 45.2% front.
                      Cheers, 50gary
                      • Mathh
                        • Nov 2006
                        • 663
                        • Beek, Netherlands
                        #191
                        Re: Busa forks
                        This will not work with your stock fuel tank....
                        When you turn the forks left or right the legs will hit the tank instantly, leaving you with no clearance at all. This problem already occurs soon enough when you mount the tree in the correct direction.....
                        MV Agusta Brutale 910R '06.
                        Yamaha MT-09 Tracer '15 grey.
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          #192
                          I agree
                          I will be mounting mine the correct way of course. I am not worried about the stock tank. The Victory Vegas tank will be used and moved back 1.5 to 2 inches anyway....Right now am hunting down a tapered bearing.....
                          MDRNF
                          79F.....Not Stock
                          • audijunky
                            • Apr 2006
                            • 707
                            • VA
                            #193
                            try here for the bearing if you haven't already
                            Buy premium ball bearings online from VXB.com – your trusted bearing supplier and distributor. Explore a wide selection of bearings at wholesale prices with same-day shipping and next-day delivery. Precision, speed, and reliability—delivered fast.
                            79 XS1100 modified standard
                            straight pipe 4-2 exhaust
                            Owned 83 Honda V65 Magna
                            Owned 02 Vstar 650 classic
                            owned 85 Honda Shadow VT 700C
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              #194
                              bearing
                              no bearing 30x47 available...must ponder more
                              MDRNF
                              79F.....Not Stock
                                • 7608
                                Chop,
                                How about a 30 X 45 with a spacer in the neck?
