begging new mod, need input
  • 50gary
    • Apr 2006
    • 225
    • Saginaw, Michigan. USA Third stone from the sun
    #226
    I have been wondering the same thing about the R1 forks/hub speedo thing? I should take a look at it soon?
    Cheers, 50gary
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      #227
      real soon
      Yeah, I was just looking at a busa wheel. I will look into it also. Almost looks like the xs11 drive hub can be machined from the inside to take the Busa axle. Whats the R1 axle Diameter? IIRC the xs11 axle is 18mm??
      MDRNF
      79F.....Not Stock
      • 50gary
        • Apr 2006
        • 225
        #228
        I just measured the R1 axle diameter, it's also 22 mm. The R1 dust seal assembly (bushing with dust seal) that the speedo drive will replace is 18 mm deep x 22 mm I.D. x 28 O.D. The dust seal itself is 46 mm O.D. That's a difference of 4 mm I.D. 2 mm radius that's .0787" on each side humm I wonder if the XS11 speedo drive could be bored to 22 mm? The drive looks as if it can physically be made to fit if I can make it drive from the R1 hub?
        Cheers, 50gary
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #229
          drive hub choices
          I am looking at the royal star, road star axles trying to see if they are beefier. I did find that a bmw k75/100 axle is 25mm, now to see what drive hubs look like.... I remember that the xs11 drive looks like quite a bit can be removed....IIRC.the xs11 axle is 17mm BTW....
          MDRNF
          79F.....Not Stock
          • pggg
            • 1609
            • NZ
            #230
            Hi guys, XS axle's 17mm, the speedo drive could be milled out inside from 17mm to 22mm at the extreme limit, you're looking at around 31mm minimum distance between wheel bearing and inside fork leg to fit the XS speedo drive.
            • pggg
              • 1609
              • NZ
              #231
              Trouble is the speedo might not read really true with 17 inch, but saying that, my 18 inch still reads the same as when 19 inch, so any error will probably be insignificant..
              • Goin Commando
                • Sep 2006
                • 125
                • Florida
                #232
                How about a nice digital speedo, that reads a magnet placed on the rim. Easy to mount, very adjustable and possibly more accurate. I here you can get them from bicycle shops for not to much money. Might be other types for sale elsewhere also. It would help to keep your front end looking clean, uncluttered and solve your front wheel/gear problem.
                I love the smell of Napalm in the morning.... It smells like......victory
                • pggg
                  • 1609
                  • NZ
                  #233
                  How about a central mounted rev-counter only, with a bicycle speedo on a bar beneath - not the handlebars, those sigma type speedos are real good, accurate as, big sized mph numbers, easy to read at the right angle
                  • 50gary
                    • Apr 2006
                    • 225
                    #234
                    This is my minimal XS650 "Dash area"
                    Cheers, 50gary
                    • Pat Kelly
                      • 3046
                      • Golden Valley, AZ
                      #235
                      Check this out:
                      Digital unit with "heads-up display" option
                      Pat Kelly
                      <p-lkelly@sbcglobal.net>
                      1978 XS1100E (The Force)
                      1980 XS1100LG (The Dark Side)
                      1999 Suburban (The Ship)
                      1994 Dodge Spirit (Son #1)
                      1968 F100 (Valentine)
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #236
                        speedo
                        speedo will be my last headache. I just got off the phone and this muffler will do. '06 ZX6RR muffler(took advice from mathH that these newer 600cc bikes put out enough power). Question is should I leave the valve in or chop it out?
                        MDRNF
                        79F.....Not Stock
                        • Mathh
                          • Nov 2006
                          • 698
                          • Beek, Netherlands
                          #237
                          Re: speedo
                          Originally posted by xschop
                          [B]speedo will be my last headache. I just got off the phone and this muffler will do. '06 ZX6RR muffler(took advice from mathH that these newer 600cc bikes put out enough power). Question is should I leave the valve in or chop it out?
                          chop it out. Is for creating torque at lower revs. You need that on a 600 bike, for a 1100cc bike it will be an obstruction.
                          MV Agusta Brutale 910R '06.
                          Yamaha MT-09 Tracer '15 grey.
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #238
                            its outta there
                            Thanks guy, I am planning on putting a mac/kerker/jardine header on, whichever is the shortest and run it straight into this guy. It should sit right in front of the wheel in place of the centerstand....chop
                            MDRNF
                            79F.....Not Stock
                            • 50gary
                              • Apr 2006
                              • 225
                              #239
                              yamaha xs1100 xj1100 kerker header Item number: 280073248273
                              Cheers, 50gary
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                #240
                                what abobout the MAC
                                The Bay sells new mac 4-1 for 300 bones. Does anyone have a good picture of one on their xs? The add reads that they have"better ground clearance and oil filter accesability". If i get that one someone can have the brand new chrome muffler from it....chop
                                MDRNF
                                79F.....Not Stock
