begging new mod, need input
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #136
    muffler choice
    I will put a 4-1 Mac or kerker header(they look the shortest) my question is can I put a newer style micron muffler directly to the end of the header? I like the new one for the R6, but don't know if it would flow correctly on the 1100cc motor. I am no exhaust specialist, just know what look I want..... open to ideas...chop
    MDRNF
    79F.....Not Stock
    • Mathh
      • Nov 2006
      • 681
      • Beek, Netherlands
      #137
      Re: muffler choice
      Flow should not be a problem, but noise. The real noise dampening on a R6 is done by the collector box under the engine.
      MV Agusta Brutale 910R '06.
      Yamaha MT-09 Tracer '15 grey.
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #138
        loud is good
        I don't mind loud, cars can hear you.....so would any muffler from any newer 600cc bike work, flow properly? i have been looking at a couple on the bay. The 06 cbr600 muffler is nice....
        MDRNF
        79F.....Not Stock
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #139
          how about this one
          Is the lower square box the part you're talking about or is that a cat converter?
          MDRNF
          79F.....Not Stock
          • Mathh
            • Nov 2006
            • 681
            • Beek, Netherlands
            #140
            Re: how about this one
            That's the box. Do not know if there is a cat on board. 600 exhausts flow 100plus horsepower, the latest even 120. So it should be fine.
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              #141
              thankx
              So just match horsepower of the donor bike? I have many options then, XSelnt....
              MDRNF
              79F.....Not Stock
              • Mathh
                • Nov 2006
                • 681
                • Beek, Netherlands
                #142
                Re: thankx
                well easy:
                1100cc x 8500 rpm = gasflow x
                600cc x 16000 rpm must be gasflow x too (roughly)
                you cannot compare 4 into 2's with 4 into 1's as the gasflow in a 4 into 1 muffler has double the speed as in one muffler of a 4-2,
                but I guess you thought about that already
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #143
                  swingarm is done
                  Custom swingarm pivot bolt attached to stock frame pivot points and pivot bolts.Smooth as Butter. The monoshock is a good fit, but I'm eating my words, I will have to relocate the battery, will be under rear fender. Triumph swingarm mounted with 25mm dia. spacers,1 from the Triumph, 1 from the xs1100 middle drive race bearing, go figure. Will post more pics,when monoshock is done hopefully tomorrow. Decided to go with a solid aluminum engine mount near the sprocket and keep the others rubber(best of both worlds).
                  MDRNF
                  79F.....Not Stock
                  • pggg
                    • 1609
                    • NZ
                    #144
                    Wow, this is looking fantastic, can't wait to see the final result.
                    • xschop
                      • Feb 2006
                      • 1794
                      • oklahoma city
                      #145
                      mee too
                      Hey pggg, do you have a sealed bearing on the inner middle shaft bearing on your setup? Obviously to keep the engine oil in. If so then I want two of them.....
                      MDRNF
                      79F.....Not Stock
                      • pggg
                        • 1609
                        • NZ
                        #146
                        Chop one of the bearings is a 25mm X 63mm, can't recall the other, but you'll suss it when you strip the drive unit
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          #147
                          inner bearing
                          inner bearing I.D. is 30mm and the problem is that the outter drive splines are 29.5mm. maybe some are mfd a little different. I want to hard weld and regrind the spline surface to accept the same size bearing as the inner( and find 2 sealed ones of course)
                          MDRNF
                          79F.....Not Stock
                          • pggg
                            • 1609
                            • NZ
                            #148
                            Both bearings are common available size, I get 29.8mm across the splines, sprocket spline pattern is 26mm x 30mm.
                            • pggg
                              • 1609
                              • NZ
                              #149
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                #150
                                muchos gracias
                                I have found a source for two of these sealed. I just don't know why yamaha cut those splines at 29.6mm (mine). I may be able to just wrap them with some thin mic'd sheet (.4mm) and call it a day....merry christmas
                                MDRNF
                                79F.....Not Stock
