    Originally posted by natemoen
    Daymaker! That is what we shall call you!
    +1 on that. I am envious and will have to investigate this LED thing
      #2057
      Hi Eveready,
      what I do to cope with my failing night vision is not ride after dark.
      Mind you, if circumstances ever forced me to ride in the dark having my own personal patch of daylight to see with would be nice.
      But where does one find all that extra Wattage?
      Hey Fred,
      Even though the light bars state like 20x 3 Watts or 6 x 10 Watts =60 watts, they are not talking actual current draw levels! I reviewed the first one on eBayAu, and the spec sheet shows that the 60w units actually draw only 3.1 amps = ~36 watts. I would suspect that the other unit (6 x 10w) would draw a similar amount...but they didn't have an actual spec sheet. The second unit surprisingly is the same company that sells the HID projector system I used for my HID projector conversion!
      I have to say that those light bars are a bit $$, and even though they look neat and have a nice illumination pattern, I wonder if mounting a pair of HID projectors might provide similar coverage?? I'll have to see if they offer these in the USA ebay.
        • 4015
        Attempted the carb mixture adjustment/sync mentioned by Motoman/Davinci in other threads. Turned my idle down below 1100 rpm, and the carb tune bars were too jumpy to even attempt adjusting mixture screws. I ended-up re-syncing the carbs to a perfect balance, then pressure-washed the engine.
        • mikubuilder
          • Jul 2011
          • 548
          • Westland, Mich.
          #2059
          Ian, you should throw some Xsesive porn on here, we wanna see your bike
          Nick
          1982 Virago 750 (it's alive!)
            • 4015
            • MPittma100
              • Aug 2011
              • 2359
              "Time" For A New Front Tire
              Looked at the front tire and saw some "dry" cracking between the treads on the Venturer. Checked the date on the tire and it is 7 years old. New Metzler on the way.
              Pulled wheel off today along with rotor and caliper covers. Those add a lot of time to the job. Checked brake pads - original Yamaha. Showed some wear, but not worn out completely. So, while I am at it, going to replace pads, wheel seals, clean and repack speedo drive, and rebuild calipers and master cylinder. Wheel bearings are good.
              MP
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
                • 8963
                +1 on that Mike, I fried mine because I neglected to do it. Had to ride back from the SE rally this year without a speedometer.
                  Hi Mike be gentle with the speedo cable too. I kinked mine while changing front tire to attend XSSE and had to replace it as it broke within a mile on test run.
                  Maxim Phil.
                  • Petersg_99
                    • Apr 2012
                    • 184
                    • Phoenix, AZ.
                    #2064
                    installed mini hard bags
                    I finally finished installing my el-cheapo mini hard saddle bags!
                    Cosmetically I would have preferred to move them down and forward a bit, but even with where they are, it's a bit tight for the passenger's feet.
                    I still need to pull them and shoot them green to match the tank, but they're out of the way for now.
                    Guy
                    1980 XS1100G - Frankenstein - resurrected from the impound lot
                    1991 Suzuki GS500E (not running yet)
                    2003 Burgman AN400 - Blue Belle
                    2005 Burgman AN400 - Silver Belle
                    • Aches n Pains
                      • 349
                      • Reston, Va.
                      #2065
                      Guy,
                      I actually like that setup.
                      One question from your photo album. What paint did you use on the MAC exhaust and how did it hold up?
                      Thanks,
                      Doug
                      1995 KZ100P
                      Pods, jets, pipes, cam adjuster, oil cooler
                      1977 Ironhead - custom build
                      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                      • Petersg_99
                        • Apr 2012
                        • 184
                        • Phoenix, AZ.
                        #2066
                        The exhaust in the photo above is all chrome.
                        The exhaust that came on the bike (may have been factory), I had the chrome stripped and painted it with VHT flame proof ceramic coating. It didn't impress me. If anything it held up more poorly than Rustoleum BBQ paint.
                        side covers and tank: Rustoleum color shift Gamma Green
                        Frame and accessories: Rustoleum hammered black
                        Front fork tubes and final drive: Rustoleum hammered silver
                        Rotors & calipers: Rustoleum hammered copper
                        I plan on re-painting the hammered silver stuff with the hammered copper, it goes with the brown seat a bit better...
                        Guy
                          Actually, I like the cage sittin' next to it.......
                          • Petersg_99
                            • Apr 2012
                            • 184
                            • Phoenix, AZ.
                            #2068
                            Yep, I'm kind of partial to it. It's a fun ride too!
                            Guy
                            • jjz28
                              • Apr 2012
                              • 1023
                              • Beckley, W. Va.
                              #2069
                              finally got around to checking the valve clearances on my xs750. Wound up using a screwdriver to get the shims out and replaced all 3 intake and 1 exhaust. Now all my valves are within clearance. Not as near as hard as I thought it would be. The screwdriver worked really good though, didn't need to by the motion pro tool.
                              77 XS750 2D completely stock
                                • 4015
                                I'm kind of curious as to how you depressed the bucket without using the tool? Probs not something I'd ever risk doing. U can't go wrong doing things the right way.
