Theodore Roosevelt -
One of the rear frame stubs cracked again and needed to be welded.
I took off the luggage rack before heading over to the welding shop to make it easier to get at the frame and the rear fender almost fell off on my head. Both of the frame stubs are cracked but this time the luggage rack is holding them in place and they haven't gotten around to falling off yet.
I put the rack back on and rode over to the shop and the owner is working somewhere out in Bakersfield today. He took the welding equipment with him so none of the other guys at the shop could do the work today. Tomorrow's not looking real good either.
There's nothing I can do about it so I think I'll take off the crummy old engine mounts and put on the better ones from XJ, then take a break and pick some lint off the dog while I watch the evening fog roll in.
♬Comment
Nick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
♬Comment
Fork oil
I changed the fork oil in my 80XS1100SG.
Put it on the center stand, jacked up the front, & followed directions. Pushing against the spring and trying to start the threads of one cap just about beat me. Removed spring and started it to be sure it was straight and could go in without crossthreading. After practicing, replaced spring and cap, filled air shocks to 15psi using small hand pump purchased fron Harley dealer.
Finished job. It seems like there might be an easier way. pump oil in???It is a great big beautiful world out there
Brent in GA
Yamaha 80XS1100SG, HD Firefighter Special Edition 02 Road King, Honda 450 rat, 08 Buell 1125R tour modified, 83 goldwing parts bike gone-traded for XJ1100, 2014 HD electraglide policeComment
Yeah, take the forks out. Turn them upside down and use a basting syringe to put the fork oil in with the forks upside down. Then put the screw back in, put the forks back and and reassemble. Works pretty fast, no mess, easy to measure exactly the amount you need, no fighting with the springs either.I changed the fork oil in my 80XS1100SG.
Finished job. It seems like there might be an easier way. pump oil in???Cy
Thanks. That fight with the springs was tough. Good to hear of another way that sure sounds doable.Yeah, take the forks out. Turn them upside down and use a basting syringe to put the fork oil in with the forks upside down. Then put the screw back in, put the forks back and and reassemble. Works pretty fast, no mess, easy to measure exactly the amount you need, no fighting with the springs either.
Things to do - buy more cigars and look for flame resistant seat cover.It is a great big beautiful world out there
Brent in GA
Sorta recall
Someone here was explaining how they put it in the drain hole with a large syringe like they used to give "Festus" their mule shots.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
I got mine all wet, as in 2 hrs in the rain. Found out my gear leaks. Also thoroughly tested the waterproofing job I did on the neutral switch wire. It works well. He probably needs a wash job now. That's automatic here, just park it outside for a while, pull it in, wipe it down. Summer is over in the PNWet.
Hey, Brent! Nice avator. I like that spot.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Yeah, that sorta works, but it can be hard to get the right amount in that way cause it spits back out, but if you take them out of the trees and do them upside down, it doesn't spit and you get it right the first time, works fast, clean and easy, and no fighting with the springs. Still gotta fight the springs if you need to replace the seals though.Cy
Thank you very much Dave. It is one of my favorite photos. When I first saw it, I considered cropping out the road sign arrow, but it is candid, really caught me going my own wayI got mine all wet, as in 2 hrs in the rain. Found out my gear leaks. Also thoroughly tested the waterproofing job I did on the neutral switch wire. It works well. He probably needs a wash job now. That's automatic here, just park it outside for a while, pull it in, wipe it down. Summer is over in the PNWet.
Thanks for taking the picture, & showing me some of the beauty in your area.
to do on 80SG I removed the chrome covers from the swing arm pivots, thinking to grease them. Found no grease zerk fitting there. Left side had grease on nut & side cover. Greased drive shaft 25cc or 25 pumps of the grease gun handle. Is it possible grease gets pushed all the way to the swing arm pivot from the drive shaft zerk? I have pumped a lot of grease in there over the years.It is a great big beautiful world out there
Brent in GA
uh oh
I had recently finshed 2nd gear fix, and was getting ready for Iron Horse rally, replacing fuel lines, bleeding brakes, installing turn/tail/brake mod using an old but unused magnetic mount trailer kit, and going back to the airbox (which was a b**** until I discoverd i had the baffle upside down. fired it up and
I heard a chirp,
and shortly later another, and then it turned into a sqeal...
looks like i won't be going... unless i can learn to troubleshoot and fix this in less than a week.
looking for a hero... anyone care to offer tips or assistance?'82 XJ1100 -
fusebox, 2nd gear fix
tail/turn/brakeComment
