  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    #406
    I rode my E. Haven't done that in a few months. Next will be the LG. It starts and runs fine.... buried in the shed.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • hamjam
      • 1003
      • Toronto ontario Canada
      #407
      changed GPS mount
      Seamus Ó hUrmholtaigh
      Niimi Moozhwaagan
      and SOXS
      2008 Nomad "Deja Buick'
      • dpotter58
        • Aug 2004
        • 1865
        • Southern Maryland
        #408
        Originally posted by 79XS11F
        Yesterday evening and this morning I pulled the carbs, re jetted for a RETURN to the drilled air box, reinstalled all, synced, color tuned and installed the auto adjusting cam chain tensioner including the damper tip that Ivan supplied to me.. Thanks Ivan. Engine runs GREAT with the return to the air box.
        Rob
        What about a damper tip? I have a couple of tensioners here to put on my bikes... I didn't pick up that I need to change a tip...
        1980 LG
        1981 LH
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          #409
          You don't "need" to. Some felt more comfortable having a nylon tip between the tensioner and the chain rail
          Pat Kelly
          • firemanstan7
            • 27
            • Newfoundland, Canada
            #410
            Finally got the mid and rear drive fluid changed and tackled the cam chain tensioner! Brake fluid change front and rear next.
            FireManStan7
            "I'm goin ridin...anyway"
            • 79XS11F
              • Jul 2006
              • 3563
              • Ottawa, Ont. Canada
              #411
              In the thread about switching out to this type of cam chain tensioner there was some questions about the stock unit having a rubberized tip that might absorb noise and or vibration. Ivan made a tip and sent to to me to test. It fit on the end of the new tensioner like a glove.
              The only issue I can think of about this sort of change is that if your cam chain is unevenly stretched the self adjusting tensioner would likely take all the slack out of the chain at the loosest point and therefore potentially be too tight at places where the chain is not stretched as much. This could in theory stretch the chain in the previously un-stretched parts or put added stress on the cam sprockets and perhaps the cam bearings.
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • Crazcnuk
                • Aug 2006
                • 2980
                • Hinton, AB, Canada
                #412
                Moved the fairing, luggage, trunk and rear running boards to the 78. Changed the handlebars to the 80 style, replaced the front master cylinder and front brake hose (the old one was too short).
                Put on newer handlebar grips. wired the xm radio adaptor, antenna etc.
                Unfortunately, it has gone back to shorting out and blowing the ignition fuse when I turn the key on.
                All that is left is to put on the case guards, change the sidecover lock (don't have a key for the one on it), put on the fender guard and front disc covers, and change the front brake pads.
                Oh, and sold the 80SG.
                '05 ST1300
                • malber
                  • Sep 2006
                  • 568
                  • Belmont, NH
                  #413
                  Sheared two exhaust mounting studs. Looks like I'm in for a trip to the mechanic in a couple of weeks.
                  1981 XS1100SH
                  • cowboybob998
                    • Mar 2009
                    • 371
                    • KC MO
                    #414
                    Witch one ?
                    I pideled with three of them today, robing from peter to pay pal, begining to wonder if I will ever get one of them up and runing, good thing for my venture royal i have something to ride and get parts, i love that bike, but not as much as the Xs
                    1979 xs1100 f
                    142 main, 45 pilot, Jardeen crosover 4/2, no air box
                    floats @ 25.7
                    1979 xs1100 F
                    1978 gl 1000 goldwing
                    1981 gl 1100 goldwing
                    !986 venture royale 1300
                    Just an ol long haired country boy, come to town to spend some egg money
                    when ya get bucked off, get back on
                    • 79XS11F
                      • Jul 2006
                      • 3563
                      #415
                      I tuned up my 79 restored bike including changing out the charging system but that didn't fit my tack bounce. It turned out to be the tack itself that was not working. So installed a NOS tack and also found a miss fire caused by loose connections between coil leads and plug caps. Just took her for a run and she runs GOOD. Also re-jeted the carbs on the modified bikes engine and got her running GOOD. She should be ready for a safety real soon.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                        #416
                        Yesterday marked the official Time Of Death for Thunderstruck. Finished splitting the cases and removing all the inerds. Frame and engine cases with the head went to the scrap yard.
                        Have a few items listed on the bay, intake boots, triple trees, clutch basket. other items to follow that are not requested here at XS11.
                        Sad day for me, will mark the TOD in her title before I cremate it.
                        • Crazcnuk
                          • Aug 2006
                          • 2980
                          #417
                          Moved the front running boards and case guards to the 78.
                          List is getting shorter.
                          '05 ST1300
                            • 8905
                            Got the 79F ready to head out on it's summer trip. I have a Yamaha trunk that used to be mounted to a rack, but I rigged it up so it easily straps to the passenger seat. Having a backrest is nice, makes you feel like you and the bike are one.
                            • Cobia
                              • Jul 2007
                              • 1587
                              • Palm Beach County, Fl
                              #419
                              Nice Job!!
                              Looks good Phil. It kind of ties the storage solution all together too, what with the saddle bags right below it and on each side. Does it interfere when opening the saddlebags?
                              1980G Standard, Restored
                              Kerker 4 - 1
                              850 Rear End Mod
                              Automatic CCT
                              1980GH Special, Restored
                              '82 XJ1100 (Sold)
                                • 8905
                                Robert, it interferes slightly, but they can still be opened easily. Looks like I have the back tied down a bit too tight in that last pic, it isn't that straight. Glad your bike is handling good with those new springs.
