Mystery Carbs
    Sounds to me like the owner is going to have to invest a few dollars for you to get those sorted out.
      • 2104
      Been following this, and would like to add a couple pennies. After you get carbs,jets,fuel flow, air filters, the bike running and synched, the most accurate fuel height adjustment is made with bike running, on center stand level both ways. IMHO the float measurement gets you real close and good enough to get it running, but if you're as OCD as me, running fuel levels are another fine tune method along with color-tune.
      • autotech44
        • Apr 2026
        • 48
        #93
        Originally posted by cajun31
        You are dealing with a mess that is for sure. Those tabs can only be bent back and forth so many times before they break off. I would probably apply some heat to it before trying to bend it back down. From what you can see are the seats and needles that bad to warrant doing that to the tabs? Who was it that worked on them? If you know, might want to ask why?
        You called it. Straightened out 3 of 4 tabs. Last one broke.
          #2 80+ style carb body with good posts:
          https://www.ebay.com/itm/20621263815...Bk9SR5KI4K2yZw
            Cheap replacements I know but I have used these and they do work. FOR XJ700 XJ900 SR250 XS400 FJ600 XS650 XS1100 FJ1200 FJ1100 Carburetor Float | eBay or if you prefer Yamaha FJ1100 FJ1200 XS1100 XS650 XS400 XJ700 Carburetor Float 3H5-14985-00 | eBay Still cheap just not having to wait for shipment from China.
            • autotech44
              • Apr 2026
              • 48
              #96
              I was just going to ask if the cheap repro sets were any good because even the ones with the tabs I bent back aren't 100%. Off just a hair on position and it doesn't hit the post correctly.
              I found a $15 set in the US.
              • autotech44
                • Apr 2026
                • 48
                #97
                Thanks. But the owner understands right now I'm doing a patch job to see if the engine's good before investing any further.
                  ........ Click image for larger version
ID:	889228 Click image for larger version
                  As an alternative... anyone can buy these in the auto parts store whilst grabbing some clear fuel line and mOaR carb cleaner spray-
                  Just gotta go in from the open side, pry out the spring with a jewelers screwdriver or pointy tweezers and the check ball falls out. (^_^)
                  Save the ball cause it's the right size for the detent balls in the choke rod in case you lose'em. (ᗒᗣᗕ)
                  I swap the aluminum washers from the drain plugs onto the zirks for a good non-leaky seal. (・‿・)
                  I would NOT recommend using Teflon tape as a means of leak proofing these for the testing. (O_O)
                  I've had to go back in later with a dental pick to clean out the Teflon tape in the carb bowl threads so the tape pieces don't end up being sucked up into the jets. (_Oo)
                  HTH
                  • autotech44
                    • Apr 2026
                    • 48
                    #99
                    I think my hands are too fat to get to the idle knob. Gonne be fun hot.
                      If you still have the carbs off the bike take a few to really clean the screw up and it will be easier to adjust. I just use a long screwdriver to adjust it from the side. It can get quite heated in there. Of course without the original airbox it might be a bit easier to get to.
                      • autotech44
                        • Apr 2026
                        • 48
                        #101
                        OK. I installed the Chinese floats and set height at 23mm. Carbs on bike with a fuel IV and bike level. Fuel level is right at the housing lip which surrounds the bowl on all 4. Making the level about 8.5mm high form the desired 3mm below the bowl screw surface. I never had this problem before. Level usually at least close with height set correctly. Anyone have a formula for how much to increase float height to decrease fuel level 8.5mm. Raising the float that much seems excessive. And I'm only doing it once...
                        Click image for larger version  Name:	Untitled.jpg Views:	0 Size:	41.8 KB ID:	889315
                          • 7844
                          It's probable the needle and seat causing the problem. I went through this with chinese parts on a set of carbs and ended up replacing needles and seats with correct part to solve the problem.
                          If you want to work with what you have, do this. Turn bank of carbs upside down and measure the floats at the BACK SIDE, furthest from the seats. Adjust the back side by about 8mm higher from the carb body, and try again. This should get you to a good running point so you can at least test the bike out before putting anymore money into it.
                          • autotech44
                            • Apr 2026
                            • 48
                            #103
                            I'm going with what I have. As a matter of fact, these floats were almost dead on in height out of the box on top of K&L float valves. I'm just wondering if anyone knows of a real accurate float height to fuel level ratio. I have a feeling if I go with a 1:1 ratio and adjust the height 8mm it's going to lower the fuel level significantly more than that. From what I've read it can be anywhere from 1:1 to .5.:1. With .5:1 going with an 8mm increase in height is going to give me about 4mm to low a level when all said and done. I swear I'm only doing it once...
                              • 2104
                              You might want to adjust one carb til you get the level correct then the others to match, that way you can eyeball the correct float tang with the others.
                              • autotech44
                                • Apr 2026
                                • 48
                                #105
                                I have them off and increasing 8mm isn't even possible. Not enough travel. I'm going to go with the old spec at 25.7mm and see what happens.
