Sounds to me like the owner is going to have to invest a few dollars for you to get those sorted out.
Mystery Carbs
Been following this, and would like to add a couple pennies. After you get carbs,jets,fuel flow, air filters, the bike running and synched, the most accurate fuel height adjustment is made with bike running, on center stand level both ways. IMHO the float measurement gets you real close and good enough to get it running, but if you're as OCD as me, running fuel levels are another fine tune method along with color-tune.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
You called it. Straightened out 3 of 4 tabs. Last one broke.You are dealing with a mess that is for sure. Those tabs can only be bent back and forth so many times before they break off. I would probably apply some heat to it before trying to bend it back down. From what you can see are the seats and needles that bad to warrant doing that to the tabs? Who was it that worked on them? If you know, might want to ask why?Last edited by autotech44; Today, 01:06 PM.Comment
Cheap replacements I know but I have used these and they do work. FOR XJ700 XJ900 SR250 XS400 FJ600 XS650 XS1100 FJ1200 FJ1100 Carburetor Float | eBay or if you prefer Yamaha FJ1100 FJ1200 XS1100 XS650 XS400 XJ700 Carburetor Float 3H5-14985-00 | eBay Still cheap just not having to wait for shipment from China.Last edited by cajun31; Today, 03:06 PM.2 - 80 LGs bought one new
JimComment
I was just going to ask if the cheap repro sets were any good because even the ones with the tabs I bent back aren't 100%. Off just a hair on position and it doesn't hit the post correctly.Cheap replacements I know but I have used these and they do work. FOR XJ700 XJ900 SR250 XS400 FJ600 XS650 XS1100 FJ1200 FJ1100 Carburetor Float | eBay or if you prefer Yamaha FJ1100 FJ1200 XS1100 XS650 XS400 XJ700 Carburetor Float 3H5-14985-00 | eBay Still cheap just not having to wait for shipment from China.
I found a $15 set in the US.Last edited by autotech44; Today, 03:52 PM.Comment
Thanks. But the owner understands right now I'm doing a patch job to see if the engine's good before investing any further.Comment
