Clutch replacement
Yes, I’ll start here.Not sure this is a materials issue. The clutch seems to be binding and has a fair amount of drag so the gearbox does not shift smoothly. It's not fully releasing when the lever is pulled in. It could be the assembly binding on the "fingers" of the basket. It could be the pressure plate "star" binding because the springs were tightened slightly lop-sided. It could be the stack of plates and pads are out of sequence. You'll find it. Gasket should still work as it's only been one ride.
XS650E😎 1Comment
☮☕ 1Comment
Dayum.... ( ͡° ͜ʖ ͡° )
Looks like it's time to get all workbench "Sciency" on those frictions, steels, and springs. (Θ︹Θ)
I've NEVER been able to detect/find warpage in the plates by eye... (•﹏•╰)
Always had to use a feeler gauge to find it... like seen HERE at time 17:54-
Diagnostic Powers ACTIVATE! (^_^)“Talent hits a target no one else can hit. Genius hits a target no one else can see.”
― Arthur Schopenhauer👍 1Comment
Marty, Not knowing anything about how you actually approached this I am going to ask a question or two. Did you soak your new frictions in oil overnight before installing them? What was wrong with your old frictions? Any noticeable damage or wear? If not a good test would to be put those back in. The new springs will solve slippage problems if the frictions were still in good shape.2 - 80 LGs bought one new
Jim👍 1Comment
Yes, I soaked the new frictions in engine oil overnight. I simply assumed the clutch worn out. Step next, I will measure the old plates against the FSM.Marty, Not knowing anything about how you actually approached this I am going to ask a question or two. Did you soak your new frictions in oil overnight before installing them? What was wrong with your old frictions? Any noticeable damage or wear? If not a good test would to be put those back in. The new springs will solve slippage problems if the frictions were still in good shape.
Thanks.Marty (in Mississippi)
XS650EComment
You may be on to something here. Interesting to know what the Vesrah measures compared to your original frictions. I have a new Japanese made partsNmore friction here. I will check the thickness and report back.It feels like the stack is too tall2H7 (79) owned since '89
☮👍 1Comment
Thinking about this. The bike moves forward with the clutch pulled to the grip. The clutch also slips when power is applied. I think maybe the ears on the friction plates are too snug. They didn’t fall into place on assembly. I pushed them into the basket.
No too long ago, I put an Alto clutch in a XS650. Those were thinner friction plates allowing me to go from 6 to 7 plates to cure a slipping clutch. Those plates fell into the basket.Marty (in Mississippi)
XS650EComment
☮👍 2Comment
I just took the measurements I was too busy to do before. My old clutch plates all measure about 2.9 mm, all over 2.8 mm so they're in spec. Three of my springs measure 41.6 mm which is a fail.
One way or another, I'll get this worked out. Hopefully, this weekend.Marty (in Mississippi)
XS650EComment
Referring to post 24, how about the length of the tabs around the perimeter of the friction plates? Do they seem normal?-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
I will get back to you on that. I haven't opened it back up yet. I do know that the plates are supposed to be 3 mm thick and 2.8 mm is minimum.
As a side note, I repaired a troublesome XS650 clutch that was slipping. I used Alto plates that were thinner. I added an additional steel and friction to make the stack right. It works great!Marty (in Mississippi)
XS650EComment
I followed DEEBS11 and cleaned the edges of the tabs with a small file.
OK, the Vesrah friction plates measure no more than 3 mm thick. In spec. If you blow up the picture, you can see some of the tabs have what looks like adhesive on them. With that black stuff there's interference. I removed it. The frictions all fit fine now. They fall into place.
As soon as I got it buttoned up it started raining. I can tell it's still not right. I can't release the clutch enough to shift from 1st to neutral with the engine running.
XS650E😞 1Comment
