Clutch replacement
    • 8077
    Did you start with the adjustment UNDER the cover? Loosen the 12mm lock nut, turn the phillips head in till you feel it drag, then back off 1/4 tune and tighten the lock nut. Do this with the clutch cable very loose, like it will not engage. When done, you then adjust the clutch cable for about 5 to 10mm play at the end of the lever before it starts to pull.
    That’s exactly what I did.
      • 8077
      Not sure this is a materials issue. The clutch seems to be binding and has a fair amount of drag so the gearbox does not shift smoothly. It's not fully releasing when the lever is pulled in. It could be the assembly binding on the "fingers" of the basket. It could be the pressure plate "star" binding because the springs were tightened slightly lop-sided. It could be the stack of plates and pads are out of sequence. You'll find it. Gasket should still work as it's only been one ride.
      Yes, I’ll start here.
        • 8930
        Yes, Vesrah.
        Just saying, they have been reported to cause a binding issue and not fully releasing. I have never used them personally, but just going from what I have read.
          Dayum.... ( ͡° ͜ʖ ͡° )
          Looks like it's time to get all workbench "Sciency" on those frictions, steels, and springs. (Θ︹Θ)
          I've NEVER been able to detect/find warpage in the plates by eye... (•﹏•╰)
          Always had to use a feeler gauge to find it... like seen HERE at time 17:54-
          Diagnostic Powers ACTIVATE! (^_^)
            • 2007
            Marty, Not knowing anything about how you actually approached this I am going to ask a question or two. Did you soak your new frictions in oil overnight before installing them? What was wrong with your old frictions? Any noticeable damage or wear? If not a good test would to be put those back in. The new springs will solve slippage problems if the frictions were still in good shape.
              • 8077
              Yes, I soaked the new frictions in engine oil overnight. I simply assumed the clutch worn out. Step next, I will measure the old plates against the FSM.
              Thanks.
                • 8930
                It feels like the stack is too tall
                You may be on to something here. Interesting to know what the Vesrah measures compared to your original frictions. I have a new Japanese made partsNmore friction here. I will check the thickness and report back.
                  • 8077
                  Thinking about this. The bike moves forward with the clutch pulled to the grip. The clutch also slips when power is applied. I think maybe the ears on the friction plates are too snug. They didn’t fall into place on assembly. I pushed them into the basket.
                  No too long ago, I put an Alto clutch in a XS650. Those were thinner friction plates allowing me to go from 6 to 7 plates to cure a slipping clutch. Those plates fell into the basket.
                    • 8930
                    That doesn't seem right, they need to slide freely. Here's the measurements from a new PartsNmore friction...
                      • 2057
                      You might be able to file or Dremel the coating off the fingers to make them slide better.
                        • 8077
                        I just took the measurements I was too busy to do before. My old clutch plates all measure about 2.9 mm, all over 2.8 mm so they're in spec. Three of my springs measure 41.6 mm which is a fail.
ID:	888909Click image for larger version
                        One way or another, I'll get this worked out. Hopefully, this weekend.​
                          • 2160
                          Referring to post 24, how about the length of the tabs around the perimeter of the friction plates? Do they seem normal?
                            • 8077
                            I will get back to you on that. I haven't opened it back up yet. I do know that the plates are supposed to be 3 mm thick and 2.8 mm is minimum.
                            As a side note, I repaired a troublesome XS650 clutch that was slipping. I used Alto plates that were thinner. I added an additional steel and friction to make the stack right. It works great!
                              • 8077
                              I followed DEEBS11 and cleaned the edges of the tabs with a small file.
                              OK, the Vesrah friction plates measure no more than 3 mm thick. In spec. If you blow up the picture, you can see some of the tabs have what looks like adhesive on them. With that black stuff there's interference. I removed it. The frictions all fit fine now. They fall into place.
                              As soon as I got it buttoned up it started raining. I can tell it's still not right. I can't release the clutch enough to shift from 1st to neutral with the engine running.
                                • 2057
                                Phil's take on things keeps making more sense. Perhaps you could install the old plates and shift into first. If it works, it would indicate a materials problem.
