Removing Cams - Question
    • 2107
    Thanks jetmechmarty and Deebs for your opinions.
    I left out an important word in my my post. It was meant to say there are no kinks in the metal ring around the cylinder, but I left out the word "no". Shall I assume your opinions are still the same?
    Seems the best alternatives at this point are Athena instead of OEM.
      • 2107
      Yeah, I was looking at that. I didn't check the dimernsions to confirm if it is the standard cylinder bore.
      It's fascinating that it is reusable.
        • 1918
        Good heat transfer too. I never used one but they sure look good.
          • 8033
          Regarding the copper gasket. I have a set for my XS650 and I wanted to go with it. It was too thin. It would raise compression and possibly advance valve timing enough to cause concern for valve piston contact. I did install the copper base gasket and a Vesrah head gasket.
          That copper gasket is probably half the thickness of the OE gasket. If not, I’m a fan of the copper gasket. Otherwise, my first choice is a Vesrah head gasket, but I believe the Athena head gasket will be fine.
            • 8847
            The standard bore size is 71.5mm and the Wiseco 1196 is 74.5mm. The 1179 Wiseco is 74.0
              • 2107
              My last attempt was a Vesrah gasket and it looked the same as the original head gasket. It was really nice.
              After receiving the bent OE gasket, I will follow the advice of my good friends here and find another choice.
              I found a Yamaha OEM top end kit that includes a head gasket:
              https://www.ebay.com/itm/29795030497...&segname=11400
              The shape of the head gasket in the picture looks like it is the revised head gasket that does not require the extra seal around the cam chain tunnel.
              I took Deeb's advice and asked the seller to pack it well. They put the kit into a cardboard box, so it should a good chance to arrive undamaged.
              I'm taking a motorhome trip with the wife next week, so my next update might not occur until after May 16.
