starter clutch slip
  • Rasputin
    • 3193
    • Lacombe, Alberta, Canada
    #46
    (2H7-2139V-00-00) HOOK is the part number for the hook. Probably only going to find one thru Andreas or off a parts bike.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
      • 2011
      That's it! Thanks!
Name:	Opera Snapshot_2024-05-30_052131_www.partzilla.com.png
      • speedlimit85
        • Jan 2017
        • 449
        • Gainesville, Fl.
        #48
        A friend has a 650 with a starter clutch slip when it's hot instead of cold like mine. He changed his spark plug gap to .3 from .32 says now it starts every time. A small change can do a lot.
        He offered to maybe help me install the kickstarter on my bike.
        Can the clutch be removed with the big bolt in the middle or do all the small bolts and springs need to come out?
        80 G
          • 8894
          The 6 bolts that hold the pressure plate and springs need to come out first, then you will have access to the large nut..
            • 2140
            Make sure you turn each bolt a small amount, like maybe half turn, then turn the others the same amount. If you remove one or more bolts without balancing the others, you are likely to crack the star plate.
              • 8894
              Good point Mike, they can break rather easily.
                • 2140
                Same thing tightening them.
                  • 2011
                  Like they said, the pressure plate can crack if not loosened or tightened evenly. The M6 screw does not have to be Godzilla torqued. Just snug tight. It's steel in aluminum threads. Easy to damage.
                  • speedlimit85
                    • Jan 2017
                    • 449
                    • Gainesville, Fl.
                    #54
ID:	881375 Click image for larger version
ID:	881376 Great shop here put kickstart in and welded pipe again.
                    80 G
                      • 2011
                      Looks great! Even got the pinch bolt on.
                        • 8894
                        Awesome bro. Tell us, does your engine kick over pretty easily?
                        • speedlimit85
                          • Jan 2017
                          • 449
                          • Gainesville, Fl.
                          #57
                          Yea.I'm able to get it in a few kicks, Less choke and more throttle than starer button.
                          80 G
                            • 8894
                            I kind of recall kicking one once with a foldable kicker, and it seemed to be dangerously close to the side cover. I was afraid it would break if I hit it with my boot. Any clearance issues with yours?
                            • speedlimit85
                              • Jan 2017
                              • 449
                              • Gainesville, Fl.
                              #59
                              I was worried about the side cover but it's more up by the air box.
                              Good idea to push up the rear peg out of the way.
                              80 G
