78 Sidecar Project
    • 2011
    Install the rotors. Use Locktite blue on the bolts and torque. Then re-balance the wheel. It balances out perfect with no weights needed. Lucky.
ID:	879114 Click image for larger version
      • 2011
      Onto the calipers. Remove pistons (always fun) and clean aluminum oxide from here. Be VERY thorough.
ID:	879117 Click image for larger version
        • 2011
        New kits. Reusing my shims. Yes. They do exist.
ID:	879120 Click image for larger version
ID:	879121 Click image for larger version
ID:	879122 Click image for larger version
ID:	879123 Click image for larger version
          • 2011
          Back on the road.
            • 7818
            Easy way to get the pistons out, use a grease gun! If the piston does not want to move, put a 10mm bolt in the banjo fitting, turn the bleeder valve about 1/2 turn, and put a grease gun on the bleeder. Then pump the handle on the gun and you can see the piston move out! NO shooting across the shop like compressed air, and grease is pretty easy to clean up.
              • 8893
              I would go easy with the extra grease in the wheel bearings, overpacking sealed bearings may lead to overheating, so I've heard.
                • 2138
                I was thinking the same thing, but I didn't say it. I have overheated my trailer bearings by over packing them. Usually they spit the excess grease out the seals when they get too hot. You can feel they are too hot. After they have have settled in, then they run at a normal temperature.
                  • 2011
                  Good point, I will keep an eye on that. However, trailer wheels use a different type of bearing, spin much faster than a 19" wheel and have much more grease packed into them. My trailer leaks some grease as well. Has the typical "Bearing Buddies" installed. Not a very good seal. I guess they want an over abundance of grease to protect them from when you back them into deep water.
Name:	Opera Snapshot_2024-04-20_045329_www.ebay.com.png
                    • 2011
Name:	Opera Snapshot_2024-04-20_050210_www.youtube.com.png
                      • 2011
                      Lots of talk about this on-line. I will report back after a few thousand miles.
Name:	Opera Snapshot_2024-04-20_051231_bobistheoilguy.com.png
                        • 813
                        #101
                        I've got bearing buddies on my trailer, when I bought it the seals on the back side where blown out from too much grease so I replaced them and managed to blow those out too!
                          • 2011
Name:	fall in love.jpg
                            • 2011
                            Big swap meet today in Stafford.
ID:	879177 Click image for larger version
ID:	879178 Click image for larger version
ID:	879179 Click image for larger version
ID:	879180 Click image for larger version
                              • 2011
ID:	879184 Click image for larger version
ID:	879183 Click image for larger version
ID:	879185 Click image for larger version
                                • 2011
ID:	879188 Click image for larger version
ID:	879189 Click image for larger version
ID:	879190 Click image for larger version
ID:	879191 Click image for larger version
