78 Sidecar Project
    • 2011
    On the road middle of December.
ID:	876554 Click image for larger version
      • 2011
      Christmas Eve day on the road. On an XS11 "Down By The River".
ID:	876618 Click image for larger version
ID:	876619 Click image for larger version
ID:	876620 Click image for larger version
ID:	876621 Click image for larger version
        • 2011
        I got news. The road never ends.
          • 2138
          I always enjoy your pictures.
          You must have good internet speed. It would take me a week to upload those pictures.
          I love your license plate!
            • 2096
            This Thread is so " Old Skool Kool " I ain't never growin' up
              • 2011
              Out for breakfast New Years morning.
ID:	876773 Click image for larger version
ID:	876774 Click image for larger version
ID:	876775 Click image for larger version
                • 2011
                Back on the road. Not bad out for March. Falls Village ride.
ID:	878422 Click image for larger version
ID:	878423 Click image for larger version
ID:	878424 Click image for larger version
ID:	878425 Click image for larger version
                  • 2011
                  Falls Village CT.
ID:	878428 Click image for larger version
ID:	878429 Click image for larger version
ID:	878430 Click image for larger version
                    • 2011
                    On the road during the eclipse.
ID:	878870 Click image for larger version
ID:	878871 Click image for larger version
ID:	878872 Click image for larger version
ID:	878873 Click image for larger version
                      • 2011
                      Getting ready for the trip next month to XS East with a brake upgrade.
                      Here are the parts: New floating rotors, pads, caliper kits, banjo bolts, wheel bearings.
                        • 2011
                        Started with wheel bearings. Remove the seals. Always use heat to remove/install bearings as it is an interference fit. I use a split type bearing extractor. Once the outside metal is heated (warm not hot) they come out easy with a few taps.
ID:	879099 Click image for larger version
ID:	879100 Click image for larger version
ID:	879102 Click image for larger version
                          • 2011
ID:	879104 Click image for larger version
                            • 813
                            #88
                            I dunno, if was going to invest in floating rotors I'd probably go with genuine organic pads. The Sixities fit but seem a bit aggressive, at least on my stock rotors.
                              • 2011
                              New bearings have minimal grease. I always remove both seals and re-pack.
ID:	879108 Click image for larger version
                                • 2011
                                Heat it up and install the bearings and inner sleeve. If you forget the sleeve the bearings will wear quickly and you can die.
                                Once the bearings seat with a distinct "TINK" sound, you are ready to replace the speedo drive and new seals.
ID:	879111 Click image for larger version
