78 Sidecar Project
    • 1757
    LAB3, they consider any bike over 35 years old an antique. So for 2023 they would let in any bike 1988 or older for free. Next year my Harley will qualify to be an antique.
      • 754
      #47
      Been wanting to get up to New England for several years now but life keeps getting in the way. I'm hoping to do it next year, just like the last three!
        • 1757
        We will have to get together when you are here.
          • 1757
          Some sidecar suspension maintenance. This Chang Jiang unit does not have a swingarm or shocks. Its a torsion bar set-up like an old VW Beetle. It's a BMW military copy. The rod is spring steel and it twists to give you a few inches of travel. Had to use the heavy duty puller to get it apart and lube the sleeve bearing. There was a little wear but it works fine with very little play.
ID:	874772 Click image for larger version
ID:	874773 Click image for larger version
ID:	874774 Click image for larger version
ID:	874775 Click image for larger version
            • 1757
            Repaired. I also did a valve adjustment today.
ID:	874778 Click image for larger version
ID:	874779 Click image for larger version
              • 1757
              Enjoying the XS11 very much.
ID:	874827 Click image for larger version
                • 1757
                Working on 19" spare sidecar rim. Pretty bad.
ID:	874862 Click image for larger version
ID:	874863 Click image for larger version
ID:	874864 Click image for larger version
                  • 1757
                  Remove bearing pack and sand blast. Install new bearing pack and true rim. Always heat the bearing seat evenly. Freeze the bearing and use a tool such as a socket or bearing installer to drive it home without damage.
ID:	874867 Click image for larger version
ID:	874868 Click image for larger version
ID:	874869 Click image for larger version
ID:	874870 Click image for larger version
                    • 1757
                    Out on the road with my wife who puts up with a lot of motorcycle stuff.
                      • 724
                      Impressive work, as always Deebs. And a Lady in the side car too...Nice!!
                        • 1757
                        Thanks Bob
                          • 1757
                          Some more riding in between work. We ride about 300 miles every Sunday.
                          Click image for larger version  Name:	DSCN0939.JPG Views:	0 Size:	152.9 KB ID:	874915 Click image for larger version  Name:	DSCN0938.JPG Views:	0 Size:	134.7 KB ID:	874916 Click image for larger version  Name:	DSCN0946.JPG Views:	0 Size:	193.6 KB ID:	874917 Click image for larger version  Name:	DSCN0966.JPG Views:	0 Size:	199.4 KB ID:	874918 Click image for larger version  Name:	DSCN0969.JPG Views:	0 Size:	153.6 KB ID:	874919
                            • 1757
                            Another Sunday (With the Valkyrie)
ID:	874924 Click image for larger version
ID:	874925 Click image for larger version
ID:	874926 Click image for larger version
ID:	874927 Click image for larger version
                              • 1757
                              Restored spare wheel.
                                • 1757
                                New Dyna coils. New primary wires crimped.
ID:	874996 Click image for larger version
ID:	874997 Click image for larger version
ID:	874998 Click image for larger version
ID:	874999 Click image for larger version
