Rising from the ashes
  • Blank Slate
    • Nov 2013
    • 392
    • Ottawa, Ontario, Canada
    #121
    Thank you Mike for the measurements! Boltdepot also has a conversion chart so it should be dummy proof next time I walk in the fastener store to shop for bolts
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • mack
      • 2411
      • Ontario, Canada
      #122
      Pablo
      Order two sets, I'm working on my spare motor and my bolts need to be replaced as well.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • Blank Slate
        • Nov 2013
        • 392
        #123
        ________
        10-4 Mack
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
        • Blank Slate
          • Nov 2013
          • 392
          #124
          I think your clutch cover is getting jealous.
          I gave the cover some love today
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
          • Blank Slate
            • Nov 2013
            • 392
            #125
            6 months ago it looked like this
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
              • 1244
              • Peachtree City, Georgia.
              #126
              Great Work.... Nice to see another getting saved.
              Originally posted by Blank Slate
              Or can of spray paint
              Blank Slate,
              I've been following along (from the sidelines) and your bike is looking EXTREMELY GREAT.
              RE: The Yamaha recessed lettering.... For what it's worth.... I spray a little puddle of rattle can paint into the spray can cap and then use a tooth pick to drip some into the cover lettering (off the bike on a work table) and spread it into all the nooks & crannies with the tooth pick. Let it dry a couple hours and put it back on.... That's what I do....
              Respectfully,
              Kurt
              • Blank Slate
                • Nov 2013
                • 392
                #127
                Thank you Kurt, Nice tip Too. I will try it on the alternator cover, the circle surrounding the lettering needs some black.
                I had quite the adventure putting a throttle sleeve into my fancy chrome grips. First sleeve broke off, 2nd ended up slicing my finger, but I am persistent and finally shaved off an inch off the bottom end to make it fit.
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                • Rasputin
                  • 3189
                  • Lacombe, Alberta, Canada
                  #128
                  I guess it is a bit late for this, but I add washers to the hand grips tofill the gap. It also makes bar end weights. This seems to help with bar vibration as well as fills the gap between bar end and grip end.
                  2-79 XS1100 SF
                  2-78 XS1100 E Best bike Ever
                    • 2054
                    It's happy now!
                    • mack
                      • 2411
                      • Ontario, Canada
                      #130
                      Pablo
                      we left the carbs off so you can get the back of the motor to look like this. Stop typing and get back to work!
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                      • Blank Slate
                        • Nov 2013
                        • 392
                        #131
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                        • Blank Slate
                          • Nov 2013
                          • 392
                          #132
                          Holy sweetness! Well I have been spending lots of time on cleaning the bikes. My gf said "now I know how Grant's wife feels".
                          I'm in trouble
                          Frame: 79 XS1100S
                          Engine: 81 XS1100S
                          Carbs: 78-79 BS34
                          Gf bike: 78 XS650S
                          Carbs: 70-79 BS38
                          • Blank Slate
                            • Nov 2013
                            • 392
                            #133
                            Started cleaning the towers with some bio friendly paint stripper. It's more of a degreaser imo. I sprayed it and brushed btwn the teeth.
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                            • mack
                              • 2411
                              • Ontario, Canada
                              #134
                              Pablo
                              All kidding aside, your doing a great job. But you have all winter, so take it from me, look after your domestic responsibilities first, then sneek out for an hour or two when she is engrossed in a chick flick or shopping. But as far as her 650 is concerned, have her do some of the work herself. Thats all part of owning and riding a bike. You have to train them OR they will train you!
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
                              • Blank Slate
                                • Nov 2013
                                • 392
                                #135
                                Got the ss bolts. I put a few on the bike and wow, what a difference.
                                Frame: 79 XS1100S
                                Engine: 81 XS1100S
                                Carbs: 78-79 BS34
                                Gf bike: 78 XS650S
                                Carbs: 70-79 BS38
