Rising from the ashes
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    #196
    Or easier, put bike on sidestand, pull clutch cover and then clean the glass. I used B12 chemtool on a Qtip to clean it. Do NOT spray just anything at it, as there is an O ring sealing the glass and you do NOT want to have it swell or decompose.
    good point on the orings Ray
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
      #197
      What we're saying is that you need to clean the site glass from the INSIDE of the clutch cover, that's why putting on the sidestand pulls the oil away from it. THen you could get some long Q-tips, or rubber band them to a long stick or piece of clothes hanger or wire, to allow you to get a good angle to get to the view glass. Spritz the Q-tip with the carb cleaner first. Often it's just gum/varnish, SLUDGE that sticks to the glass on the inside and prevents viewing. Once you get it off, you should be able to view the oil level much better.
