Rising from the ashes
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    #151
    Hi Blank Slate,
    Send a PM to Andreas he has one or more. Give him your address and he will quote a price to your door. Advantage is he is in BC so no border to cross with all the complications that can entail.
    You might have to wait a few days for a reply as I recall he was off racing ,fishing or drinking maybe all three for a few days
    Yes he's my fav vendor. I know him well.
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
      #152
      Originally posted by Blank Slate
      My center stand is bent. See pic below. I was going to put it in a vice grip but I doubt I have strength to bent it back. I thought about hammering away at it but that could damage it. Suggestions? It was bent when I got it new. Prob should have returned it then.
      Hey Blank,
      Your centerstand looks normal to me, what makes you think it's bent??
      Here are a couple of photos of that similar style stand, and it looks just like yours.
      This lower picture is of mine after I extended them a few inches due to my extended front fork tubes and the higher position my frame sits vs. OEM.
      The part that you push down on with your foot is supposed to have that bend in it to allow it to fit up around the STOCK exhaust pipe that would normally be on that side! Without it, you have a big space there, and so that part of the stand can look BENT, but it's how it's supposed to be!
      • Blank Slate
        • Nov 2013
        • 393
        #153
        This looks like my stand
        My stand might be all right, I thought it had a bend because the bar doesnt lay flat on the ground like other centerstands I've seen. But the bike is stable so maybe I shouldn't worry.
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
        • Blank Slate
          • Nov 2013
          • 393
          #154
          This is my centerstand. A normal stand has three contact points to the ground and I have two
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
          • S1Loki
            • 11
            • Cabot, Ark.
            #155
            Blank,
            My current '82XJ does the same thing with its center stand
            '82 XJ11
            '02 Triumph Trophy
            '97 Buell S1 Lightning
            '92 Buell RS1200 (WestWind)
            '82 KZ750R1 (GPz)
              #156
              Okay,
              Well, now we can see what you're talking about. But you're right, the two foot pads should be touching the ground. It looks like someone really hefted on the foot lever portion one time trying to get the bike up on the CS and did bend it a bit!? You could take it off and mount it in a vice, and then get a nice long piece of pipe, or a large/wide deep socket and extension(s) to give you some leverage and fit over the foot lever pad and then bend it back just enough to allow the CS base footpad to be able to make contact and not the foot lever pad.
              • Blank Slate
                • Nov 2013
                • 393
                #157
                I'll give it a shot Top Cat. If not buy a new one.
                I've been having fun with paint, been doing the frame bit by bit with this stuff. Not sure how long it will last but the black gloss is to my liking.
                Wonder if I can do the wheels with this rattle can too
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                • Blank Slate
                  • Nov 2013
                  • 393
                  #158
                  Regulator from geezer
                  "Nate Dogg and Warren G had to regulate"
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • mack
                    • 2411
                    • Ontario, Canada
                    #159
                    Regulator
                    You might have to turn it around 180 degrees for the tank to sit down properly.
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
                      Yikes!. Bend it up cold(no heat) by slipping a piece of pipe large enough to go over the foot piece. Slip it up close to where the normal bend is and pull up on the pipe till centerstand piece hits the floor before the foot piece does. Gradually rock against the part your bending so the metal molecules have a chance to move with the bend. This is done that way so as not to weaken where bend takes place. Just some advice from a certified welder and metal urgeast training. I'd get a bit of help holding right side of bike. Also, when correctly on centerstand it's normal for majority of these 11's to be of center a half a bubble set across the top of the four carbs. No concern unless checking actual bowl fuel levels, which entails a small piece of rubber belting under right side of stand to square it up.
                        Resist nicks and scratches VERY well! masking off the outer polished portion of wheel,again an excellent choice of paint! Dupli-Color is hard to beat, especially for your touch up choices! BTDT!
                        Tuff durable paint!.......Excellent choice.
                        • Blank Slate
                          • Nov 2013
                          • 393
                          #162
                          Thanks Motoman
                          I got the nastiest migraine yesterday after spending a half hour painting the wheels with no mask. Lesson learned the hard way.
                          Re: the centerstand. If someone helps me hold the bike up on the right side, I can attempt to bend the bar with it still attached to the bike? That would be convenient because it was hard work getting that spring on.
                          Mack: 180 degrees you say... I knew that. Just seeing if you were paying attention
                          Frame: 79 XS1100S
                          Engine: 81 XS1100S
                          Carbs: 78-79 BS34
                          Gf bike: 78 XS650S
                          Carbs: 70-79 BS38
                            I would just get another centerstand. I have tried to straighten one before and it is not an easy task. For sure I would not try straightening it on the bike and risk damaging the frame mounting tabs. JMHO
                            • Blank Slate
                              • Nov 2013
                              • 393
                              #164
                              I didn't think of that. I cringe when I think what I would havedone to the bike without this forum.... Oh that's right, I was gonna sell it
                              Frame: 79 XS1100S
                              Engine: 81 XS1100S
                              Carbs: 78-79 BS34
                              Gf bike: 78 XS650S
                              Carbs: 70-79 BS38
                              • Blank Slate
                                • Nov 2013
                                • 393
                                #165
                                i hated polishing at first but now I enjoy doing a little bit every day
                                this is what the covers used to look like
                                Frame: 79 XS1100S
                                Engine: 81 XS1100S
                                Carbs: 78-79 BS34
                                Gf bike: 78 XS650S
                                Carbs: 70-79 BS38
