Rising from the ashes
  • Blank Slate
    • Nov 2013
    • 392
    • Ottawa, Ontario, Canada
    #106
    Originally posted by mack
    I didn't realize how good those headers I gave you were. They look sweet!!!
    Huge improvement over the old 4-1
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • mack
      • 2411
      • Ontario, Canada
      #107
      Post
      another picture more from the side so that we can see the hangers and the weld connection Pablo.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • Blank Slate
        • Nov 2013
        • 392
        #108
        Frame: 79 XS1100S
        Engine: 81 XS1100S
        Carbs: 78-79 BS34
        Gf bike: 78 XS650S
        Carbs: 70-79 BS38
        • Blank Slate
          • Nov 2013
          • 392
          #109
          Sanding and polishing time
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
          • mack
            • 2411
            • Ontario, Canada
            #110
            Pablo
            Look here:
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • tomcos67
              • Apr 2015
              • 311
              • Amsterdam, N.Y.
              #111
              That's impressive.!!! Thanks for tip..!!
              1980xs1100.sg Pacifica Fairing ..stock.
              2006 Honda Shadow Spirit 1100.! ⛺
              • Blank Slate
                • Nov 2013
                • 392
                #112
                Awesome Mack
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                • Blank Slate
                  • Nov 2013
                  • 392
                  #113
                  Not bad for 30 minutes of work?
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • tomcos67
                    • Apr 2015
                    • 311
                    • Amsterdam, N.Y.
                    #114
                    On the side covers I usually just use black sharpy ,put the black back in Yamaha ,works fine.
                    • HalfCentury
                      • 408
                      • Burlington NC
                      #115
                      Did you soda blast? If so, how much soda did you use?
                      82 XJ1100 - sold
                      96 Honda Magna 750 - Girlfriend's bike
                      2000 ZRX1100 - sold
                      2003 FJR1300 - Silver rocket
                      • Blank Slate
                        • Nov 2013
                        • 392
                        #116
                        Some guy down the street from me does restoration work and said bring a cover to me and I'll show you how its done. First he used a belt sander to get the deep scratches at the bottom of the cover level. Next gave me a rag and paint remover to scrub the paint off. Then he used a scotch-brite pad and finally a he worked it againsta polishing wheel while applying chalk to the pad. At least that's what I remember the steps being. He said he could put a coat on it when it's done.
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                          • 6762
                          #117
                          Lookin' good Pablo...
                          • Blank Slate
                            • Nov 2013
                            • 392
                            #118
                            Thanks Ben.
                            Been working on the covers and shining up the bolts. Had the idea of buying stainless steel ones but I'm not finding a complete list of measurements for them. I went to a specialty store with my measurements and bought 6 types of bolts, none of them fit. Thread size was too small. Imperial metric, I measured in cm's, the store has inches, man I give up and will just dremmel the existing ones as best I can lol
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                            • Blank Slate
                              • Nov 2013
                              • 392
                              #119
                              Or can of spray paint
                              Frame: 79 XS1100S
                              Engine: 81 XS1100S
                              Carbs: 78-79 BS34
                              Gf bike: 78 XS650S
                              Carbs: 70-79 BS38
                                • 2123
                                Alternator Cover is Beautiful
                                Pablo:
                                I think your clutch cover is getting jealous.
                                About the SS bolts:
                                This post contains a list of the bolt sizes from Crazy Steve:
                                I had lots of help from the community deciding to go stainless:
                                I got my SS bolts online from BoltDepot.com
                                26 pcs 6mm x 35mm @ $0.29 -> $7.54
                                26 pcs 6mm x 25mm @ $0.22 -> $5.72
                                14 pcs 6mm x 20mm @ $0.21 -> $2.94
                                Total $16.20 + $11.01 shipping (ouch) = $27.21
                                Don't give up you really want to go SS!
