Street fighter/ Bobber build 2.0
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    #241
    Lose the mirrors (bobbers don't have em), get some black fork gaiters to cover up them skinny legs and lower headlight a few inches (street fighter). But that's just how I would finish it off. Square gauges are retro which I think is cool. Like paint choice.
    Great work!
    Rob - 79 SF
    • Fearthepack
      • May 2012
      • 255
      • Orlando, Fla.
      #242
      I have to admit my skeptiscism initially but I wholeheartedly agree with Marco...you have achieved what few actually set out to accomplish. I am a purist at heart however I must say I wouldnt mind owning and riding this one...IMO keep the gauges and mirrors...I dont think they detract from the look....my hats off to you
      Thank you sir! That means a lot coming from your respected crowd. i must admit i have a purist streak but an even wider perfectionist streak the combination always turned it into a endless train wreck.....No amount of work, pristine original parts, amount of shine was ever good enough to be seen in public....
      So prier to this adventure a wise bird (paid professional) suggested I incorporate levels of fit and finish into my project (therefor planed) imperfection at different levels in order to keep moving forward. So I picked a few items that had to be perfect #1 balance #2 non stock #3 paint #4-20 I picked different levels of finish.....I must admit I had a blast and the advise kept me moving forward...
      1979 F worst one i could find
      to convert into a bobber/ streetfighter!
      _________________________________
      We can't all get along!
      • Fearthepack
        • May 2012
        • 255
        • Orlando, Fla.
        #243
        Great work!
        Retro! U smart that's the term I was looking for....Black gators I have, put them on and off, on and off they upset the balance in my opinion. Now if I could get just the chrome coil springs like the rear shocks that maybe the bomb.
        What if we gave it a new category (style) then I could keep the Mirrors LOL
        Maybe: SLobber
        Fighting Bobber
        Strobber
        Streetbob
        Just having fun! Streetbob does have a certain ring I must say LOL
          • 6762
          #244
          Maybe: SLobber
          Fighting Bobber
          Strobber
          Streetbob
          sounds like a Hardley Ableson...
          • Fearthepack
            • May 2012
            • 255
            • Orlando, Fla.
            #245
            Your right...Damn there are no more original ideas...
            • Fearthepack
              • May 2012
              • 255
              • Orlando, Fla.
              #246
              OK, back to the business end of this build.... took 6-7 rides around the block adjusting the air/ fuel mixture screws not much luck....
              1.butterflies all synced with motion pro style sync tool
              2.got a great smooth idle
              3.Breaks up at roughly 4000 rpms no matter air /fuel settings
              2.00,2.25,2.50,2.75,3.00 turns out from lite seat
              4. tach seems fine (acurate) while not moving but wants to jump from 2000 to five and 3000 to 6000 rpms while going down the road
              5. Light backfire trough carbs and tail pipe
              6. I could see backfire in clear sycn tube on #1 vacuum fitting seemed to go away when all butterflies got synced
              7. Nice acceleration from 2000 to 3500 then flat
              For the life of me I don't remember and no pics show it but don't know if I removed and cleaned the Venturi tube (needle jets)
              Looks like I get to dive back into carbs anything else I should look for while in the carbs?
              Also the front @%^&*(##@$%^@#%@$@%bitchen brakes still have air in them. My nemesis
              Also torqued the head bolts, oil pan, ACCT, and valve cover bolts all needed attention after getting it hot. Didn't really expect that.
                • 7765
                Check your float height. IF the fuel level is about 1.5mm low, you will run out of fuel at about 3-4K. DAMHIK. Also, check the main jets while you are in there. Seems like it isn't getting the fuel it needs, or maybe way too much fuel, and black plugs.
                As an aside, I always check the sync at 4K RPM once the idle is correct, just to make sure the carbs stay working together.
                Front brake, when parked for the night, use a bungie to put on the front brake for the night. It will help the air to float to the "top".
                • Fearthepack
                  • May 2012
                  • 255
                  • Orlando, Fla.
                  #248
                  Plugs as follow:
                  #1 Dry and sooty
                  #2, #4 between just normal to almost wet
                  #3 Nice, slight brown
                  Not run sense Tuesday
                  I set All floats from top of gasket to top of each side of float to 25.7mm or 1inch will recheck.
                  Will Try the front brake trick, little SOB.
                    ... I set All floats from top of gasket to ....
                    If you really did set the floats from the top of the gasket and not from the carburetor body gasket surface then the floats are wrong.
                    The floats are too high by the thickness of one gasket when the carburetors are upside down and that makes them too low in the float bowls and too lean when the engine is running.
                    Take off the gaskets and reset the floats. I know, that's easy for me to say.
                    • Fearthepack
                      • May 2012
                      • 255
                      • Orlando, Fla.
                      #250
                      Thank you I will take your suggestion to task
                      • AggiesaurusRex
                        • Apr 2016
                        • 57
                        • Orlando, FL.
                        #251
                        Did this ever get running smoothly?
                        80G
                        • Fearthepack
                          • May 2012
                          • 255
                          • Orlando, Fla.
                          #252
                          Back in the saddle again....LIFE is what happens to keep you from completing projects sad put true...I got the bike out of storage again and onto build 3.0.
                          Took the carbs apart very clean still, did find a clog in the float bowl vent of number 2 carb.... reset all the float levels they were way rich which should explain the sooty black plugs. Fired right up but wow the belching of raw gas out the tailpipe so rich. I'm running pods and 4 into 1 with small barely a muffler. took the carbs back apart and finally, finally, finally, finally found I was missing the 4 large screw plugs at the bottom of each pilot jet stack. I can only imagine how much gas was being sucked up the through the pilot jet. Installed the missing screws,Started back up and what a difference, no visible signs or smell out the tailpipe. Now onto dialing it in with sync gauges. Small battle won. Hurrah Looks like time off gave me usable wisdom.
                          • xs11lover
                            • 1433
                            • Montoursville Pa
                            #253
                            Pretty cool!
                            79 XS11 Special (Lazarus)
                            79 DT 100
                            • Fearthepack
                              • May 2012
                              • 255
                              • Orlando, Fla.
                              #254
                              I'm using modified pods on the carbs so what should be done with the carb tubes that would have run to the stock air box. They are just above the fuel intake connectors. Nothing or do they need capped? hope i explained that good enough...
                                • 8798
                                Leave them open as they are bowl vents. Capping them will result in a flooding condition.
