Rear Wheel Help
    • 9980
    OK, I just had one of the moments. ( that scares me sometimes).
    You did work on the trans right? When you put the shift forks back in did you put them back in the correct order? They are marked 1 2 &3.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      I think I put them in the correct order. Would the trans shift in and out of gear if I had misplaced the shift forks? I don't seem to have any problems shifting by hand in and out of gear.
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        • 9980
        It would shift but it might hang in some gears and not go completely into others.
        I went out to look at the order, left to right or right to left, but I don't have a parts engine I can easily get that info with. I THINK #1 is the closest to the clutch but I'm not sure. I never made a note of it. I bet someone here knows off the top of their head though.
        Like I said, you can drop the pan and oil pump and see what's going on.
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #34
          Can I drop the pan without taking the engine out? It is currently on a bike lift. If I remove the clutch and the counter shaft would I be able to rotate the trans by hand. I remember spinning the transmission by hand before I buttoned everything up. It rotated by hand very smoothly. I am stumped because everything spun by hand. Now that I have everything put back together it gets jammed up. Very frustrating. I just don't want to disassemble everything if I don't need to. However, if the trans needs work I guess I have no other option.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            • 9980
            Very hard to say EXACTLY what the issue is without looking at it in front of me.
            With the clutch off the transmission is disconnected from the engine completely so it will spin freely in gear or not. It would only bind if it was in 2 gears at once assuming there was no other damage.
              • 8798
              Shift forks 1-2-3 Left to right with wheels on the ground.
                • 9980
                Oh, I forgot to say, yes the pan can be removed with the engine in the bike. The 2nd and 1st gear fixes can be don with the engine in the bike.
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  #38
                  So the trans spinning by hand with the clutch off does not necessarily mean there is no trans problem? Is that correct.. The trans can spin freely even if the shift forks are in the wrong order?
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                    • 9980
                      • 9980
                      Thanks Phil.....
                      • TheRev
                        • Jun 2012
                        • 235
                        • Madison, Wi.
                        #41
                        So here is what I think I should do. Remove Exhaust, rear wheel, final drive. Unbolt the middle drive and remove the shaft. Remove the rear swing arm.
                        Then I should try to rotate the shaft and the final drive. If it rotates freely then I assume there is no problem..
                        Then I should try to rotate the middle gear drive. If that is bound up I should remove the clutch and see if that frees up the middle gear drive. Is that correct? If by removing the clutch and I still can't rotate the drive then I need to dive into the transmission. Is that correct?
                        Please let me know if I am missing something.
                        1979 xs1100f
                        New Fuse Box
                        Progressive Shocks
                        Gold Valve Emulator
                        Dyna Coils
                        Electronic Flasher
                        Led Headlight
                        Led Turn Signals
                        2nd Gear Fix
                        Auto Cam Tensioner
                        Digital Dash
                        Stainless Bolt Kit
                        Maier Fairing
                        Spin On Oil Filter
                        Plasti Dip Rims
                        ISO Grips
                          • 9980
                          There's no reason to remove the swing arm or any of that. Just taking the 4 bolts out of the U-joint will disconnect it from the middle drive back. That's what we have all been trying to tell you.
                          When you put it into 1st and it makes a terrible sound, is the sound coming from the transmission or the middle drive?
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            #43
                            I couldn't tell where the sound was coming from. I turned off the engine ASAP. It sounded like a bag of rocks and the rear wheel was "jerky" in it's movement. I will remove the bolts as described without taking off the swing arm.
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              #44
                              Does anyone think it might be a clutch problem? That would be easier to fix then pulling the transmission apart.
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                              • CaptonZap
                                • Jun 2010
                                • 1748
                                • Denver
                                #45
                                The first step in a problem solving exercise is a good visual inspection. Most mechanical problems can be seen.
                                Drain the oil, take the right side cover off and watch the clutch action when you pull the hand lever. Rotate the wheel.
                                Still no joy?
                                Take the bottom off, lay down and crawl under with a bright light, and shift with your hand and watch the action.
                                While you are under there, rotate the wheel back and forth and see how far back up the drive train there is motion. This assumes that you put the u-joint back together.
                                No need to pull the tranny until you know what the problem is.
                                CZ
