Rear Wheel Help
  • rdmcguy
    • Jul 2013
    • 515
    • Denver, Colo.
    clutch
    Not to ask an obvious question but have you tried to pull in the clutch lever?
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      I am not sure what the washer swap for the 2nd gear fix is. I ground down the dog ears like in the 2 gear fix thread. I have tried to pull the clutch lever which is not a dumb question. All questions when diagnosing a problem are helpful. Thanks
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        • 9980
        THIS is what the washer swap is. I was asking because when I did it on my SF the dogs had a little issue with dragging a bit when in neutral but wasn't an issue when I got the thing on the road.
        Have you tried taking the bolts out of the u joint/middle drive union yet to see what happens?
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          Thanks for the input. I haven't tried taking the bolts out of the u joint yet. I will do that this week. I didn't do the washer swap. I will read about that. Perhaps I should have done that when I had it all apart. Thanks for the advice. I appreciate all the help.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            • 9980
            Yes, you absolutely should have.
              Hey Rev,
              To do the 2nd/1st gear Dremel fix, you had to pull the clutch basket off/out. Did you take the clutch basket apart....pull the boss assembly, pull the frictions and steels out, inspect, clean/de-varnish/de-glaze the steels and reassemble? IF so...or at least pulled the plates out/apart, then they aren't STUCK.
              As for the washer swap....many folks have done the Dremel fix and did not swap the washer, and have been running fine for years/10's k miles! Spilt milk now, don't worry about going back in to do it. Yes, it's recommended as part of the fix to help keep the 2nd gear better engaged with the 5th gear, but there's a decent amount of engagement of the dogs/slots with the OEM setup and a good undercutting....the undercutting helps to pull/keep the gears together under stress/load. On a relatively virgin(low miles) engine doing the washer swap alone "could" help prevent the skipping from occuring to begin with.
              If you decide to remove the final drive....you should be able to turn/rotate the drive at the axle end by hand!
              I'm curious to see how you mounted your Dig Gauge cluster, I just posted my amateur attempt in my "questions/gauges" thread.
              • rdmcguy
                • Jul 2013
                • 515
                • Denver, Colo.
                While I am thinking about it
                Another thought that comes to mind.
                Perhaps it got nudged into gear by someone?
                A Kid,you ,buddy playing a prank?
                  Or maybe pushing down the shifter, thinking you've got it into 1st because it didn't click any more gears, but without spinning the rear tire/transmission, it actually never got to first and therefore never got to neutral when you clicked it up?
                  • TheRev
                    • Jun 2012
                    • 235
                    • Madison, Wi.
                    That is very possible, although the neutral light is on.
                    1979 xs1100f
                    New Fuse Box
                    Progressive Shocks
                    Gold Valve Emulator
                    Dyna Coils
                    Electronic Flasher
                    Led Headlight
                    Led Turn Signals
                    2nd Gear Fix
                    Auto Cam Tensioner
                    Digital Dash
                    Stainless Bolt Kit
                    Maier Fairing
                    Spin On Oil Filter
                    Plasti Dip Rims
                    ISO Grips
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      Hey Rev,
                      When I took the final drive apart I was able to rotate the drive by hand. In fact it was not difficult at all. I am wondering if I should start the bike, shift into first, and gently let out the clutch until i get the rear tire to spin slowly. Perhaps that will free up any binding. What do you think?
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • XS11UFO
                        • May 2012
                        • 74
                        • Palatka, Fla.
                        Man, it's only 4 bolts to isolate the issue, either way could cause automatic disassembly. I wouldn't on my bike.
                        Scott
                        1978 R100S BMW
                        • TheRev
                          • Jun 2012
                          • 235
                          • Madison, Wi.
                          Great Point. I have been working on this bike for two years. I just need to be patient and sort out all the little problems. I will remove the four bolts and check the middle drive. I am almost positive that the problem is not the final drive or the shaft because I have had those apart and they rotate freely.
                          1979 xs1100f
                          New Fuse Box
                          Progressive Shocks
                          Gold Valve Emulator
                          Dyna Coils
                          Electronic Flasher
                          Led Headlight
                          Led Turn Signals
                          2nd Gear Fix
                          Auto Cam Tensioner
                          Digital Dash
                          Stainless Bolt Kit
                          Maier Fairing
                          Spin On Oil Filter
                          Plasti Dip Rims
                          ISO Grips
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            Ok, I am almost certain that the final drive and the shaft are fine. When I remove the four bolts off the middle drive am I supposed to be able to rotate the middle gear somehow? If the middle gear doesn't rotate what does that mean? Would I need to remove the engine and rework the transmission? That would be awful since I thought I was so close to being done? I should probably add that I have never worked on the middle gear before, so nothing has changed with that. I have however had the transmission apart to do the second gear fix. I also had the clutch out of the bike while doing the second gear fix. The clutch however feels fine. I can shift into various gears by hand without a problem. I am beginning to think this is a full blown transmission problem which would mean I have to remove the engine and begin at square one. I am going to need this forum more than ever to figure this out?
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              • 9980
                              Ok, I am almost certain that the final drive and the shaft are fine. When I remove the four bolts off the middle drive am I supposed to be able to rotate the middle gear somehow? If the middle gear doesn't rotate what does that mean? Would I need to remove the engine and rework the transmission? That would be awful since I thought I was so close to being done? I am going to need this forum more than ever to figure this out?
                              It means you have a problem at the middle drive or transmission. Most likely the transmission in this case I would guess.
                              It won't free up with the shifter in any position/gear?
                              You should be able to drop the oil pan and oil pump to see what the issue is.
                              • TheRev
                                • Jun 2012
                                • 235
                                • Madison, Wi.
                                I shifted into first and gently let out the clutch and it sounded awful.
                                1979 xs1100f
                                New Fuse Box
                                Progressive Shocks
                                Gold Valve Emulator
                                Dyna Coils
                                Electronic Flasher
                                Led Headlight
                                Led Turn Signals
                                2nd Gear Fix
                                Auto Cam Tensioner
                                Digital Dash
                                Stainless Bolt Kit
                                Maier Fairing
                                Spin On Oil Filter
                                Plasti Dip Rims
                                ISO Grips
