Rear Wheel Help
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Rear Wheel Help
    Hello All
    I have my bike on the bike lift in neutral. I can rotate the rear wheel only a few inches but it won't spin freely. Isn't it supposed to spin freely? I am finishing a complete frame off rebuild so I am not quite sure what to expect. However, if the bike is in neutral shouldn't the rear wheel spin?
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
  • rdmcguy
    • Jul 2013
    • 515
    • Denver, Colo.
    Dragging rear brakes?
    My first guess would be a rear brake issue,
    # 1 try loosening the bleeder valve or #2 remove the caliper completely
    From there I would continue to move forward as needed ...hub,Differential,shaft, middle drive etc..
    Keep after it
    Joe
      When you spin that rear wheel in neutral you are spinning, 1 the wheel, 2 the final drive, 3 the driveshaft and U-joint, 4 the middle drive, 5 a portion of the gears in the transmission.
      And most of those components are bathed and/or submerged in thick oil.
      The shaft drive system isn't the most free wheeling type of drive, but definitely the smoothest.
      Chain drive is the most free wheeling with the least resistance but certainly NOT the smoothest or maintenance free.
      If it seems to tight check the rear brake caliper for binding.
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        When it comes to the point that it won't go past, is there a metal to metal feel, or just a tightening to the point of not turning?
        If there is a thunk and each end of rotation, it is mechanical drive, if it is tightening, it is probably brakes.
        Since you are stripping the bike anyway, take the drive train apart, and inspect all the components for wear, and any problems will be apparent.
        CZ
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          I know it's not the brake because I don't have that installed. Also, it moves a few inches then it stops. I haven't tried to force anything for fear that the bike might slip on the lift. When I first assembled the bike after the rebuild it wouldn't move at all. So I took the wheel off, dismantled the final drive, pulled the shaft and inspected all. I then reassembled the final drive and put it all back together. Now I at least get some movement which is good, but I am not sure it is enough. Shouldn't I be able to spin it by hand? I have never ridden the bike because it was in such bad shape when I got it so I don't know what is normal.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            One way to check if it's in the final drive or drive shaft is to take out the 4 bolts that fasten the u joint to the middle drive. If it turns then the issue is in the middle drive or the transmission.
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              Heh Greg,
              The old "two gears at once " problem?
              2 inches sounds about right for drive train slop.
              CZ
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                You mean if the shaft and the final drive turn after I disconnect it from the middle drive?
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                  Heh Greg,
                  CZ
                  Yeah but if you read the first post he says it's in neutral CZ
                  Yes, exactly.
                    If it's sat for any length of time, the clutches can stick together. Even in neutral, this wouldn't let the wheel move any more than the lash in all those components Greg mentioned, since the discs can't slide against each other. Lots of people have had to break those loose.
                      In neutral the clutch is taken out of the equation Tod.
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        Broken shift fork, leaving a gear engaged?
                        Since he has never ridden the bike, and we don't know what "rebuild" entails, TRBIG may have the answer.
                        CZ
                        • TheRev
                          • Jun 2012
                          • 235
                          • Madison, Wi.
                          When I rebuilt (2nd gear fix) the shift forks and gears were all in good shape. Everything rotated as it should before I buttoned everything up and installed the engine. I am going to check the middle gear drive this week. I am interested in hearing more about the clutch plates sticking. Is there a way to check that, or repare if necessary? Thanks
                          1979 xs1100f
                          New Fuse Box
                          Progressive Shocks
                          Gold Valve Emulator
                          Dyna Coils
                          Electronic Flasher
                          Led Headlight
                          Led Turn Signals
                          2nd Gear Fix
                          Auto Cam Tensioner
                          Digital Dash
                          Stainless Bolt Kit
                          Maier Fairing
                          Spin On Oil Filter
                          Plasti Dip Rims
                          ISO Grips
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            How do I break the discs loose?
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              Did you do the washer swap when you fixed 2nd gear?
