Rear Wheel Help
  • XS11UFO
    • May 2012
    • 74
    • Palatka, Fla.
    #46
    From your post about running the engine and hearing rocks crushing when you released the clutch, it sounds like your clutch was doing what it was supposed to do. After the rock crusher though, I would check the oil and filter for metal, I'd be surprised if there isn't something broken now.
    Scott
    1978 R100S BMW
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      #47
      Great News!
      I i don't think my transmission or clutch is the problem. I removed the exhaust, rear tire and swing arm. Then I rotated the middle gear joint and it rotated fine. No noise or resistance. So I started the bike and shifted into gear. The transmission shifted smoothly and the clutch worked fine. Absolutely no noise like crushing rocks. So I think the problem is in the final drive. What do you all think?
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        #48
        Hey Rev,
        Well, it sounds like you've finally isolated the problem, and that it sounds like it's the FINAL DRIVE. Did you ever separate the final drive from the swingarm during your rebuild to clean and regrease the driveshaft/FD junction?? You will probably find worn or broken splines on the driveshaft where it mates to the FD. With the FD separated from the swingarm, you can then rotate the rear wheel drive hub and see/feel the driveshaft hub rotate and vice versa, and if they feel smooth, then it would indicate the worn/broken driveshaft splines....at the FD junction moreso than the Middle Drive Ujoint yoke.
          Hey Rev,
          Had you previously had final drive apart, or just removed? In your earlier thread it was hard to depict which.
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            #50
            Hey Rev,
            I did separate the final drive from the shaft. I also took the final drive apart to clean it. My guess is I didn't put it together correctly. I was considering doing the xs750 final drive mod earlier in the build but didn't want to add that expense.. I guess i can do that now. I haven't yet looked at the shaft. I would not be surprised if it is trashed.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              #51
              I had removed the FD must not have put it together correctly. I purchased a xs750 drive so I could do the Final Drive Mod.
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
                You need to pay close attention to the mod procedure on the 750 FD, especially if you have the type 1 unit.
                Read the mod procedure carefully and follow the instructions carefully on the torque specs.
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  #53
                  Hey Rev,
                  I had some time tonight so I cleaned up the final drive to inspect everything. I figured out what I did. I forgot to install the spring that helps the shaft stay in the middle drive yoke. The splines on the shaft and the final drive look fine. I didn't see any metal shavings at all. I rotated the final drive and it felt smooth. Then I looked at the middle drive yoke and saw some signs on the swing arm that indicated the shaft was not engaging the middle drive ujoint yoke properly. Perhaps the shaft pulled out and was bouncing around a bit within the swing arm. Probably because of the missing spring. I added the spring and put it all back together. I haven't started it yet because of the late hour but my hope is it runs smoothly this time. Any advice?
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                  • TheRev
                    • Jun 2012
                    • 235
                    • Madison, Wi.
                    #54
                    Ok, I still need help. I bought a new xs1100 final drive, although my origional one looks ok. I put the new final drive on the swing arm and this time put it all together correctly (this time I made sure the spring was installed). When I put the wheel on and shifted into neutral and spun the rear wheel by hand. Once again it had resistance. This time I pulled the rubber boot back and saw that the U Joit was hitting the edge of the swing arm rim. So when I spin the wheel while watching the u joint the bolts on the u joint rubs against the swing arm rim and that is what has been causing the "chunking" sound.
                    So I pulled the wheel off and the swing arm and looked at the swing arm rim. Sure enough, the swing arm rim had gouges in it from the u joint rubbing. Clearly this is what my problem is. Here's my question, why is the u joint hitting the swing arm? Could it be because I have the bike on the center stand sitting on the lift and the rear tire is suspended? Could it be because I am using different shocks? Would the rub be solved if the rear tire was sitting on the ground and the shock is compressed? Please help. THanks
                    1979 xs1100f
                    New Fuse Box
                    Progressive Shocks
                    Gold Valve Emulator
                    Dyna Coils
                    Electronic Flasher
                    Led Headlight
                    Led Turn Signals
                    2nd Gear Fix
                    Auto Cam Tensioner
                    Digital Dash
                    Stainless Bolt Kit
                    Maier Fairing
                    Spin On Oil Filter
                    Plasti Dip Rims
                    ISO Grips
                      Sounds like the swingarm isn't centered in the frame.....
                      • TheRev
                        • Jun 2012
                        • 235
                        • Madison, Wi.
                        #56
                        That's what I thought but I measured it correctly. What is happening is the swing arm is tilted down because the tire is suspended. The bottom lip of the swing arm is hitting the u joint that is spinning. So I think the shocks I put on are too long. What size shock does the xs1100 have?
                        1979 xs1100f
                        New Fuse Box
                        Progressive Shocks
                        Gold Valve Emulator
                        Dyna Coils
                        Electronic Flasher
                        Led Headlight
                        Led Turn Signals
                        2nd Gear Fix
                        Auto Cam Tensioner
                        Digital Dash
                        Stainless Bolt Kit
                        Maier Fairing
                        Spin On Oil Filter
                        Plasti Dip Rims
                        ISO Grips
                          12 5/8" center to center eyelet.
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            #58
                            Mine is 14 inches. I think that must be my problem. I bet if the bike was sitting on the ground and the shocks were compressed there would not be a problem. What do you think?
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              When you are riding and the shock fully extends, it will hit like it does now. I would find some shorter shocks.
                              • TheRev
                                • Jun 2012
                                • 235
                                • Madison, Wi.
                                #60
                                I was wrong. My shocks are 12.5. So now I am back to square one. Why would the u joint hit the inside edge of the swing arm when the rear tire is suspended above the ground? I am so close to finishing this bike. I just can't figure this damn rear end out. Please help.
                                1979 xs1100f
                                New Fuse Box
                                Progressive Shocks
                                Gold Valve Emulator
                                Dyna Coils
                                Electronic Flasher
                                Led Headlight
                                Led Turn Signals
                                2nd Gear Fix
                                Auto Cam Tensioner
                                Digital Dash
                                Stainless Bolt Kit
                                Maier Fairing
                                Spin On Oil Filter
                                Plasti Dip Rims
                                ISO Grips
